Old 07-26-2010, 11:05 PM   #2941
bthebert
Oddometer: 203
Originally Posted by chonkoman
Thanks for all your suggestions. I broke everything down again and found out the gasket grease that was recommended to me by advance auto parts turned my gaskets into mush, thus the pouring out of my coolant from the weep holes. I will order some new seals and use no grease next time and hope for better luck. Hard to go another week without riding!
I'm sorry, but this makes no sense at all.
If the SIDE COVER gasket got "turned to mush", you would leak OIL, not coolant.
There is no "gasket" under the water pump (impeller) cover. Just an O-ring.
There is only ONE "weep hole".
Something's fishy here.
- Bill
2005 F650GS Dakar
1995 DR350SE
2008 WR250R
Coast to Coast x 2
bthebert is offline   Reply With Quote
Old 07-27-2010, 02:10 PM   #2942
WU7X
The Old Fart
WU7X's Avatar
Oddometer: 1,986
MYBLUETT, pm sent
Let's talk!
"Seika" - 2013 DL650 + DMC M72D Sidecar
"Gracie" - 1983 R100RT 60th Anniversary Edition
"Dusty" 2011 Adventurized 4Runner
Adventure is worthwhile." ~ Aristotle
Airhead #14449
WU7X is offline   Reply With Quote
Old 07-27-2010, 02:57 PM   #2943
smokin998
Rides Water Buffalo
Oddometer: 38
Is the stock kick stand on a BMW F650GS burly enough to support the weight of the rider while climbing on the bike? I've seen a few guys doing this and was wondering if someone has intimate knowledge ????
Jamie
smokin998 is offline   Reply With Quote
Old 07-27-2010, 03:33 PM   #2944
john_aero
john_aero's Avatar
Oddometer: 1,159
Originally Posted by MYBLUETT
i had the pivot pegz on the dak and thought very highly of them before switching to the TT set that came with the relocation kit.
(still have the pivots if you are interested)
2nd dibs if her is not interested
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 07-27-2010, 03:48 PM   #2945
john_aero
john_aero's Avatar
Oddometer: 1,159
one more thing
anyone know where i can get thoes 2 small parts that fit onto or into the bolts underneatht he round covers on the rear panels. they are used for hooking bungee straps too
i had linkfor them but cant find it now
Old 07-27-2010, 07:55 PM   #2946
TwilightZone
Oddometer: 2,956
>"Is the stock kick stand on a BMW F650GS burly enough to support the weight of the rider while climbing on the bike?"
I mounted the Dakar that way for a year, with no failures. (note that the kick stand has a 1" pad on the bottom).
I've lost 75 lbs and can climb on now. :>)
TwilightZone is offline   Reply With Quote
Old 07-27-2010, 08:39 PM   #2947
smokin998
Rides Water Buffalo
Oddometer: 38
Thanks. It's a bit of a task climbing on with a full load when you've got stubby legs. I kinda have to take a run at it and hope for the best.
Jamie
Old 07-27-2010, 08:54 PM   #2948
skipro3
skipro3's Avatar
Oddometer: 120
I have a 2" spacer on my kick stand. I mount it from the high side, the throttle side. When I put my weight on that peg, the bike is naturally unweighted off the kick stand. Gotta be quick or it will come all the way over, but I like it better than putting all my weight on the stand plus the bike's weight. I learned this from a CHP motorman BTW... Since this lesson, every CHP bike rider I see gets on and off their motorcycle on the high/throttle side.
skipro3 is offline   Reply With Quote
Old 07-28-2010, 07:57 AM   #2949
Number8teen
Uncompetent
Number8teen's Avatar
Oddometer: 11,227
Hey all...
I've got an 07 Dakar and I was wondering if anyone's had strictly electrical surging/shorting type problems with the bike before. Probably really not the best word to describe it, and a search for surging on this thread brings up the single spark engine surging/stalling issues.
My bike runs just fine, but on a long trip back home this weekend I noticed the spedo/tach drop down to zero and kick back into place a couple of times. Then I noticed that my odometer had, uh, sort of reset itself. Maybe the bike wanted to increase its own value, but unfortunately it doesn't understand the existence of titles. Although if I could catch up to the original amount I guess that'd work... only 34k to go.
I also had the reserve light kick on once that I noticed, for a few seconds, then turn off when I had well over half a tank left. When this happens, the bike continues running fine. Starts up fine, too. Signals/brake lights seem alright. Oh and when the tach/spedo thing happens, the clock resets itself.
If this type of issue's been discussed here before, just let me know that I should go back to diggin' it up. Otherwise, any ideas? Hope my bike's brains aren't going bad, but given counters resetting and all...
weeee
Number8teen is offline   Reply With Quote
Old 07-28-2010, 08:05 AM   #2950
WU7X
The Old Fart
WU7X's Avatar
Oddometer: 1,986
Check your battery lugs
It sounds electrical all right...check to make sure your battery lugs are tight. Don't ask me how i know that can be a problem. Then work up from there. Check all electrical connections. KISS problem solving.
Nice to see you at WestFest! Nanc and I were going to say "hello" (Nanc is originally from Cumberland, WI), but you were having too much fun to be bugged by us old farts.
Airhead #14449
Old 07-28-2010, 08:06 AM   #2951
Gumbeaux
The Chameleon
Gumbeaux's Avatar
Oddometer: 797
Originally Posted by Number8teen
Hey all...
I used to have an 06 F650GS and I had the tach going crazy once. At suggestion of others, I checked my battery connection, found it a little loose. Tightened it down and no problem afterwards...
Others suggested the water caused it...
Dunno about the odo reset...never heard of that before.
Gumbeaux
Gumbeaux is offline   Reply With Quote
Old 07-28-2010, 08:11 AM   #2952
Number8teen
Uncompetent
Oddometer: 11,227
Thanks, I'll do that! I hope that it's something as simple as the battery connections. And you shoulda come and said hi! I wouldn't have been able to say much back without my voice, but I sure managed to talk a lot anyway. Always good to meet fellow midwesterners. Hope you two had fun! Makin' the central rally?
weeee
Old 07-28-2010, 08:14 AM   #2953
Number8teen
Uncompetent
Oddometer: 11,227
Water from rain or...?
Seems like battery lugs are the popular culprit and the easiest thing to check so I'll do that after work tonight. And yeah, the odo reset is what has me most worried that the problem might be a little more serious, but I'll just hope for the best.
weeee
Old 07-28-2010, 08:21 AM   #2954
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
If that doesn't take care of things, the next thing to check is the electrical box right behind the steering head. Water can work its way into the relay contacts and make strange things happen. I like to spray contact cleaner inside that box now and then.
My bike had weird troubles with the console for a long time until I figured that out. A dealership even replaced the console under warranty once, which didn't actually help things.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 07-28-2010, 08:25 AM   #2955
JDLuke
JDLuke's Avatar
Oddometer: 8,644
Originally Posted by john_aero
one more thing
Those are part of the stock luggage mounting system. BMW part #71607653836, US $37.50 each MSRP.
JDLuke screwed with this post 07-28-2010 at 11:28 AM
Times are GMT -7.   It's 06:43 AM.
