Old 06-08-2004, 09:08 PM   #1
PASSMORE OP
Just the last name...
PASSMORE's Avatar
Oddometer: 4,250
Mounted a F650 windshield to my 640 Adventure tonight
Hi all,
Finished my installation of the BMW F650 windshield on my KTM 640 Adv tonight. I will post photos as soon as I can get them posted. I mounted it "midway" for both functionality and aesthetics that are pleasing to my eye. I made no modifications to the shield for mounting such as trimming or bending. I may trim just a hair here and there. The bottom edge is against the fairing - this may not be favorable, but I will monitor it. Also, I get ever so little of a tap on my right hand guard at full turn (my bars are a touch tweaked on that side). Everything points to a reasonable modification in both price and installation.
Michael
PASSMORE is offline   Reply With Quote
Old 06-08-2004, 09:59 PM   #2
d0gWateR
Goat Stuntaz DSMC
d0gWateR's Avatar
Oddometer: 463
MiFoPa,
would like to see the pix, considering the same mod for longer runs.
Cheers!
You were born an original, don't die a copy.
Cambodia 2013 Blog
d0gWateR is offline   Reply With Quote
Old 06-16-2004, 07:43 PM   #3
PASSMORE OP
PASSMORE's Avatar
Oddometer: 4,250
Here are some photos... In hindsight I think I would have mounted it a hair higher, but overall I am very pleased with the performance.
Arch screwed with this post 06-20-2004 at 12:09 PM Reason: Fixed picture size.
Old 06-16-2004, 07:45 PM   #4
PASSMORE OP
PASSMORE's Avatar
Oddometer: 4,250
I used hex head bolts for a cleaner look - I believe they were 3/8's. For spacing I used skateboard "truks" bushings (Bones - medium density).
Arch screwed with this post 06-20-2004 at 12:10 PM Reason: Fixed picture size.
Old 06-16-2004, 08:31 PM   #5
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
Might have to get me one of those.
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack is offline   Reply With Quote
Old 06-16-2004, 08:32 PM   #6
Mack
Mack's Avatar
Oddometer: 3,797
Looks warm and comfy.
Old 06-17-2004, 01:29 PM   #7
Velocibiker
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
Almost looks like it belongs there .
I'm 6'5", so the OEM screen is practically useless. I'm mostly concerned with helmet buffeting. Usually results when a taller screen is attached that isn't designed to provide a full sized air pocket.
With the OEM screen, dirty air is hitting me at about an inch or so below my collar bones.
What's been your experience so far?
Velocibiker is offline   Reply With Quote
Old 06-19-2004, 08:53 PM   #8
twsiv
Oddometer: 106
so do you have a report for us yet? is there buffeting.
I'd like to do that myself, although one more thing to not clean. :-)
01 KTM 640 Adv
None of the other toys really matter on this site.
twsiv is offline   Reply With Quote
Old 06-21-2004, 02:18 PM   #9
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,243
"hair higher" ? measurements? any whistling at cruisin' speed? how much did your conversion cost ya (parts)? Is that the stock F650 windscreen or one of these fancy aftermarket types?
http://www.f650.info/fr/details_accessoires_bulles.html
looks nice for us stilts!
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle screwed with this post 06-21-2004 at 02:59 PM
meat popsicle is offline   Reply With Quote
Old 06-22-2004, 07:34 AM   #10
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,909
It sounds like you have a pretty good setup right now. A taller windscreen would move that turbulence upwards. I don't think we can get a tall enough windscreen to get behind, or at least I wouldn't want one that tall on my D/S bike.
I have the older, taller KTM Adventure windscreen, and at 6'3 and not so long waisted, I get buffeting. I am actually thinking about splashing a mold off my mask and trying a cut-down version, unless I find a mask off a wrecked '01-'03 to try.
You F-650 windscreen guys might want to try aluminum chainring bolts from a bike shop. Ricardo Kuhn recommended these a long time ago. Maybe a fat o-ring in between.
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Old 06-22-2004, 07:56 AM   #11
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,560
Cool2
The buffering effect is mostly caused by the vaccum effect behind the windscreen. I eliminated that effect by putting some 4.5-5.0 cm of space between the Dakar windscreen and the LC4 Adv windscreen.
It might not looks the best, but it works to eliminate the vaccum effect at high speed.
By adjusting the "tilt" of the F650GS Dakar windscreen with different length washers, you can easily find a windscreen position where you might be able to get rid of your buffering problem.. you might just need to drill bigger holes on your Adv windscreen to allow flexibility for mounting points.
Make sure you have plenty of supporting members for the mounting points of the GS Dakar windscreen, it will flex your Adv windcreeen at high speed.
Here's the original thread from over a year ago when I first put the GS Dakar windscreen on my LC4 Adv
http://www.advrider.com/forums/showthread.php?t=12728
Mankind is doomed & Physics do not lie
Chances favor the prepared mind.
Cat0020 screwed with this post 06-22-2004 at 09:08 AM
Cat0020 is offline   Reply With Quote
Old 06-22-2004, 08:03 AM   #12
Velocibiker
Oddometer: 1,164
Yup. That's why sport bike screens always have a vent cut out at the base. Ya might tinker with different sized spacers to change the angle of the screen too. That can also make a huge difference.
Times are GMT -7.   It's 09:58 PM.
