Old 06-16-2010, 12:51 PM   #2551
john_aero
john_aero's Avatar
Oddometer: 1,173
Originally Posted by cdo1uk
cant get on there. im not paid up.... :-(
well the forks and top clamp what i have that be of any use to you.
make offer.
but hey get a bike 1st and then see what you need to do
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 06-16-2010, 01:12 PM   #2552
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,276
Originally Posted by JDLuke
Well, you COULD do that... But I wouldn't really recommend it. Not when you can do this instead. Oh, yes I almost forgot: The Dakar comes with a 21" front wheel, and the 650GS a 19". You might want to swap that as well.
You also forgot that the Dakar comes with a bigger set of balls as well.
notmybikemodelname is offline   Reply With Quote
Old 06-16-2010, 01:26 PM   #2553
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,368
+They're actually the heaviest part of the bike, but never remove them to save weight!
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 06-16-2010, 02:16 PM   #2554
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Well, I guess that's why some of us didn't need to buy a Dakar in the first place.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 06-16-2010, 03:43 PM   #2555
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
I hear ya. I didn't need to, I chose to
Old 06-18-2010, 12:20 PM   #2556
rmarkr
Squatter
rmarkr's Avatar
Oddometer: 401
Follow up to post # 2519 - ABS warning lamp wiring
Firstly - I got the lamp to work!!.......and there was no puff of smoke.......and nothing got hot or buzzed.
I connected this transistor. It was bought almost at random out of an array of transistors (I know fuck all about them)
I connected the 'base' to the line from the ABS controller,
the 'collector' to earth
the 'emiiter' to the lamp
The polarity of the line from the ABS controller is -ve.
We'll see if it works over the long haul, but I suspect that a resistor is required somewhere in the circuit.
rmarkr is offline   Reply With Quote
Old 06-18-2010, 03:19 PM   #2557
andyhb
andyhb's Avatar
Oddometer: 73
Fork springs
Just checking on opinions regarding Wilbers v Touratech fork springs, and differences (if there are any) Looking at a spring and oil upgrade to 10w.
Gas Gas 280 Factory Racing
andyhb is offline   Reply With Quote
Old 06-18-2010, 10:15 PM   #2558
Philmeup
Philmeup's Avatar
Oddometer: 102
Thanks guys for your suggestions re my fork seal
got a better idea now on what to do.
Philmeup is offline   Reply With Quote
Old 06-19-2010, 02:34 AM   #2559
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,011
Burn !
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 06-19-2010, 11:19 PM   #2560
khpossum
poster
Oddometer: 477
Problem while traveling thru Uzbekistan, burned wiring harness
Long shot, very long shot, but here we go. I am on my 2007 Dakar in Uzbekistan. The plan was to travel to Mongolia and back. Yesterday afternoon I burned up a substantial portion of my wiring harness. My own damn fault, details later, internet time is short. I have exposed the burned portion, above the right hand top engine support bolt, between 2 and 8 inches from the relay panel. Not too much is actually burned up, but it has turned into one molten mess. I am going to try to sort it out, but it does not look very good, chances are very slim. Does anybody have or know of a scrapped Dakar with a wiring harness I can buy?
Also, my own dealer is closed on Mondays. Which of the "parts over the internet" BMW dealers is open on Mondays. I may have to order a new harness.
Is the USA Dakar wiring harness diferent from the European wiring harness? I know sopme of the devices are different, but not sure of the wiring?
Any other suggestions for fixing this mess?
Any help is appreciated.
KP
khpossum is offline   Reply With Quote
Old 06-20-2010, 12:58 AM   #2561
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,472
Keep it simple. It doesn't need to be a neat fix at this stage. Leave that till you get back. If it would be me, I'd cut out the section of the loom and replace it wire by wire with new wires. That would have to be less work than replace the whole loom. I've done a lot of electrical work so am comfortable with a soldering iron, but that was not always so. If you're not, you can use crimp terminals. Anything that will close the circuit, is water proof and stays together under constant vibrations will do.
I'm assuming that you've untaped everything and can identify the different colours. AND have clear access. Sounds like you would have to (if you haven't already done so) strip it down to like you would have to do the valve check.
Mongolia will most likely be the highlight of your trip, so anything that will make that happen will be good.
tmotten is offline   Reply With Quote
Old 06-20-2010, 01:40 AM   #2562
Gravel Seeker
Thomas
Oddometer: 4,011
+1
Think I'd try to replace the melted wires first before replacing the entire harness.
You know of this site ofcourse - Enter your BMW Serial Number (last 7 digits of your VIN) and it'll give you the part numbers (and prices): http://www.realoem.com/bmw/select.do...0061200&arch=0
As far as I can tell they didn't make a USA Dakar after 2006
I just checked the first harness listed for both bikes and they seem to be the same. Your VIN will tell you which part you need.
(Prod code 0186)Dakar 12/2006 USA (w/ ABS part no. 61117680405): http://www.realoem.com/bmw/partgrp.d...69&hg=61&fg=05
(Prod code 0176) Dakar 01/2007 Europe (w/ ABS part no. 61117680405): http://www.realoem.com/bmw/partgrp.d...68&hg=61&fg=05
Good luck !
Gravel Seekers.com
Hey !
Old 06-20-2010, 03:14 AM   #2563
Gravel Seeker
Thomas
Oddometer: 4,011
I've posted this in the Rotax tuning thread, but as I've no idea which threads people are reading I'll chuck it up here aswell.
I have K&N filter and a Staintune and I've never really considered it 'till now, but which FI helpers are out there ? Which ones work alright and which ones only look alright ? What do they do and id there are any downsides ?
I had my bike on the Dyno after fitting the K&N and Staintune and got 38,6 hp on the wheel - 49,3 NM torque. I later discovered (a year or so later that the throttle cable was in the wrong notch, but I've no idea if it was in the correct notch during the Dyno test (replaced the headgasket in the meantime)
f650.com: http://faq.f650.com/GSFAQs/DynoRunsFAQGS.htm
I've found this. Techlusion FI-1031 (which I think is the same as the "Fuel nanny" ?), but are there any other magic boxes out there ? It seems there are little gain in power, but it runs better/ cleaner ?
Gravel Seekers.com
Hey !
Old 06-20-2010, 05:17 AM   #2564
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,041
I made my own... Got bosch connecters online and the rest at Radio Shack. Works great and is adjustable depending on how much fuel you need to add to compensate for various intake/exhaust mods.
_________________________
2006 BMW R1200GS
2010 KTM 690 ENDURO R
1969 BSA STARFIRE
wswartzwel is offline   Reply With Quote
Old 06-20-2010, 06:02 AM   #2565
khpossum
poster
Oddometer: 477
prob lem in uzbek with wiring harness
Gravelseeker and TMotten, thanks for your respo0nse. I am tryingh to stay positive, but it is hard, it is such a mess and in such an obnoxious place. there must be 40 or 50 wires of different sizes melted together or with burned insulation. I can solder pretty good. I will need shrink tube,, not sure if I can find that here. prob will have to remove the harness form that area to get acess.
I will have to get the relay panel probably removed to have any chance to get to all the cable ends. Is the cable harness connected to it with connectors or is it solidly connected?
Other question, what are the odds that shorting some of the computer sensor wires fried the computer? how sensitive is that thing? any expereince there?
KP
khpossum screwed with this post 06-20-2010 at 06:21 AM
Times are GMT -7.   It's 05:19 AM.
