Old 03-07-2009, 02:52 AM   #1
Balsta OP
Oddometer: 400
Are the NGK CR8EIX any better?
Anyone with experience on the NGK Iridium spark plugs, CR8EIX?
Lifelength?
Better engine performance? - hard to believe as long as the std CR8EK is in good shape
http://www.ngksparkplugs.com/product.../iridiumix.asp
Balsta is offline   Reply With Quote
Old 03-07-2009, 05:15 AM   #2
PABiker
Anywhere but here
Oddometer: 3,825
I'll let you know, I have 3 sitting on the bench right now. 2 for the 950 and one for the DRZ. Just haven't got off my ass to put them in yet.
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 03-07-2009, 06:24 AM   #3
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
i noticed that the bike runs really smooth for 2 or 3 hundred miles after new plugs. I thought it was the iridiums at first. Too bad the front plug isnt as ez to change as the rear
MookieBlaylock is offline   Reply With Quote
Old 03-07-2009, 07:14 AM   #4
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,862
I put one in my 640 Adv, and it noticeably started better, idled smoother, and accepted throttle better at low rpm. Above 2000-2500 rpm I couldn't tell a difference.
I put them in my 950SE and didn't notice a difference. I'll use them again anyway, because they really should be a better plug, and when you're changing them every 10k miles, the cost difference is negligible.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 03-07-2009, 10:49 AM   #5
firebolter
Oddometer: 606
I run that plug in my Husky SM610. Works good, no major noticeable difference I can tell.
2014 F800GSA
2007 KTM 525 EXC
2013 Berg TE300
2006 Husky SM610+71 BSA 250 Trials
2011 Beta 300 2T Lim Ed+ 74 RL250 Suzi
firebolter is offline   Reply With Quote
Old 12-16-2011, 01:43 PM   #6
Zander
Zander's Avatar
Oddometer: 194
I currently run NGK CR8EK on my 950.
I'm currently performing winter maintenance and was wondering if it is worth it to go to Iridium NGK CR8EIX ?
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Old 12-16-2011, 01:52 PM   #7
David P.
David P.'s Avatar
Oddometer: 356
Lifelength?
Bilke will run a lot smoother and it will start a lot easier so very noticeable difference!
KTM 525 - 2007, Raid Designs MRS Ed.
www.RaidDesigns.com
David P. is offline   Reply With Quote
Old 12-16-2011, 03:48 PM   #8
AdvGa
AdvGa's Avatar
Oddometer: 1,320
...in addition, they have a Better Designed Core and last about 3X the normal plug.
...and you don't Gap them (they are pre-gapped in the Box)
AdvGa is offline   Reply With Quote
Old 12-16-2011, 06:46 PM   #9
Zander
Zander's Avatar
Oddometer: 194
Thanks for the feedback. I'll get some iridium plugs tomorrow.
Beginner's mind !
KTM 950
Old 12-16-2011, 06:53 PM   #10
Tangai
Oddometer: 573
I use them in mine, but I can't tell any difference at all. They are supposed to last a lot longer.
Tangai is offline   Reply With Quote
Old 12-16-2011, 08:55 PM   #11
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Post back at about 30k miles and let us know how they worked out...
Here are some more benefits:
Why NGK Iridium?
More Durability and a Higher Melting Point compared to Platinum,
better center electrode anti-oxidation and anti-erosion,
improved ignition,
superior anti-fouling,
lower required voltage,
new metal shell plating process for better anti-corrosion.
http://www.shopwiki.com/ngk-iridium-spark-plugs
http://bikeadvice.in/ngk-ir-iridium-...s-motorcycles/
A spark plug firing end temperature must be kept low enough to prevent pre-ignition, but high enough to prevent fouling. This is called “Thermal Performance”, and is determined by the heat range.
Plug Replacement Time: Unfortunately, there is no fixed answer to this. As spark plugs grow older, they lose their sharp edges as material from the centre and ground electrodes are slowly eroded away. As the gap between these two points grows, the voltage required to bridge the gap increases proportionately. Even the best ignition systems will be strained to supply enough voltage to completely burn the fuel.
Old 12-16-2011, 09:06 PM   #12
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,773
I put iridiums in my 950 2,500 miles ago and I definitely notice a difference starting and on the low to mid-range. It's worth the money in my book.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 12-17-2011, 01:31 AM   #13
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,884
I used them and did not see any difference.
My mechanic said they have a thinner point so more prone to damage, due to high motor temperatures. I now use NGK CR8EK.
Old 12-17-2011, 12:30 PM   #14
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,161
I didn't see/feel any difference either
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 12-17-2011, 01:24 PM   #15
V-rider
Oddometer: 161
Sorry, your mechanic is wrong.
In an attempt to slow the spread of misinformation...
I think your mechanic may be confusing two different possible issues. "Damage" and durability are two different things.
A precious metal (platinum or iridium), fine electrode spark plug design was created to be more durable under high temperatures than the common nickel plug design. That's one major reason why they are made! Auto and powersport manufacturers prefer to use this design if their bean-counters will let them.
If someone has "high motor temperatures" then they have more to worry about than the firing end design (or material) of their spark plugs.
If your cylinder temperatures are too high then your spark plug firing end temperature could also be too high. It doesn't matter which design of plug you have in there - regular or fine electrode - both will be damaged if you experience pre-ignition (not to be confused with knock). (By the way, the term "detonation" is sometimes used interchangeably with knock, but knock is the more correct term. Knock is different from the phenomena called pre-ignition.) Your engine will most likely suffer severe damage if you experience pre-ignition.
The firing end ceramic insulator shape is what mainly determines the heat range of the spark plug. The heat range is the most important factor to consider when replacing your plugs. Just don't install a heat range hotter than what is recommended - you will risk pre-ignition.
The metal electrode shape or material really has nothing to do with the heat range - but the precious metal, fine electrode design will last longer.
Along with durability, the fine electrode design also provides better ignitability.
Most engine designs will respond favorably to a plug with better ignitability. If you don't notice a difference using your five senses - then probably only a gas analyzer will show the improvement. If that is the case, and you don't care how long it is between your plug replacement intervals, then don't bother spending the extra money.
I run NGK iridium plugs. I get them cheap because I am a Test Engineer for NGK (not bragging - just throwing that out there to lend credibility to my words.)
OK. Nuff said. Thanks for reading.
V-rider is offline   Reply With Quote
Times are GMT -7.   It's 02:16 PM.
