Old 03-01-2009, 03:32 PM   #1
cruthas OP
AdvMotorcyclist Counselor
cruthas's Avatar
Oddometer: 235
Broken KLR in Mountains of Peru, help please?
Ok, so my KLR has a starting issue. I stopped it and went to turn it back on without putting it in nuetral and the bike power went dead, no lights no nothing. I can jump the bike on a hill and it runs fine, the lights flicker a little. When the bike is jumped it runs fine but when I stop it turn it back on I have all the lights but when I push the start button I hear a shorting noise from some where and all the power dies. If I roll the bike a bit the power come back off and on. Not sure what to do? Any ideas? Any help would be great
Thanks Dave
riding on two wheels, one in front of the other.
www.mototheworld.com
<-------- My Journey
My Moto Video Diaries Part I
My Moto Video Diaries Part II
2004 Kawasaki KLR 650
1995 Kawasaki KLR 650
1981 Honda CB750
1998 Suzuki GSX-R 600
1997 Kawasaki Ninja 600R
cruthas is offline   Reply With Quote
Old 03-01-2009, 03:52 PM   #2
tedder
irregular
tedder's Avatar
Oddometer: 8,797
The shorting noise might just be the solenoid engaging.
Check your battery cables first. It's likely one or more are loose. Then check battery voltage. Start working though things logically.
tedder is offline   Reply With Quote
Old 03-01-2009, 03:56 PM   #3
cruthas OP
cruthas's Avatar
Oddometer: 235
I allready checked and dis-assemmbled all the connections
could it be the starter? --roter?
1981 Honda CB750
Old 03-01-2009, 04:03 PM   #4
tedder
irregular
tedder's Avatar
Oddometer: 8,797
Could be the starter, yeah. Might be time to find a local mechanic.. hard to diagnose over the 'net.
Do you have a multimeter (ohmmeter) so you can test the various starter connections? If so, someone here might be able to paste in the correct values for them. If not, again, a local guy is probably your best bet. Latin American mechanics are da best.
Old 03-01-2009, 04:47 PM   #5
JV
What?
JV's Avatar
Oddometer: 587
Might try this.
http://www.klr650.net/forums/showthread.php?t=47827
JV is offline   Reply With Quote
Old 03-01-2009, 05:06 PM   #6
yosmitetom
Oddometer: 3,354
I sure sounds like a bad connection at the battery to me. This very thing has happened to me several times. I know you said you checked it but I would recommend checking it again. I carry a 10mm wrench handy just for this. Second wild ass guess is the starter solinoid that is located under the plastic cover on the left side near the battery.
yosmitetom is offline   Reply With Quote
Old 03-01-2009, 05:18 PM   #7
Thraan
Thraan's Avatar
Oddometer: 29,892
How much water in the battery? It sounds like it doesn't have enough juice to turn the motor over.
Work is the curse of the drinking classes - Wilde
Thraan is offline   Reply With Quote
Old 03-02-2009, 06:30 AM   #8
the_gr8t_waldo
Oddometer: 2,151
when you check everything associated with the starter, don't forget the return electrical path. it's often overlooked
the_gr8t_waldo is offline   Reply With Quote
Old 03-02-2009, 06:36 AM   #9
tjhess74
tjhess74's Avatar
Oddometer: 590
not familar with the klr's all that much, but ive had some starter button issues on previous kawasakis. the switch gets corrosion or water in it and creates a short. it makes the starter think its trying to engage, which will short out all your lights and such. i would take the switch off and peek inside. its a very simple problem that has big symptoms.
avatar pic: Tathum Gap, Trail of Tears, NC.
my goal is to see how many gallons of dead dinosaurs i can send through my bike.
2008 Kawasaki Concours 14
2007 Honda VFR800 RWB
tjhess74 is offline   Reply With Quote
Old 03-02-2009, 09:28 AM   #10
dminded
Oddometer: 167
It does sound like a loose connection, but I'd check battery two. klr's are know for boiling out the water. If so all you have to do is top back off with distilled.
dminded is offline   Reply With Quote
Old 03-02-2009, 03:31 PM   #11
PukaWai
PukaWai's Avatar
Oddometer: 708
It sounds like a battery issue -mine acted like that when the battery was dying. A couple of things to check: the stator output wires run near the front of the front sprocket. I once broke my chain and the end whipped through there and damaged those wires. It took forever to find that problem, so check the whole length of the stator output wires for damage.
Also, I was able to order a kick-starter kit for mine from Kakasaki, the motor was designed so that you could install this thing, even though they did not come stock with it. I think it was around $200 - good insurance against dead batteries. I'm not sure if Kakasaki did away with that option on later models?
PukaWai is offline   Reply With Quote
Old 03-02-2009, 04:39 PM   #12
bmwktmbill
Traveler
Oddometer: 5,218
Any auto shop should be able to diagnose the problem if you can't, in Cusco there are several good bike shops, go to Norton's rat bar on the square and ask for a good shop...and have a beer and some food.
Have some heavy hitters haul your rig there if you can't start it, figure it or yourself out.
Should be plenty of downhill in the Andes to bump start bro, think like a Sud Americano motorcyclist.
Take a few deep breaths, you are short on Oxygen.
Here's a link to Norton's...
http://www.nortonrats.com/
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 03-02-2009, 06:13 PM   #13
RoadBound
Is it springtime yet?
RoadBound's Avatar
Oddometer: 44
I've got a HD Wide Glide that I have to be careful washing to avoid getting water into the starter button housing. It behaves exactly as you describe, dimming the lights for an instant but usually (but not always) breaking the connection again before the starter actually engages. This doesn't surprise me with a Harley, but the KLR would not be that easy to get the electricals wet. How old is your bike? If it's only a few years old I would think that you could rule out corrosion in the switch as well. I'm betting along with the others that there is a short somewhere to/from the starter. A loose battery terminal connection would be pretty obvious, so unfortunately your problem may require some disassembly to locate. Don't forget to check the fuse box for condensation/corrosion. Any mods or wrecks lately that could have caused damage?
RoadBound is offline   Reply With Quote
Old 03-02-2009, 06:21 PM   #14
tedder
irregular
tedder's Avatar
Oddometer: 8,797
Cruthas's KLR spent time on a small boat for many days, so it got more than its share of "marine air".
When my DL spent a week in the same conditions, everything was rusting. I swear, even plastic rusts with that much salt air.
Old 03-02-2009, 06:33 PM   #15
smokeysloth
Chronic Bike Trader
Oddometer: 84
Check the grounds again- jump the starter solenoid with a pair of pliers (worked for me for a couple thousand miles through latin america). good luck and let us know how it goes!
smokeysloth is offline   Reply With Quote
Times are GMT -7.   It's 04:56 PM.
