Old 06-26-2010, 02:14 PM   #2656
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,369
Originally Posted by Lion BR
2006 Dakar in action.
Great vid. What kind of helmet cam? Beautiful country too.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 06-26-2010, 03:19 PM   #2657
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,261
Thanks.
The camera is a GoPro Hero HD.
Lion
Here is another one:
Lion BR is offline   Reply With Quote
Old 06-27-2010, 12:58 AM   #2658
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,049
Thanks.
Lion
Funny, I'm just looking at that (literally, have their page open in another tab)
Are you happy with it ?
Is this information correct ?
Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included).
GoPro's obsession with sound has conquered the wind. At 85 mph on a motorcycle, you’ll enjoy the throaty sound of your motor, not the wind. Inside even the quietest street cars, hear the pull of your motor...not the drone of the wind and road.
Included is a 1100mAh rechargeable lithium-ion battery that lasts for up to 2.5 hours of constant recording. With optional accessories, you can also plug the camera into a wall outlet, cigarette lighter, or with any USB-compatible power adapter, wire it directly to your vehicle’s electrical system. The battery will charge while you record.
Battery life ? Can the rechargeable battery be replaced by standard batteries in a pinch ?
How many hours of recording on your memory card at highest quality ? (What size card are you using)
They have a tripod mount
Which I guess will work on the camera ram mount I've bought earlier
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 06-27-2010, 01:05 AM   #2659
Gravel Seeker
Thomas
Oddometer: 4,049
Steep. Suspension fully compressed...
I don't see that.... the rear suspension
But you are correct, sir, going uphill.
Here's going down before coming back up
Can you tell I miss my little adventure ?
Gravel Seekers.com
Hey !
Old 06-27-2010, 06:07 AM   #2660
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,052
What kind of exhaust do you have? Bike sounds good in the video.
Thanks.
Lion
2002 BMW R1100S/ 2006 BMW R1200GS
2010 KTM 690 ENDURO R/ 1969 BSA STARFIRE
wswartzwel is offline   Reply With Quote
Old 06-27-2010, 07:19 AM   #2661
Lion BR
Lion BR's Avatar
Oddometer: 4,261
Battery life: I would say the information is correct. To have more hours of operation you can either by a 12V-to-USB plug and charge the battery at night. Or bring with you extra batteries. Replacement batteries cost from $15 to $20 in the US.
And the amount of video in a card depends on the resolution you are recording. I record on 960p at 30fpm (second highest definition) and it does perhaps 90 minutes of video on an 8GB card. 90 minutes is a lot of footage. I never recorded on the highest definition, except on testing it and I did not like the results (it is the same setting as 960p/30fpm - with a wide screen format). If I remember correctly, I needed more light and less travel speed to capture good flkowing images at that setting.
GoPro recommends using Class IV SD cars (it is about the speed of recording, I guess). I'm not an expert on these matters. So I simply followed the instructions.
The downsides:
1. You can't see what you are filming (I don't know if other cameras allow you to see that either).
2. You can't see how much space you have left on your card (but you can see how many clips you filmed)
3. It is not very fluid-dynamic. With this thing on your helmet, at speeds of +65mph, together with a visor'ed helmet, your neck with have to work hard to keep your head attached to the rest of the body.
About mounting it: if you mount it on the bike itself, your results may not be as good as on the helmet. The vibrations will either distort the image and you will get less quality.
Lion
Old 06-27-2010, 07:21 AM   #2662
Lion BR
Lion BR's Avatar
Oddometer: 4,261
Original exhaust. Take a look at the taco when you hear the good sound. This bike comes to life above 5k rpm. At idle and lower rpms, it sounds like a sewing machine. And performs as such. But at > 5k rpm...
Old 06-27-2010, 08:45 AM   #2663
Gravel Seeker
Thomas
Oddometer: 4,049
The downsides:
Lion
Gravel Seekers.com
Hey !
Old 06-27-2010, 07:04 PM   #2664
Lion BR
Lion BR's Avatar
Oddometer: 4,261
You are welcome.
Old 06-28-2010, 08:41 PM   #2665
livit
Oddometer: 69
Originally Posted by tmotten
Dunno about the radiator, but try F650.com as well.
As for the oil pipe. Might as well cut it at the banjo, take it to a hydraulic pipe fitting place and get them to silver solder half inch barb onto it. Than a half inch oil hose and you'll be fine. AND you can now change the water pump in 30 minutes.
Thanks for your help, found an answer to my question and I will be modifying oil pipe in the near future.
The best advice I've ever had...
"Never take a laxative and a sleeping tablet on the same night".
livit is offline   Reply With Quote
Old 06-29-2010, 10:23 AM   #2666
Gravel Seeker
Thomas
Oddometer: 4,049
So, anyone have any ideas about new compression after shaving 25/100s mm (0,25 mm) off the cylinder head ?
The volume in "the top" has obviously decreased, but is it enough to get too high compression ?
Are there any things I can do if compression is too high ?
Higher octane ?
Fuel additives ?
Alternative sparkplug ?
Anyone ? Buehler ?
Gravel Seekers.com
Hey !
Old 06-29-2010, 12:49 PM   #2667
jonkem
Got let out early
Oddometer: 172
Surely the volume you are compressing is less as well as the space you are compressing it into? Sort of balances itself out?
Isn't there a "serviceable limit" for skimming the head published in the workshop manual?
jonkem is offline   Reply With Quote
Old 06-29-2010, 12:55 PM   #2668
WU7X
The Old Fart
WU7X's Avatar
Oddometer: 2,111
Head gasket
This may be a dumb answer, but can't you just fabricate a thicker head gasket to make up the difference? Guess I would have to know why you shaved the head in the first place....
Be patient, I'm an Old Fart
"Seika" - 2013 DL650 + DMC M72D Sidecar
"Gracie" - 1983 R100RT 60th Anniversary Edition
"Dusty" 2011 Adventurized 4Runner
Adventure is worthwhile." ~ Aristotle
Airhead #14449
WU7X is offline   Reply With Quote
Old 06-29-2010, 02:12 PM   #2669
rmarkr
Squatter
rmarkr's Avatar
Oddometer: 407
Easy - drill a 2.5mm hole in the piston crown - its sure to reduce compression!
rmarkr is offline   Reply With Quote
Old 06-29-2010, 02:14 PM   #2670
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,369
Times are GMT -7.   It's 10:39 PM.
