03-30-2009, 06:51 AM
#61 | |
House Ape
Oddometer: 2,169
David
David I'm tryin' ta think, but nuttin' happens! --Curly |
03-30-2009, 07:01 AM
#62 | |
MotoInsight
Oddometer: 933
Seriously - every single set of crashbars on the market bolt there with the exception of the Wunderlich setup.
Rob Werksman - Owner, Motorcycle Insight, LLC Adventure Motorcycle Depot | S1000RR Depot | F800 Depot | Twalcom USA North American Importer - Globescout, Twalcom, Wild@Heart, Hornig, AC Schnitzer (Motorcycle) |
03-30-2009, 07:33 AM
#63 | |
Oddometer: 262
http://www.newfrontiersadventures.com/MC/CentralAm.html |
03-30-2009, 09:42 AM
#64 |
Begining the Adventure
Oddometer: 997
Even the BMW bars mount to the engine. I suspect that is exactly what those mounting points were made for.
03-30-2009, 10:36 AM
#65 | |
North Forest Rider
Oddometer: 3,620
03-30-2009, 02:01 PM
#66 | |
Oddometer: 1,152
After all, it's to THEIR benefit when finishing up with cracked engine cases after a more serious hit. Seems that only Wunderlich and Touratech got it right then. I'm not an engineer, but a "flexible" (steel) long-leverage impact-item bolted to a more rigid /brittle Alum item spells trouble.... doesn't really need Einstein-quals, does it? Time will tell, I guess... (nb Not trying to stir the shit here, just thinking aloud...and from experience) |
03-30-2009, 02:39 PM
#67 | |
North Forest Rider
Oddometer: 3,620
When speaking of the Holan, BMW, Adv Spec, etc.: the brunt of the force from a hit would direct most of the force to the frame. The main connection point for these crash bars is on the sides of the bike, by the top of the engine. This connection is directly to frame, and designed by BMW and other to take the brunt of the impact. Not much would happen to the small connecting point at the bottom of the engine. And actually, the Holans are designed to relieve stress at these connection points as well. |
03-30-2009, 03:24 PM
#68 | |
MotoInsight
Oddometer: 933
In any case, you're incorrect about Touratech - they attach to the same mounting points, and I'm putting my trust in them (and their OEM Holan) over someone on an internet forum. Nothing personal, just sayin...
03-30-2009, 03:42 PM
#69 | |
Intl' Hops Inspector
-Jordan- Summer 09 Venezuela to Minnesota: Summer http://www.advrider.com/forums/showthread.php?t=449804 The goal of course is everywhere US (MN, WI, IA, KS, OK, MO, TX), Mexico, Belize, Guatemala, El Salvador, Honduras, Nicaragua, Costa Rica, Panama, Colombia, Venezuela. 11 down, 184 to go. |
03-30-2009, 03:49 PM
#70 | ||
Oddometer: 1,152
Physics are physics, impact forces are impact forces...regardless of brand/ model. Qualified? If common sense and 35 years of wrenching and riding (incl. building a few bikes over the last few years) counts.... Quote:
If a hit is directed upwards and looking at the twin-brace of the bars running vertically up the side, those 2 little 5mm Allen bolts at the bottom will either rip out of their their threads or just snap, the curved mounting plate hitting the engine cover (which is usually very thin cast). The more likely scenario is a drop while riding... directing impact forces upwards/ rearwards....and as the upper mounting location is more solid than the bottom, that upper bolt will act as a pivot... again tearing the bottom plate off the casings (as the down-leg is nicely braced and therefore fairly solid = transmit forces). God forbid if those down-struts get snagged on a solid branch or the edge of a rock (creating rotational forced on the bottom bracket). It's the same problem as on the DL650, which just hasn't got any decent mounting points to mount a bash plate...some aftermarket supplier decided to make a "super-tough" bashplate from 5mm alloy, all braced up and beautifully finished....with a top-mount on the front cyl head. Great piece of work that thing .....for an ashtray. |
03-30-2009, 04:34 PM
#71 | |||
North Forest Rider
Oddometer: 3,620
And, whatever dude. You don't know what you're talking about. BMW wouldn't have designed it like that if it would have been a problem. You're purely speculating. The Griz screwed with this post 03-30-2009 at 04:45 PM |
03-30-2009, 04:55 PM
#72 | |||
Oddometer: 1,152
Doesn't that all come down to direction of impact, force-vectors and an endless number of other possibles? 3) Snap at mounting points? That's one thing I still have to see. Seen dozens bent and buckled, totally out of shape and folded back onto themselves with all sorts of colateral damage...but I've never seen a crashbar break at the mounting points/ plates. No OEM bar, Givi, Hepco or whatever... The odd broken broken weld caused by vibration, sure...but never snapped at "pre-designed" points. Quote:
Plenty of evidence around of the "Big Guns" in the industry (any industry, really) goofing up. Quote:
03-30-2009, 05:06 PM
#73 | |
Oddometer: 1,152
Sorry for sprouting shit then...I'm deeply humbled Of course the F8 isn't even a bike...and almighty BM is way beyond Godliness
03-30-2009, 05:41 PM
#74 |
Oddometer: 1,237
Just for reference and off topic I understand, But I went with the TT bars and they do not mount to any points on the engine. They use the footpegs and the same central frame mount everyone else does. Sorry, I don't have pics at present.
03-30-2009, 06:04 PM
#75 | |
North Forest Rider
Oddometer: 3,620
