Old 03-09-2009, 07:00 PM   #1
High Plains Drifter OP
High Plains Drifter's Avatar
Oddometer: 263
KLR250 VS Super Sherpa?
Yes, I did do some searching so please forgive my laziness. I currently own a nicely farkled 2000 KLR 650 and am considering dropping down to a smaller bike. For the all knowing, what are the differences between the KLR250 and the Super Sherpa? Any potential traders out there?
High Plains Drifter is offline   Reply With Quote
Old 03-09-2009, 07:25 PM   #2
1994klr250
1994klr250's Avatar
Oddometer: 678
I've been riding my 94 klr250 for almost 2 years now. Its a great little bike, kick start only, decent range with between 170 to 190 miles on a tank. It has a 6 speed gear box, so 55 mph is in my opinion a great cruising speed. Anything above 65 or so it gets a little buzzy. My bike always starts on the first or second kick, even in the winter. Sherpa is E-start. The klr250 is water cooled vs sherpa air cooled. The klr250 has 11.1 compression ratio vs 9.3 for the sherpa, I believe the klr is a little bit more peppy. I've ran mine up to the 9,500 rpm many times and it pulls just fine from 6k to 9.5k. I've never riden a super sherpa so I can't say much about it other than what i've read.
1994klr250 is offline   Reply With Quote
Old 03-09-2009, 07:30 PM   #3
Outwardbound
Oddometer: 696
I have the KLR250. I love the thing ! You are best to keep it below 60mph or it'll be wound out; but sprints up to 75 are possible. My guess is that it's heavier than the Sherpa (given its water cooling), so in pure off-road use the Sherpa 'prolly better. I MUCH prefer the 250 over the 650 when offroad. The 650 is so heavy; you must be a really good rider to use it's full capability. I don't think you can go wrong with either; and I strongly suspect the KLR would cost way less than the a Shepa of the same age.
There's a KLR250 thread here in Thumpers somewhere...haven't seen it for a while.
Just buy one and run the bejesus out've it. You'll like it.
Outwardbound is offline   Reply With Quote
Old 03-09-2009, 09:07 PM   #4
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,894
Outwardbound is correct that the Sherpa is lighter. At 312-314 lbs. with a full tank, the KLR is one of the heaviest dual sport 250s ever sold. Still more than a hundred pounds lighter than a KLR650, however.
Valve adjustments a little trickier on the Sherpa, requiring shim replacement.
montesa_vr is offline   Reply With Quote
Old 03-09-2009, 09:14 PM   #5
Echo1
Oddometer: 278
I've owned both bikes. The KLR250 weighs more at 312 lbs with a full tank vs 282 lbs for the Sherpa with a full tank. The KLR250 has a rear drum brake vs the Sherpa rear disc. The KLR250 has screw adjust valves and the Sherpa shim adjust. The KLR250 has analog speedo, tach, & temp gauges vs LCD digital speedo, odo, clock, and dual trip meters on the Sherpa. I'm 6ft 180lbs and both bikes are comfortable to ride but the Sherpa is smaller. Both bikes averaged a little over 70 mpg and the KLR250 tank holds 2.9 gals vs the Sherpa 2.4 gals. Performance wise the Sherpa has more low end torque and the KLR250 has a better top end. The Sherpa also runs much better at higher altitude where the KLR250 probably would have benefitted from a jetting change. Both bikes are really good but in my case the better low end torque of the Sherpa makes it a lot nicer to ride in terrain where the KLR250 might require clutch action to keep the revs up to prevent bogging down. So right now I'm pretty happy to have the Sherpa and a KLR650.
Echo1 is offline   Reply With Quote
Old 03-09-2009, 11:37 PM   #6
fixer
KLR-riding cheap bastard
fixer's Avatar
Oddometer: 7,439
the siamesed valves on the 250 are kinda fiddly.
i've never been into the valves on a Sherpa, but swapping shims just means buying shims... nothing "tricky" about that. just gotta have the parts.
Sit tall in the saddle, Hold your head up high
Keep your eyes fixed where the trail meets the sky
And live like you ain't afraid to die
And don't be scared, just enjoy your ride.
"... in my version of Heaven you get all your dogs back." Mista Vern
"Old dogs don't die, they just wait for you in another place." Twilight Error
I'll show you a place, high on a desert plain, where the streets have no name.
fixer is offline   Reply With Quote
Old 03-09-2009, 11:39 PM   #7
fixer
fixer's Avatar
Oddometer: 7,439
Originally Posted by High Plains Drifter
...what are the differences between the KLR250 and the Super Sherpa?
KLR 250 is kick only. Sherpa has the magic button and a stainless exhaust.
Old 03-10-2009, 01:40 AM   #8
Beezer
Oddometer: 5,836
The Sherpa is a sweet little bike & will do 65 for long periods no problem. I got one for my wife, but I like riding it and it packs along on the camper.... better than a spare tire! Great bike, it's a blast. I'm 6' & 230.
