Old 04-28-2012, 08:54 AM   #8056
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 862
Originally Posted by Gravel Seeker View Post
Touratech IMO computer and LED strip on extremely home made alu plate that works like a son of a bitch !
That looks good Thomas. That is what I am working on now also. Ditching it all. Just indicators and a GPS on a dash.
Matto
mattomoto is offline   Reply With Quote
Old 04-28-2012, 09:08 AM   #8057
kubiak
Oddometer: 4,236
Originally Posted by GSBS View Post
Yup... still on the original. Always used the non-synthetic 20W50 BMW-brand oil, changed at 5K-mile intervals. Clutch has never slipped.
I have no idea if the BMW oil is any better than other brands, but for the couple of bucks extra every 5,000 miles I've always used it as it hasn't let me down yet.
thats great! i guess i shouldnt worry too much about mine going out soon with 24,000 miles. it was slipping a little in high gear at 17,000 miles when flogging the clutch hard when i got it but the guy was running synthetic oil, i been running regular motorcycle 10-40 oilfor the last 7,000 miles now and it works great. thanks!
Old 04-28-2012, 03:04 PM   #8058
Kainic
Almost there
Kainic's Avatar
Oddometer: 308
Looking to put some money down on a pair of Happy Trail Owyhee Panniers. Can't decide on the 6" or the 7.5" wide ones. Do the 7.5s make the rear too big?
Kainic is offline   Reply With Quote
Old 04-29-2012, 12:20 AM   #8059
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,433
Yeah, thanks. Many, many years since I did mine in now. Post pics of your sollution. I have more pics if you need them.
Think I replaced the stock dash with a TT rally bracket after just one year. After that the leap to this was short and easy. Really was simply a result of putting the Cyclopse headlight on and having to figure something out since the TT rally bracket was towering 10-15 cm up in the air which wasn't all that pretty
I've gotten hold of some pieces of alu now that is powdercoated black. I'll either buy som Hella rally light and try to fab something up or just reuse the Cyclopse lamps and perhaps add one of those Trailtech highbeam spots. Also since "daytrime running LED" or whatever it's called is now andatory on all new cars sold in the EU and EEC they are readily available from any car accessory shop, so I'm thinking of trying one out. Just wish I had a garage to work in where weather and darkness didn't play a factor and I could just leave everything half done for the week it would take to get the job done. Instead I'm stuck outside on the lawn with highs of 12C and lows of 2C at the moment
Wonder if I can put the original dash back on and have the odo read 7000km ..... or is the info stored elsewhere
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 04-29-2012, 01:58 AM   #8060
tmotten
tmotten's Avatar
Oddometer: 2,284
Had anyone had to relocate the starter/ load relief relay? I've got to but but am out of ideas on where to put it. Maybe someone found an alternative one similar to standard relays in build. The factory one has non insulated terminals which is why it's in the middle of nowhere on a plastic bracket in a rubber boot.
tmotten screwed with this post 04-29-2012 at 02:13 AM
tmotten is offline   Reply With Quote
Old 04-29-2012, 08:01 AM   #8061
redbastard
redbastard's Avatar
Oddometer: 1,041
The 7.5 are just the right size
Here's a picture of the HT 7.5's on my wifes bike next to my old KTM.
My buddy put them on his V-strom as well, and they worked well. Any smaller and you'll be hard pressed to get anything in them.
redbastard is offline   Reply With Quote
Old 04-29-2012, 08:03 AM   #8062
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 862
Right on Thomas. Here is what I am working on. Made a cardboard cut out for the dash and now will cut some alum for it. I too use the cyclops lights but put them on a bracket I made that bolts to the stock subframe. I put all my indicators in homemade bracket also similar to your TT one. I may pop for the TT one however as mine may not be too weather proof. I will paint the Ermax windscreen all black also when all done. Need to fab a sheild in front of the lights also. Some plexiglass for that I think.
Bonus with the stock subframe is I bent the the two mounts on top with the bolts welded to them so they can be used with some bushings to bolt the windscreen to the subframe as well as the sides making it more secure.
