Old 03-30-2009, 10:52 PM   #166
mcgiggle
Oddometer: 272
Hi Jim,
It's the standard Dakar screen, I've removed all the clocks and headlight, going to cut out all the not needed metalwork from the OE clock/headlight tree and mount the screen as shown, with two 80mm flush fitting projector style lights one above the other.
Pete
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 03-31-2009, 06:24 AM   #167
mothra
Rally Driver
mothra's Avatar
Oddometer: 681
Originally Posted by underwaterguru
As hard as I looked I could not find a sealed battery that will fit in the spot. Any help?
This is the sealed battery I have in my dakar. It is a direct fit replacement.
http://www.bmwsantacruz.com/Merchant...oduct_Count=24
Matt Smith
www.fireantracing.com
'02 F650GS Dakar (why do I continue to ride a 400lb bike like an enduro bike?)
Proud to be RIFF RAFF 2011
mothra is offline   Reply With Quote
Old 03-31-2009, 06:47 AM   #168
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,645
They seem to be the only ones with that battery, I ordered one two weeks ago today, and was told it's held up in port by Homeland Security.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 03-31-2009, 07:14 AM   #169
jdaniele
jdaniele's Avatar
Oddometer: 944
Deka ETX-15l works and is cheap check ebay for some deals.
You toss the foam at the bottom of the tray spit on the sides and squeeze it in. Tight but fits.
All winter with no tender and starts right up.
JD (K2ADV)
"These pretzels are makin me thirsty"
I can't seem to remember why I don't drink anymore.
jdaniele is offline   Reply With Quote
Old 03-31-2009, 09:37 AM   #170
underwaterguru OP
Moto shop Adventurer
underwaterguru's Avatar
Oddometer: 76
cross to yuasa
I crossed the Deka ETX-15l to a yuasa ytx 14ahl bs. Will have to order one and see if it fits. Thanks for the help
Keep the Rev's up!!!!
underwaterguru is offline   Reply With Quote
Old 04-01-2009, 12:02 AM   #171
mcgiggle
Oddometer: 272
OK guys, before I throw this f&%"!ng Uni Filter out of the window can someone shed some light on it ?
The rubber outer is the same thickness as the OE but not as soft so when I try to put it all together the air box/snorkel/battery box joint won't fit, when I try harder and give it a good push it just falls out of the groove.
Cheers
Pete
Old 04-01-2009, 02:00 AM   #172
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 915
Cheers
Pete
Had the same trouble with mine . The rubber frame kept pushing inside the snorkel housing & leaving air gaps . Ended up going back to the standard paper element .
Brute is offline   Reply With Quote
Old 04-01-2009, 02:50 AM   #173
mcgiggle
Oddometer: 272
Brute, mines ok in that department, it's that the rubber is to thick ! Tried again to fit it but the only way I can see is removing 40% of the rubber and I have no idea how to do that so open to ideas.
Pete
Old 04-01-2009, 03:08 AM   #174
tmotten
tmotten's Avatar
Oddometer: 2,282
I had to grind some of that rubber off with a dremel. Good excuse to get a Dremel. Worthwhile though.
tmotten is offline   Reply With Quote
Old 04-01-2009, 09:48 PM   #175
hetman
Oddometer: 110
I have the Yuasa YTX14AHL-BS installed also.
hetman is offline   Reply With Quote
Old 04-02-2009, 10:33 AM   #176
mcgiggle
Oddometer: 272
Rallye foot rests
Spent an hour with a mate this afternoon and came up with these........
Cost, a can of San Miguel each.
Old 04-02-2009, 10:54 AM   #177
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: Hey, I can see my colon from here...............
Oddometer: 6,396
2 cans of San Miguel? I would've added a shot of Tres Generaciones as well
notmybikemodelname is offline   Reply With Quote
Old 04-02-2009, 05:48 PM   #178
TheCowboy
back in the saddle again
TheCowboy's Avatar
Oddometer: 590
Ok, first oil change on my wife's 650... there are two drain plugs on the bottom of the engine.. which one, or both? the center one has the magnetic plug and only drained out about 1/2 pint oil. Don't want to remove the other one till somebody say's yep, do that one too.
BTW, where's the oil filter? The parts guy gave me one that looks like the one on my F800GS... can't find one like that on the 650.
owners manual is useless on oil changes
Cowboy2
TheCowboy is offline   Reply With Quote
Old 04-02-2009, 06:03 PM   #179
JDLuke
JDLuke's Avatar
Oddometer: 8,645
Cowboy2
Full step by step directions are available at F650.com.
The short story: Only pull the magnetic plug. On the right side of the engine, remove the sprocket cover, which allows you to get at and remove all three of the screws holding on the round, roughly 2.5 or 3 inch diameter oil filter cover. Oil will pour out, I use a soda can I've cut to catch the stuff and funnel it away from the engine and into the catch pan.
You also need to remove the left side fairing to drain the oil tank. I generally do this bit first.
Old 04-02-2009, 07:14 PM   #180
TheCowboy
TheCowboy's Avatar
Oddometer: 590
www.f650.com got it... yep, everything I ever wanted to know.
Thanks again...
Cowboy2
Times are GMT -7.   It's 01:02 AM.
