03-02-2009, 04:17 PM
#1 |
The Belgian
Oddometer: 400
Review: Protaper ATV high handlebars
After my last ride, I noticed my right wrist became cramped. After soem fiddling, I found out it was the bend in the OEM bars. Some searching led me to the Protaper ATV High bars.
![]() Placement was easy, first loosen all the stuff on the OEM handlebar. Then slide the handlebar all the way to one side and slide stuff off the other side, and vice versa. The crossbar has a thick foam pad on it, but my Scotts Steering Stabilizer was in the way. I could use it that way, but I wanted to be able to reach the dial. So, a screwdriver between the foam and the bar, a bit of WD40 and it slid right off. ![]() ![]() Reinstall same as install, no longer hoses needed with no risers. Very happy with it's position now, feels better allready! Remember to file off the tabs on the inside of the clamshell-like switchhousings. They have a tab that sits in a hole on the OEM bar, don't need that. Stock bar ends don't work, need to be modded. I installed Acerbis handguards instead. |
03-21-2011, 06:36 PM
#3 |
Husky Racer
Oddometer: 100
1. The Pro Taper bar: Is this a standard diameter bar (7/8") or a Fat Bar? I have the same cramped right arm issue that I discovered on my first ride. Does the Pro Taper bar have less pull-back than the OEM bar? Any other recommendations for bars? 2. The handguards: Any pros/cons on the Acerbis vs the Highway Dirt Bike guards (other than cost)? Any other recommendations? 3. What did you use for replacement grips? I plan on ordering bars & handguards this week, so any responses would be welcome! Thanks.
03-21-2011, 11:21 PM
#4 |
The Belgian
Oddometer: 400
Standard 7/8". Less pullback, wrists are better positioned.
Acerbis need the adapter kit, and it can be a bit of a pain to get them to fit with the controls. Might need to file the end of the brake lever so it doesn't bind on the inside of the metal brace I placed Oxford heated grips with grip puppies, but the puppies were too thick so I cut them off. Ran the Strom for 20.000km's like that. Sold the Strom last month and got a Super Ténéré instead, so can't be of any more help. Great bike though!
Yamaha XT1200Z Super Ténére |
03-22-2011, 09:56 AM
#5 |
Oddometer: 853
i have the same setup on my wee and love it. i have the same exact acerbis enduro guards as well. when my scott grips wear out i'm putting on a set of protaper half waffle/half knurled. i have the symtec grip heaters. I used cycra probend brackets to attach the handguards.
It's a Jungle out there. 2007 Blue Weestrom 2004 Yamaha Wr250f |
12-20-2011, 08:30 AM
#6 |
countercurrent exchanger
Oddometer: 210
remove padded crossbar?
just got some protapers on and getting used to them- but one complaint is that the padded crossbar gets in the way of inserting and removing the key. does it serve any function, other than looking tough?
12-20-2011, 10:06 AM
#7 |
The Belgian
Oddometer: 400
I'm sure it does, but you can always do as I did, remove the foam...slides right off!
12-20-2011, 11:51 AM
#8 | |
Verbal tactician
Oddometer: 9,202
It helps stiffen the bar in the event of a drop or crash. Even then, 7/8ths bars are very bendable. IMO, fatbars are so much more durable it is worth the little extra dough and extra fitting time needed to install.
all around good guy |
03-09-2012, 04:15 AM
#9 |
Steady Rollin' Man
Oddometer: 215
The foam is to protrect your melon in a wreck.
Smooth is fast. |
03-09-2012, 09:43 AM
#10 |
Oddometer: 147
Just installed the same bar on my r80st. What a difference! Stock bars put my wrists at a weird, unnatural angle. Extended rides became painful. Looked around, and these bars were the ticket. Hat to sand the ends down a bit to fit the BMW controls onto the bars, but no big deal. Apparently it's a metric/sae thing. No biggie. Pretty sure I got them off of amazon for about $45ish.
Anyway, great bars, low price, and comfy. Nailed it! |