Whatever headlight sheild I come up with will bolt on to that tap hanging down from the middle of the subframe that way the upper windscreen can come off to gain access to stuff under the dash. Trying to make things very modular so not to have to remove tons of stuff to do simple work. Making the sheild today.
Matto
Old 04-29-2012, 10:49 AM   #8063
isgila
isgila's Avatar
Oddometer: 104
Fuel reserve light
Good day inmates,
light is not working. Went f650.com and tested as recommended.
swap bulbs, jump the connector. all was good. finally decided to take out the pump for inspection.
Wires are all good. how do i check if the floater device is not stuck. i saw no moving parts..
Apprecite the help
isgila is offline   Reply With Quote
Old 04-30-2012, 02:23 AM   #8064
Gravel Seeker
Thomas
Oddometer: 3,433
Neat. (Got any up close pics of the bracket you made for the lights. Might wanna copy that)
Dunno if you misunderstood, but the TT piece I have is the rally dash plate (the one for roadbook holder and IMO computer). I don't have the Rally "tower" bracket piece that is used to hold up the proper Dakar rally dash... make sense ?
Here's a couple of pics from way back when
What I've found is that I really hate the taller screen and want something like this again (here yo can see how the dash/ IMO is towering up too)
Want to re-reoute the light circuit to where I can run the lights independently of the ignition
  1. Off
  2. Off, but brakelight works
  3. On, just halo and brake light
  4. On, halo, tale and brakelight
  5. On, halo, low beam, tale- and brake light
  6. On, halo, high beam, tale- and brake light
So I went on eBay and found this one that I'm 90% decided on at the moment. Why re-invent the wheel when it's gonna look home made at best and cost about the same in the end.... so I'm mentally designing the dash as we speak. Needs room for IMO and GPS. This one's nice enough to work and weird enough to be cool and stand out
Gravel Seekers.com
Hey !
Old 05-01-2012, 08:09 PM   #8065
redbastard
redbastard's Avatar
Oddometer: 1,041
New exhaust
So I fitted my new exhaust on the bike yesterday. It is a nice looking exhaust, much quieter than the Remus muffler I had on there, still has a really nice rasp to it. The bad news I think my bike just gained about 4 lbs. I'm not sure but I think this has a catalitic converter in it.
redbastard screwed with this post 05-01-2012 at 08:57 PM
Old 05-02-2012, 04:00 AM   #8066
isgila
isgila's Avatar
Oddometer: 104
Ermax screen
Can anybody help me to check if frog specialist is still in business. email them a few time but no response.
Or can anybody help me to get hold of one and ship it to singapore. pls Pm me.
Thanks.
Old 05-02-2012, 04:06 AM   #8067
Dirt Rover
Dirt Rover's Avatar
Oddometer: 34
+1 on the 7.5's. That's what I have on mine. Even with the 7.5's I find myself wishing they were a little wider. Heck, a 30 pack of beer can't fit in them unless you unload them from the box.
F650GS Dakar
Ninja 650R
KTM 300 EXC
...foolish consistency is the hobgoblin of the mind. (Ralph Waldo Emerson)
Dirt Rover is offline   Reply With Quote
Old 05-02-2012, 07:11 AM   #8068
kubiak
Oddometer: 4,236
nice looking exhaust, yea it could have a converter on it, it looks like the front section might be one.
Old 05-02-2012, 10:45 AM   #8069
Parx400
Oddometer: 1,066
You need an FMF Titanium Q4. Its is so damn light.
Parx400 is offline   Reply With Quote
Old 05-02-2012, 07:36 PM   #8070
redbastard
redbastard's Avatar
Oddometer: 1,041
Mmmmm titanium :)
Too late, money is spent :) I weighed the Remus, it was 7lbs, the new Sebring wiith Cat is 11lbs. I think I can handle the extra 4lbs as it looks so purdy and sound fantastic.
Times are GMT -7.   It's 02:37 PM.
