Old 05-24-2010, 10:38 AM   #2356
khpossum
poster
Oddometer: 383
Originally Posted by HowlingMad
Not sure exactly, but it appears that there is a bracket possibly only one screw. (I'll look at mine later today). I think it's hard to answer your question without a picture, which is probably difficult in your situation, but it sounds like if you can stop if from rattling and inspect at each fuel stop, you might be ok for a while. At least until you can reach an area where you could provide some pictures.
Thanks HowlingMad. Looking at the parts fiche it is definately the carbon cannister. There is not much to see of this thing as installed. Just a piece of the top and the two hoses and that is it. Regular inspections are a bit of a problem because of all the luggage for this trip, but I will have a look at it tomorrow again to see if my Touratech caliber Turkish garbage bag, so carefully shoved in the hole is still there. Do you have any idea what is involed in getting the fuel tank out of the hole?
KP
khpossum is offline   Reply With Quote
Old 05-24-2010, 01:15 PM   #2357
MTBXR
MTBXR's Avatar
Oddometer: 46
Lower Chain roller
Just checking because I am getting mixed responses. I was checking/cleaning my chain the other day and notice for the first time that the lower chain roller was absent. I don't know when it left or if even it was ever on there. Assuming it should have one I order one, but then to find out my model (06 GS) never had one to begin with. So, yes or no - does this bike need a lower chain roller?
thanks
Looks like meat back on the menu boys!
MTBXR is offline   Reply With Quote
Old 05-24-2010, 02:09 PM   #2358
rmarkr
Squatter
rmarkr's Avatar
Oddometer: 349
thanks
The GS did not come with the lower roller; I believe the Dakar did. If you extend the rear travel you will probably need to fit one (to a GS)
rmarkr is offline   Reply With Quote
Old 05-24-2010, 02:14 PM   #2359
MTBXR
MTBXR's Avatar
Oddometer: 46
Thanks, that's $70 I saved.
Old 05-24-2010, 06:31 PM   #2360
sonicapollo
Adventure Addict
sonicapollo's Avatar
Oddometer: 175
Turn Signal
Busted a front signal on my 03'. I had intended to replace them anyway. Anyone have any good recommendation for an offroad (read flexible and maybe small) signal set I should look into? Probably replace just the front 2... but may be tempted to do them all at once.
Anyone who says the TT set will be shot and eaten.
sonicapollo is offline   Reply With Quote
Old 05-24-2010, 07:37 PM   #2361
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,350
You could try these....
http://www.cyclegear.com/spgm.cfm?L1...BD14-U0279-5_G
Personally I went to flush mount LEDs which you can also find at Cyclegear.com
Remember it's literally a slippery slope when you ride these bikes off-road. Streetbike hardware with a GS teaser logo... next thing you know you'll be taking off the "possum scraper"
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 05-24-2010, 09:55 PM   #2362
rob feature
Domain Ranger
rob feature's Avatar
Oddometer: 3,302
Zeta handguard bolt-ons. I have a set on my DRZ. Not only are they super bright, but they really clean up the front end. No more blinkers to snap off
Mine came blank...no decals.
Awesome little pieces. Got mine from Wheeling Cycle
Only pic I have of my set
rob feature is offline   Reply With Quote
Old 05-24-2010, 10:12 PM   #2363
rob feature
Domain Ranger
Oddometer: 3,302
Originally Posted by rygroh
Oops, you guys are right. I wired the switch so it interrupts the signal sent from the front abs sensor. The dashlight flashes and I can drop my bike as much as I want and each time I start it the abs stays off.
Does it kill the whole ABS system or just the front?
Old 05-25-2010, 03:19 AM   #2364
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,645
I'm about 99.8% certain that in the event of an ABS fault (which is what this mod simulates) the entire system is disabled.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 05-25-2010, 06:24 AM   #2365
rygroh
Noobs UNITE
rygroh's Avatar
Oddometer: 61
Yea, it turns the whole thing off.
ha!
rygroh is offline   Reply With Quote
Old 05-25-2010, 06:50 AM   #2366
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,322
KP
Do you mean removing the fuel tank or the charcoal canister? Either way, I'm hoping others in here can help since I've never removed either. I can't even get a decent picture of the canister, so it looks like at least a two beer project.
I know there are more knowledgeable people in here, so hopefully they can help chime in. If not, you could try the Chain Gang or the HUBB.
Good luck.
Touratech Turkish Garbage Bracket. Sounds redundant.
HowlingMad is offline   Reply With Quote
Old 05-25-2010, 06:58 AM   #2367
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,322
That's great, I've been looking for a solution to this problem (tried different switches, etc). Could you share a little more details about where you intercepted the sensor? I assume where the cable terminates since the sheath is fairly well protected.
Old 05-25-2010, 09:19 AM   #2368
khpossum
poster
Oddometer: 383
carbon canister loose, in Turkey need some help
In order to get the carbon cannister out I need to remove the fuel tank, and for which I need to remove what? Seems like the whole subframe has to come off. Chaingang gave me zero response.
That thing droppoed waayyy down:
To the point it sat on the engine, so I shoved it back up and propped it up with a garbage back from the bottom:
BTW, greetings from Turkey, full ride report at
http://www.advrider.com/forums/showthread.php?t=568261
Old 05-25-2010, 09:42 AM   #2369
rob feature
Domain Ranger
Oddometer: 3,302
Cool! New mod in the works then. That's been the most annoying thing about this bike.
Thanks for the info!
Old 05-25-2010, 11:07 AM   #2370
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,350
RC Mads Rockin' Dogbones...
So RC Mad had these made up and I never ponied up in time... so he was kind enough to send me a .dwg file which I emailed to my friend with a CNC machine and long story short.
Raised the bike one angry inch" Overall ground clearance is 13" and seat is now 37" since I'm a tall guy I needed to do this a long time ago. With the forks dropped down to the max in the triple and the suspension unwound a bit, the bike takes whoops 100% better than before. REALLY FUN.
This was just a rough one-off for testing, so I plan to make the arm thickness just a bit smaller since my allen head shock bolt was scraping.
So thanks to John. I'm going to have some more made up and just figure to compensate my friend and pay for the metal if anyone is interested I will find out how much he needs. You can PM me.
Jim
Times are GMT -7.   It's 12:56 AM.
