Old 03-08-2009, 05:29 PM   #1
Krautbikeman OP
Failed Anger Mgt #$%@#$%^
Krautbikeman's Avatar
Oddometer: 5,502
ProTaper handlebars on 93 GSPD
Due to mine being bent, I'm going to replace my stock GS bars with some Pro Tapers. What fitment issues do I need to be thinking about, particularly since mine has heated handgrips?
What I want is to be able to fulfill my basic obligations to my family, help out those I can, and never fuck anybody for a handful of silver. If I can laugh while doing so, and ride, and explore, I will consider myself blessed beyond what I deserve.
Jinx
Want to ride better? Basic/Experienced street and Dirt Bike classes. www.adventureridertraining.com
Krautbikeman is offline   Reply With Quote
Old 03-08-2009, 10:05 PM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,871
Normal GS bars are 7/8, or what ever the mm equivalent is.. Keep that in mind. You'll also need to drill a hole in the center middle of the bars if you plan on keeping the stock heating.
Are they the same rise? Just make all the cables can move properly. I dont think you'll need longer ones.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 03-09-2009, 07:12 AM   #3
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
pro taper atv hi bars are nearly an identical bend to the stock bars. you will have to grind off the powerdercoat or widen the controls as 7/8 = 22.0025 mm.
bmwblake is offline   Reply With Quote
Old 03-09-2009, 09:22 AM   #4
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,606
what's the advantage of protaper and other aluminum handlebars anyways?
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-09-2009, 10:40 AM   #5
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
cheaper and easier to find than the stock ones that i bent.
Old 03-09-2009, 11:03 AM   #6
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
Bling factor.
T.
Infracaninophile is offline   Reply With Quote
Old 03-09-2009, 11:39 AM   #7
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
perhaps if you get some sort of cool risers and the fat bars. i just bought a replacement for the bent stockers at less than half the cost.
Originally Posted by Infracaninophile
Bling factor.
T.
Old 03-09-2009, 11:50 AM   #8
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,871
I like the Carmichael SE's. Not as big a rise, and less sweep. Feels more like a dirt bike. About 60-80 bucks.
Found another pic:
PS... I had no grip issues when using Hotgrips, (aftermarket)
Stagehand screwed with this post 03-09-2009 at 04:22 PM
Old 03-09-2009, 12:36 PM   #9
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
Careful in running heated grip wires... make sure to drill a hole large enough that you can get a dremmel bit into to knock off all the sharp edges and avoid cutting the wire...
Also, the alu bars soak up the heat from the grips much faster than the steel, I've heard you need to wrap the left side with tape or foil to get the grip hot...
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 03-09-2009, 04:06 PM   #10
soyanarchisto
soyanarchisto's Avatar
Oddometer: 3,579
Thats the case with stock bars as well--at least on my aftermarket grips.
soyanarchisto is offline   Reply With Quote
Times are GMT -7.   It's 11:25 PM.
