Old 04-17-2011, 06:42 AM   #61
leafman60
Oddometer: 1,882
So cruising on the interstate at 70 for 500 miles is gonna be a buzzy time with the 250?
I like the specs of this thing but Id also like to be able to consistently run at highway speeds.
leafman60 is offline   Reply With Quote
Old 04-17-2011, 06:45 AM   #62
leafman60
Oddometer: 1,882
By the way, what sorta fuel-mileage are you guys getting with it ?
Old 04-17-2011, 08:21 AM   #63
Romabuk
Hole in da pants
Romabuk's Avatar
Oddometer: 114
Great thread, I just ran in to a fellow who last year rode a xt250 from Vancouver to Alaska and back last summer. I weigh 220, and it seems a set of these could work out for me and my girl!
Romabuk is offline   Reply With Quote
Old 04-17-2011, 08:46 AM   #64
dec181966
Dude on a motorcycle
dec181966's Avatar
Oddometer: 164
Freeway suitability & milage
Hey Leafman60,
Without changing the sprockets the XT would be hard pressed to do 500 miles at 70 mph. I have had mine in the low 70s for short runs on the hwy but this is not a strong point for the little 250. It will do but....yes at higher cruising speeds it can be a bit buzzy.
As far as milage I get about 130 miles out of the 1.9 gallons (CA version) before I hit reserve so about 68 mpg.
"I dodge the grave most everyday"
dec181966 is offline   Reply With Quote
Old 04-17-2011, 06:12 PM   #65
leafman60
Oddometer: 1,882
Yes, thanks. I like the little bike a lot. I almost bought a left-over model last summer. There are, or were, some killer deals on past year's models. Instead I ended up with a BMW G650XCo. The 650 will cruise at 80-90 all day and then do pretty well on gravel and dirt roads. Love it.
I still like the look and feel of the XT. I sure wish they'd make an XT350 ! I think that would kick it up a notch that maybe it needs.
leafman60 screwed with this post 07-27-2011 at 01:53 PM
Old 04-25-2011, 09:30 PM   #66
Alacrity
Semi Pro Bar Vaulter
Alacrity's Avatar
Oddometer: 468
XTs fine for what it is - my DRZ400E is less fun here than my XT.
Not as fun as a KDX - but fun enough
The greatest pleasure in life is doing what people say you can't. So far...its working. The bars low
Alacrity is offline   Reply With Quote
Old 04-25-2011, 09:45 PM   #67
Lucky:)
Oddometer: 224
nice trail :)
Lucky:) is offline   Reply With Quote
Old 04-26-2011, 05:03 PM   #68
Alacrity
Alacrity's Avatar
Oddometer: 468
Originally Posted by Lucky:) View Post
nice trail :)
Yea it sure beats this - normal spring at the farm
Theres a D606 in there somewhere
Old 04-26-2011, 10:14 PM   #69
ALinUTAH
Oddometer: 722
I wanted to chime in and say that 70mph for 500 miles on the interstate is just a little too much to ask of an XT250. It would be possible on flat ground with no headwind, but it would be pushing it to the max. I rode 350 miles the other day on mine, about 100 miles of that was 60-65 on the highway and it just purred along at that speed. I got it up to 77 briefly, laying down as low on the tank as I could. It took a long time to go from 70-77 and then felt like it hit a rev limiter. I'm not sure it has the power to push a taller sprocket ratio, and you wouldn't want to give up the lower end if you ride trails. -al
ALinUTAH is offline   Reply With Quote
Old 04-27-2011, 07:46 AM   #70
dec181966
dec181966's Avatar
Oddometer: 164
Question Hand guard question
Hey Alacrity,
Can I ask what hand guards you have on the XT? Did you have to mod anything to get them on?
Thanks!!
Michael
Old 04-27-2011, 12:07 PM   #71
kaosrider
kaosrider's Avatar
Oddometer: 885
A little help please
OK Had this 08 XT for about 3 years. It is the wife's bike, she tried to kill it.. then my daughter joined me on a dual sport event..she did great, but there was this one water hole
OK so bike went underwater. (As a sied note this bike has been the greatest at restarting after falling down, no flooding issue etc. like other bikes) Pulled it out of the water onto the trail and started draining water. The air box does not apparently have a drain. It was totally full of water. We truned the bike complete upside down, sitting on handle bars and rear bike rack. I had to lean it back and forth for the water to keep coming out. Set it back up right and then it started up . We rode for the rest of the day and back to camp say another 40 miles.
So made a note to self to go home and change oil etc. Ordered new air filter. So then maintenance began. As my luck would have it or operator error, whatever I could not get the oil plug loose. I eventually rounded off the head of the bolt. Now, not one to be beaten, I went afterit. I turned the bike back upside down and worked on the bolt. got it loose. Put rightside up again changed the oil and air filter. Buttoned it back up and will not start.
Took seat off again and looked into air box and there was oil in there . It did not look like the new clean oil, so maybe from being upside down, old oil from crank case or something.... Clean it out and bike fires up then quits. Bottom line is bike will run with the air filter out but as soon as I put the air filter in the bike quits, any thoughts?
kaosrider is offline   Reply With Quote
Old 04-27-2011, 12:41 PM   #72
Alacrity
Alacrity's Avatar
Oddometer: 468
Originally Posted by dec181966 View Post
Hey Alacrity,
Thanks!!
Michael
Cycra CRM - had to play with them a bit to align, but no mods. They are on ProContour YZ Hi - so not sure if they'd work as well on the stockers.
Better pic of the attachment from the side
Looking at the mud pic above again those are Cycra Composites - the CRMs mosied on - but both fit fine
Alacrity screwed with this post 04-27-2011 at 12:47 PM
Old 04-27-2011, 02:41 PM   #73
dec181966
dec181966's Avatar
Oddometer: 164
Thanks!!
Thanks for the quick reply!!
Old 11-13-2011, 11:48 AM   #74
xcflyn
xcflyn's Avatar
Oddometer: 1,152
Are those bars 1-1/8" ??? Gotta get a set for the wifes, but could not find for the stock bars (7/8) ??? Also wondered if you have a link to the bars you have on your bike ?
Thank you- and man that bar/guard set up really looks nice on that bike !
xcflyn is offline   Reply With Quote
Old 11-13-2011, 01:04 PM   #75
xcflyn
xcflyn's Avatar
Oddometer: 1,152
BTW- where is the actual XT250 thread any how. The xt225 thread is hugh and there are a few short threads for the XT250 ?
Times are GMT -7.   It's 11:24 AM.
