Go Back   ADVrider > Riding > Regional Forums > Pacific Northwet - Where it's green. And wet.
Old 06-10-2014, 02:48 PM   #1126
sorebutt
Oddometer: 2,002
I've run everything from stock to what ever I could find at that size. My last tubes were Michellin heavy duty. They are really thick. I've had tubeless tires that were thinner than those tubes. They are a little hard to work with, but they should last and be puncture resistent.
sorebutt is online now   Reply With Quote
Old 06-10-2014, 02:57 PM   #1127
sethc06
sethc06's Avatar
Oddometer: 87
Do you mean the ultra heavy duty? I couldn't find the right size for the rear. Those are the ones that are 4mm thick.
Sent from my SCH-I535 using Tapatalk
"I would rather wake up in the middle of nowhere than in any city on earth." -Steve McQueen
sethc06 is offline   Reply With Quote
Old 06-10-2014, 03:06 PM   #1128
sorebutt
Oddometer: 2,002
That would be the ones.
Order some spoke weights also if you want me to mount your tires. The ones that go on the spokes last forever and are easier to put on and balance.
Old 06-10-2014, 03:12 PM   #1129
zaptoad
just a guy
zaptoad's Avatar
Oddometer: 304
Just wondering.......
These are good heavy tubes, so don't get me wrong. Everyone has had different experiences. With sustained highway speeds however, heavier tubes tend to build more heat than lighter tubes. On many of the 950 KTM sites, they recommend not running too heavy a tube. I have had them melt right on to the inside of my front tire before and had to literally rip them back out of the tire. I tend to run heavier tubes in my lighter bikes and lighter tubes in my heavier bikes. Just wondering what your experiences were?
Thx.
"In 3 words I can sum up everything I know about life: it goes on" Robert Frost
"If I knew where I was, I wouldn't know where I was going!" ODDA
zaptoad is offline   Reply With Quote
Old 06-10-2014, 04:19 PM   #1130
sorebutt
Oddometer: 2,002
I have them on a K60 for almost 9000 miles. I've ridden everything from rough off road to hwy at 70 mph and haven't had any problem. They are on an 800 GS. I've ridden in some pretty hot weather also.
Old 06-10-2014, 04:22 PM   #1131
RestlessRider
Oddometer: 254
I will try to make it to the Wallowa rally.
RestlessRider is offline   Reply With Quote
Old 06-10-2014, 05:08 PM   #1132
sorebutt
Oddometer: 2,002
I'm leading a ride from Asotin next Thurs. We will be leaving Asotin at 10:00. Try to make it.
Old 06-10-2014, 05:27 PM   #1133
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 11,403
I'm waiting for your IN on the thread.
Ladybug0048 is offline   Reply With Quote
Old 06-10-2014, 07:55 PM   #1134
DoubleThumper
Purposefully Lost
DoubleThumper's Avatar
Oddometer: 370
Thx.
You need to use more baby powder inside the tire to cut down the friction!
Sent from my MIND using TELEKINESIS V2.3
DoubleThumper is offline   Reply With Quote
Old 06-10-2014, 08:08 PM   #1135
DoubleThumper
Purposefully Lost
Oddometer: 370
The (Plain, unscented, Cheep) Talcum powder will help you NOT pinch your tube when mounting and dismounting the tire and it will help the tire run cooler on the highway.
Old 06-10-2014, 08:22 PM   #1136
sorebutt
Oddometer: 2,002
Why don't you want to smell good?
Old 06-10-2014, 08:44 PM   #1137
sethc06
sethc06's Avatar
Oddometer: 87
Which rear tube size are you running. I'm only seeing 18s available in the Michelin UHD tubes.
I'll get some spoke weights with the tubes. I'm assuming you'll have the powder since you're retired yeah? Oh and I'm noisy now!
Old 06-10-2014, 08:53 PM   #1138
DoubleThumper
Purposefully Lost
Oddometer: 370
Try Moose Tubes.
http://www.mooseracing.com/products/...oductId=114465
Old 06-10-2014, 09:06 PM   #1139
sorebutt
Oddometer: 2,002
I have the heavy duties on the front. I don't remeber what I have on the rear.
Old 06-10-2014, 09:36 PM   #1140
zaptoad
just a guy
zaptoad's Avatar
Oddometer: 304
really! ;-)
Only been riding 52 years. I've learned a little, but just a little...... .
I don't run TKC's on the front either. Flimsy side walls pinch flat.
Times are GMT -7.   It's 11:21 PM.
