Old 08-25-2009, 03:19 AM   #796
Fizz
Fizz
Fizz's Avatar
Oddometer: 168
Hex screw at bottom of 2004 Dakar fork leg
I 'accidently' undid this screw when I was changing my fork oil and reversing progressive springs (so tightly wound coils up, rather than down) , and then it wouldnt screw back up tight, it just kept turning!!!
When I sat on the bike and pushed down on the forks, I got my wife to tighten it up which it would then do.
Is this safe?
Thanx in advance
Fizz
Fizz is offline   Reply With Quote
Old 08-25-2009, 03:52 AM   #797
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Is this safe?
Thanx in advance
Fizz
So long as it torqued up properly, it's safe.
That fastener should be torqued to 20 Nm, or just a hair under 15 ft lbs.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 08-25-2009, 04:18 AM   #798
Fizz
Fizz
Fizz's Avatar
Oddometer: 168
Old 08-25-2009, 06:09 AM   #799
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,354
Is this safe?
Thanx in advance
Fizz
Just did my fork seals yesterday. I've learned to hate those damn bolts.
You may want to keep an eye on those seals since they use a crush washer that is supposed to be changed each time. I doubt they would leak but it would suck to find it later.
HowlingMad is offline   Reply With Quote
Old 08-25-2009, 09:11 AM   #800
Capt. REDBEARD
TWECO
Capt. REDBEARD's Avatar
Oddometer: 1,128
Cheers
Thanks - I am glad someone saw my petition for information......... I put in 10 more lbs. (now at 35 lbs.) last week and I noticed a little less road noise and the bike seemed to handle a little better. Plus I felt more comfortable with some more air in them - get them closer to Conti specs.
Originally Posted by herrhelmet
TKC 80s
Guess your post got buried.... I run mine at 32- -35 lbs. At 25 lbs you will dent your front rim if you hit a rock. Heavier bikes need a bit more air pressure.
Great all around tires.
I've gone with Dunlop D 606s lately for more bite off-road.
Capt. REDBEARD is offline   Reply With Quote
Old 08-25-2009, 11:30 AM   #801
sjeproductions
sjeproductions's Avatar
Oddometer: 271
What year is your Dakar
Originally Posted by hetman
I installed this IMS folding shift lever and it fit (picked a 2004 XR250R):
http://www.motorcycle-superstore.com...ift-Lever.aspx
And I've heard of people using this Moose one instead:
I like the looks of the IMS folding lever and i was wondering what year dakar you put it on? I have a 2001, not sure if that spec was ever changed.
sjeproductions is offline   Reply With Quote
Old 08-26-2009, 02:39 AM   #802
Fizz
Fizz
Fizz's Avatar
Oddometer: 168
Whats 35lbs in PSI?
Are you putting the same pressure in front and back tires?
Regards
Fizz
Old 08-26-2009, 04:01 AM   #803
john_aero
john_aero's Avatar
Oddometer: 1,173
Whats 35lbs in PSI?
Regards
Fizz
I will ask her good self, she knows all about PRESSURE
it is .24 PSI
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 08-26-2009, 04:51 AM   #804
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,369
it is .24 PSI
35 lbs in USA usually means 35 lbs/square inch in our lame non-metric way
herrhelmet is offline   Reply With Quote
Old 08-26-2009, 07:24 AM   #805
Capt. REDBEARD
TWECO
Oddometer: 1,128
what the helmet said.......
exactly -
and yes I am running the front same as the rear (35psi)............
Old 08-26-2009, 09:03 AM   #806
-N8-
Ride like you stole it!!
-N8-'s Avatar
Oddometer: 125
question for the Dakar group -
Anyone retrofitted the black plastic upper mudguard extension from say a '03 to a '06 Dakar beak? The beaks are different but wondering how difficult it is to make it work and does it look good?
2006 BMW F650GS Dakar
The More moving parts...the safer I feel!!
-N8- is offline   Reply With Quote
Old 08-26-2009, 05:59 PM   #807
hetman
Oddometer: 133
Mine is a 2006.. I don't think it matters but not totally sure.
hetman is offline   Reply With Quote
Old 09-02-2009, 05:20 AM   #808
ssigs
Oddometer: 7
Vibration question...
Did you ever find out what was the reason or cause for the vibration? My Dakar vibrates more at the 3500-4500 range. And it vibrates more on the seat area and not as much on the pegs and handlebars.
Lion
Sorry for the slow reply. The rear shock has "had it" and I'm waiting on new Olhin to arrive, due sometime this month. Have changed the rear tire - new Scorpion to match the front the bike came with. Once shock fitted I'll post the result. Seems a bit smoother or I'm getting more used to it - haven't ridden my wifes GS for a while so nothing to compare with. Have found any cure? Cheers
ssigs is offline   Reply With Quote
Old 09-02-2009, 09:19 AM   #809
tomatoe333
tomatoe333's Avatar
Oddometer: 2,296
One thing to check is the bolts that attach the front "engine shell" (the piece that goes in front of the engine between the frame below the steering head and the lower subframe). On my bike, those bolts were loose. I was getting quite a bit of vibration, and some noises while going over bumps. Torqued the bolts to spec, no more noises.
tomatoe333 is offline   Reply With Quote
Old 09-02-2009, 10:21 AM   #810
Rich-in-GA
Oddometer: 52
Dakar vs regular 650.
Curious how the Dakar compares to the regular F650GS in off-road conditions. How much more ground clearance do you get on the Dakar? Are there any other differences other than suspension? (When did BMW stop making the Dakar model? '06?).
Rich-in-GA is offline   Reply With Quote
Times are GMT -7.   It's 04:12 PM.
