Old 02-16-2009, 11:31 AM   #1
thumperdump OP
thumperdump's Avatar
Oddometer: 44
Best Hand Pump to Carry?
So whats a good compact hand pump to carry with? I don't want a 12 volt one, but a hand - foot pump. I've contacted a couple places that sell bicycle pumps and they didn't think they would work very well on motorcycle tires as they would be very hard to pump up. I'm going to check out Walmart, but probably what they have are similiar to what I've looked at. Any suggestions?
thumperdump is offline   Reply With Quote
Old 02-16-2009, 12:48 PM   #2
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,269
One of the Topeak Morph pumps.
Walter
Walterxr650l is offline   Reply With Quote
Old 02-16-2009, 02:25 PM   #3
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,832
I bought a $15 Bell bicycle hand pump at Wallyworld, works just fine on a motorcycle....no problem at all. It's a small pump, like all hand pumps so you're going to have to give it a good few minutes of effort....like 100-120 pumps to inflate, but it's also not relying on juice and it packs light so no big deal.
swingset is offline   Reply With Quote
Old 02-16-2009, 02:37 PM   #4
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Crankbrothers Power Pro with Gauge
I use this one which works very well for my Enduro and also mountain bike.
weight120g
length6.9" / 175mm
material6061-T6 aluminum barrels
pressure115psi / 8bar
air switchhigh volume / high pressure
colornatural or black
mounting bracketnot included
patch kitnot included
warrantylifetime
http://www.crankbrothers.com/powerpump_pro.php#
Fast1 is offline   Reply With Quote
Old 02-16-2009, 02:43 PM   #5
thumperdump OP
Oddometer: 44
I just went to Wally World and bought a Campbell Hausfield foot pump for $6.97. It is about10LX3 1/2Wx2 1/2thick, it is spose to pump up a car tire, so should work on a motorcycle tire. It's a little bigger than I wanted, but guess it will have to do. I guess if one of you fellows reccommend something I like better, I can return it to Wally World.
thumperdump screwed with this post 02-16-2009 at 02:50 PM
Old 02-16-2009, 02:49 PM   #6
MillCreek
ADV Risk Manager
Oddometer: 1,996
I concur with the recommendation for a mountain bike frame pump. They are designed for larger and lower pressure tires such as a motorcycle tire. I have used my MTB frame pumps to inflate many motorcycle tires. The smaller road bike frame or pocket pumps work as well, they just need a larger number of pumps to inflate a motorcycle tire.
Any REI or Performance bike shop will have many pumps to choose from.
Regards,
MillCreek
Snohomish County, Washington USA
2012 Suzuki DL650A as the current bike
Whole bunch of bikes in the past
MillCreek is offline   Reply With Quote
Old 02-16-2009, 03:03 PM   #7
Owyhee
Ran when parked
Owyhee's Avatar
Oddometer: 557
I have a $7 mountain bike pump in the tool bag on my XR. It's about eight inches long and about 1/4lb. From flat it's 125 pumps to get a 90/90-21 to 15psi and about 220 pumps to get a 140/80-18 to 15 psi. Anything above 15psi makes it hard to pump especially after pumping a few hundred times.
"O"
Owyhee is offline   Reply With Quote
Old 02-16-2009, 03:07 PM   #8
LukasM
Oddometer: 5,425
I have read lots of reviews trying to find the best hand pump as well. The Topeak Morph series was strongly supported everywhere, they work well and everybody loves the fold-out foot. Sells for about $25 or so, I will probably get the Mini Morph to carry as a back-up for my cheapo stripped down 12v compressor.
Old 02-16-2009, 03:14 PM   #9
bluesman
Oddometer: 3,347
why would you want hand pump when you can have foot pump :)
I got one on Intermot and it's just sooooo cool.
http://www.minifootpump.com/new_mfp/...p_product.html
or
http://www.minifootpump.com/new_mfp/...r_product.html
I have similar one except it is metal, a bit heavier and have electronic gauge :) and it is brilliant.
bluesman is offline   Reply With Quote
Old 02-16-2009, 03:17 PM   #10
johnnyandjebus
johnnyandjebus's Avatar
Oddometer: 532
Not to take this too far of topic but can you set the bead with a mtn bike pump. I am looking as well for a small manual pump but find I need 40-60 PSI to set the bead properly. Could be I am doing something wrong as I am a noob at tire changes/flat repairs.
That crankbrothers pump looks sweet.
John
1994 DR350se
johnnyandjebus is offline   Reply With Quote
Old 02-16-2009, 03:30 PM   #11
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
The Crankbrothers will pump to 115 psi although it will take allot of pumping due to the volmune of air required to fill a motorcycle tube. I flated this weekend on a 35 mile mountain bike ride and used it to inflate the mountain bike tire to 55 psi after patching the tube. I like to carry a very small volume, 3 or 4 oz, of dish soap in a container to aid in removal and re-seating of the motorcycle tire bead. I've also used the Crankbrothers pump to air up for pavement sections when on the motorcycle and I've found that the gauge is fairly accurate.
Old 02-16-2009, 04:13 PM   #12
fixer
KLR-riding cheap bastard
fixer's Avatar
Oddometer: 7,439
$7 for the WM foot pump is cheap... but it's heavy and bulky compared to a MTB hand pump.
visit the local bicycle shops and see what they have. ask them what they use. ask if they have any you can try.
Sit tall in the saddle, Hold your head up high
Keep your eyes fixed where the trail meets the sky
And live like you ain't afraid to die
And don't be scared, just enjoy your ride.
"... in my version of Heaven you get all your dogs back." Mista Vern
"Old dogs don't die, they just wait for you in another place." Twilight Error
I'll show you a place, high on a desert plain, where the streets have no name.
fixer is offline   Reply With Quote
Old 02-16-2009, 04:53 PM   #13
Two Hawks
Old School
Two Hawks's Avatar
Oddometer: 43
Thumb Topeak Morph pumps
Another vote for the Topeak Morph pump. Been using mine for a long time on both my Mtn Bikes and motorcycles. Both light and compact but mainly it just plain works..
Molon Labe
Two Hawks is offline   Reply With Quote
Old 02-16-2009, 04:58 PM   #14
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,510
weight120g
length6.9" / 175mm
warrantylifetime
DrLewall is online now   Reply With Quote
Old 02-16-2009, 05:16 PM   #15
lvdukerider
Las Vegas Nevada
Oddometer: 523
My local wally world stopped carrying those (I think because of me). I used to use mine on a real regular basis and would get about 1 month use out of one before it would fail, usually the shaft would wear a groove in the cheap stamped metal end of the pump body then the whole thing would just jam up. I would then bring the box and reciept back to wally world and they would cheerfully give me a replacement. They finally ran out of them and stopped carrying them and refunded my $6.97 which I put towards one of those tiny Slime brand mini electric air pumps. For emergency use the Bell foot pump is proably fine.
lvdukerider is offline   Reply With Quote
Times are GMT -7.   It's 08:22 AM.