Beezer is offline   Reply With Quote
Old 03-11-2009, 08:52 AM   #9
radguzzi
The Journey is the Reward
radguzzi's Avatar
Oddometer: 5,761
This is good timing, I am thinking about a KLR 250 that a Buddy has near here. I past on it last year as I had not yet sold the XR 400R, still haven't actually but that is another story...
I kinda - sorta thought I wanted t trade the XR for a CRF 230 but that did not work out and I keep thinking about the KLR...
I don't know if I want to looking for a Sherpa but I may poke around CR just to do it, the E button would be nice... The KLR 250 is very reasonably priced.
Good info here,
Thanks Guys...
Rob
________________________
Guzzis and Others...
Member: AMA - USCRA - MGNOC
radguzzi is offline   Reply With Quote
Old 03-11-2009, 10:59 AM   #10
solohvs
somewhere around the bend
solohvs's Avatar
Oddometer: 182
Back From The Dealer
I've had a trials bike for several years and have decided to "update" my equipment. The Super Sherpa is not unlike the early trials bike in the sitting and standing position and the feel in general. The disc brakes and the stainless exhaust are a big plus and the cross over tires will be better than the trials tires we've all been riding since enduro days.
I'm 5'8" and 170 pounds. Just back from the dealer and I didn't grab up the Super Sherpa I went in for. Some of the other BIGGER displacement bikes were on sale and I could ride home on a 400 or 650 for about the same price as the KL250 Super Sherpa - which is MSRP at $4499 + $400 destination charge.
Will someone please tell me that the little sherpa is just as good if not better than some of the big bikes. It weighs in at about 300 lbs so I can tuck on on the back of my truck and NOT pull a trailer. Less weight means it will be just a nimble off road as my old Honda TLR 200 from 1986.
Bigger is not always better? Will I be happy with the Sherpa?
Thanks. Brian.
solohvs is offline   Reply With Quote
Old 03-11-2009, 05:00 PM   #11
montesa_vr
montesa_vr's Avatar
Oddometer: 1,894
You can buy a nice little reliable Japanese dual sport with crappy suspension like the Sherpa or for a little more money you can buy a great big monster Queen Mary reliable Japanese dual sport with crappy suspension. If your ego is measured in cubic centimeters, you'll have to buy the Queen Mary and then you can tell us all how much you love riding it in tough single track to justify your decision. Or you can buy a 250 and actually have fun riding off road.
I would rather ride a Sherpa on the freeway than a DR650 off road. I think the XL650 and DR650 are not just too heavy, they're way too heavy. To me the 650 class bikes are two in-between to be useful, unless all you want is cheap transportation. My brother sold his DR650 and bought a used BMW GS1100. He figured if he couldn't have any fun off road anyway, he might as well be comfortable on the highway.
Old 03-11-2009, 05:41 PM   #12
coastie124
Oddometer: 52
Was at the dealer a couple days ago checking out the two new klx-250 one with the super moto package. They also had the new sherpa's. Sweet bike. The price wasn't too bad but I think if I were going to pike either a klx-250 and the new sherpa I would go with the sherpa. Neither would be my first pick in a dual sport bike. I think for the money I would buy a used bike of better quality.
08 KLR650 Malvern, AR
coastie124 is offline   Reply With Quote
Old 03-11-2009, 06:09 PM   #13
johnlt
Oddometer: 592
With nearly a foot of suspension travel and ground clearence, the KLX 250 is far superior to either the KLR250 or Sherpa for off road but at the expense of a tiny tank and a high seat height.
Johnlt
2009 BMW R1200 GS Adventure
2000 Suzuki DR200
1975 BMW R75/6
Yamaha WR250R
johnlt is offline   Reply With Quote
Old 03-11-2009, 07:13 PM   #14
solohvs
solohvs's Avatar
Oddometer: 182
Choice
I have the cash to buy new and this will be project for me. I've had way more time around an enduro/trials bike than my current road bike - Honda VFR800. For a while there the 250 seemed like the gold standard for off road travel and I guess that still holds true for trials bikes.
I'm not the Queen Mary type and the Super Sherpa has a loyal following.
A nice little bike would be a BLAST off road and I'm hoping the six speed transmission will keep me going on the road. I guess they make all that extra hardware and crash bars because the giant dual purpose boats crash so hard so often when taken off road. Born to be mild - I'm a gentle off road type.
The Super Sherpa might just be fine for me.
Old 03-12-2009, 09:53 AM   #15
Voidrider
Oddometer: 992
I've been hankering after a Sherpa for the past few years...so I keep doing research and wondering what else is out that that would fit MY riding needs.
While I really like the suspension advances in the KLX bikes, I don't think I need a bike quite so dirt oriented. They also feel tall for me (yes, they could be lowered, but when the KLR 250 and Sherpa are fine out of the box...).
I keep coming back to wanting the Sherpa.
Usually I see a LOT more KLR 250s on Craigslist than Sherpas...so I started wondering if maybe I should consider one of them. I've sat on them both, and I have to say that I felt that the Sherpa was a bit more comfortable.
From what I can tell, the price difference between Sherpas and KLR 250s, for the same year, seems to be pretty much negligible. This might be a regional thing though.
Voidrider is offline   Reply With Quote
Times are GMT -7.   It's 06:44 PM.
