Old 02-26-2009, 05:46 PM   #1
dwalk51 OP
Oddometer: 4
Vento Zip r3i carb tuning?
Hey all, so I took out the carb on my zip today, sprayed it down, and put it all back together. Somewhere along the line I inadvertently messed up the idle adjustment screw as well as the mix screw. Could someone tell me the default settings that these should be? I couldn't find it on the site or using google.
Btw, when it says, X turns out, like 2.5, does it mean have the screw screwed all the way in, and then X full rotations of the screw?
dwalk51 is offline   Reply With Quote
Old 02-27-2009, 07:37 AM   #2
jhuth
jhuth's Avatar
Oddometer: 186
scootdawg
try scootdawgs info or forum might have better luck there
http://www.scootdawg.com/
http://scootdawg.proboards59.com/
"Art is what you can get away with." -Andy Warhol
jhuth is offline   Reply With Quote
Old 02-27-2009, 10:56 AM   #3
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,403
So did you unscrew the pilot and main jet bodies and give them a visual inspection?
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 02-28-2009, 10:18 PM   #4
dwalk51 OP
Oddometer: 4
well no, but I took it pretty much apart and sprayed it down real good. All I need to know is what to screw them back to. Wish I hadn't messed with it, oh well.
Times are GMT -7.   It's 03:28 PM.
