Old 03-05-2009, 02:13 PM   #1
Bucket Boy OP
The other mechanic
Bucket Boy's Avatar
Oddometer: 399
DL650 Tow Hitch
I'm finally fabricating some of these hitches for a few of you ADV riders. So how many do I need to make here? $299 (DL650)
While I invite any and all questions about the hitch and what its like to tow, PLEASE dont waste space in here if you think its a stupid/unsafe idea.
Pro's-
-6 bolts, 5 min install
-Tow ball in line with axles (no upset with braking)
-Universal 1 7/8" ball
-Endless uses for trailering
Con's-
-Will not work with centerstand
-Gas stops take an hour answering peoples questions
I've towed 5,500 miles on the prototype hitch with weights up to 400lbs at 90mph. No adverse handling differences.
http://www.cascadetourcompany.com/products.html
AlpineTourCo.com
Bucket Boy screwed with this post 03-15-2009 at 08:52 AM
Bucket Boy is offline   Reply With Quote
Old 03-05-2009, 02:26 PM   #2
Bucket Boy OP
The other mechanic
Bucket Boy's Avatar
Oddometer: 399
"What's it like in the corners?"
If the road is smooth I run at normal speed through the corners. Note you are a foot wider in the rear so you may not run all the way to the painted lines. If the road is really bumpy you can feel the feedback as you have tounge weight on the hitch. Nasty road= obey yellow caution signs (suggested speed).
AlpineTourCo.com
Old 03-05-2009, 02:31 PM   #3
Bucket Boy OP
The other mechanic
Bucket Boy's Avatar
Oddometer: 399
"Is first gear to tall?"
I recommend stock gearing. If your running a 16-17 tooth counter sprocket you may need to go back down. The most important idea here is to slip the clutch a bit if your going out of a "dip" style driveway as the trailer weight will pull a bit back on you. I'm currently towing a gross weight of 215lbs so can run a bit higher then stock gearing.
AlpineTourCo.com
Bucket Boy screwed with this post 03-05-2009 at 02:42 PM
Old 03-05-2009, 02:39 PM   #4
Bucket Boy OP
The other mechanic
Bucket Boy's Avatar
Oddometer: 399
"Do you have enough braking power?"
Of coarse you require a bit more room, but not much more. Consider a dresser Harley weighs nearly a thousand pounds with a normal center of gravity for a mortorcycle, VS. DL650 500lbs with luggage and towing a TTR on trailer (250lbs) Your sitting at aprox 750lbs with better brakes. And the towed weight is pushing at the center line of the axles not 3ft up.
AlpineTourCo.com
Old 03-10-2009, 03:04 PM   #5
Bucket Boy OP
The other mechanic
Bucket Boy's Avatar
Oddometer: 399
Painted black, or your choice of black.
AlpineTourCo.com
Old 09-19-2010, 02:16 PM   #6
Spiritrider21
Oddometer: 1
Fixings ?
I know this is an old thread but it is still interesting !
Do the two struts mount to the footpeg fastenings ? I am guessing
thats how it works.
Heres hoping for a reply I will make one thgis side of the pond !
Many Thanks
Spiritrider21 is offline   Reply With Quote
Old 12-15-2012, 09:48 PM   #7
ki4idb
V Strom Rider
ki4idb's Avatar
Oddometer: 273
HItch
I would like more information on these hitches. I have a 2007 DL650.
Alec
www.mytb.org/Shadow-Man
Bike:
'07 Suzuki DL650 V-Strom
'07 Honda Shadow VT750DC (Totaled)
ki4idb is offline   Reply With Quote
Times are GMT -7.   It's 06:02 PM.
