05-04-2012, 03:05 PM
#8086 |
Oddometer: 2,282
It's a bit odd that they provide torque specs for fittings with crush washers. Regardless of the torque, if the washer isn't crushed, it's not right. That said, I do like following the torque settings.
05-04-2012, 03:09 PM
#8087 |
Motorhead!
Is there a cliff notes version of this thread somewhere?
Cole Ford<----my iPad app ...and iPhone version .....Android Tablet version06 KTM 950 Adventure(The Fainting Goat) ![]() 02 F650GS DAKAR ![]() 2 KLR650s Travel bikes http://coffeemotorcycleswine.blogspot.com/
05-04-2012, 03:23 PM
#8088 |
Oddometer: 13,716
In English, can someone describe for me the correct chain tension on an 04 Dakar? I am stupid and unsure if my measuring device even has mm. In inches, how much slack should it have, I assume on the side stand. Measuring from the inside of the chain pr outside Then tightening it, looks simple enough, any tricks? It sorta creeps me out there is no cotter pin holding the axle on. Maybe 20 bikes lifetime, never saw this before.
Thanks for any help. Great bike, handles like a dream. Never saw smoother shifting.
Don't be surprised. |
05-04-2012, 03:29 PM
#8089 |
Almost there
Oddometer: 305
Sorry I am kind of slow. Is it FG-6 or FG-8 or F109R for a 2006 Dakar.
Kainic screwed with this post 05-04-2012 at 04:38 PM |
05-04-2012, 07:20 PM
#8090 |
Oddometer: 2,282
I believe it's the fg6 looking through my emails.
05-04-2012, 07:38 PM
#8091 |
Oddometer: 4,141
on my dakar the oil changes are easier with a few mods i did. first off with the yz forks and aftermarket headlight i dont have to unbolt all that extra plastics. then on the oil filter i made a case saver so i dont have to take off the stock sprocket cover then i cut a slot in the stock skid plate so i get a socket right on it with out taking it off.i even had my shrouds cut so i can drain my oil tank without taking off the shrouds but i put stockers back on so thats about all i have to remove now.
05-04-2012, 10:15 PM
#8092 | |
Nurettin |
05-05-2012, 03:57 AM
#8093 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,390
Doesn't look like you cut any of the frame away ? That's really what I felt was in the way of mounting it on top instead of underneath.... might have another look at it.
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! Gravel Seeker screwed with this post 05-05-2012 at 04:07 AM |
05-05-2012, 04:00 AM
#8094 | |
Thomas
Oddometer: 3,390
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
05-05-2012, 04:07 AM
#8095 | |
Thomas
Oddometer: 3,390
05-05-2012, 04:15 AM
#8096 |
Thomas
Oddometer: 3,390
And it's still that one for the '00-'02 models right ?
05-05-2012, 04:32 AM
#8097 |
Goin' mobile
Oddometer: 55
I looked at the maxbmw parts list for this '01 Dakar. The Fiche says sump plug is a 24mmx2.
15 11 13 7 708 604 SCREW PLUG, MAGNETIC - M24X2 So I ordered the 24mm X 2 Fumoto: FG-6 FG-6: Engine Oil Drain Valve 24mm-2.0 $32.45 1 $32.45 Those shots of your bike on its side, I am at that point now. Today I think I am going to go get a small Dremel and grind the sides of that bolt to make them flat again. I ground a 23mm socket to remove the chamfer, tapped it on the sump plug and put my craftsman 1/2" drive breaker bar on it. Then I took my 6 Ton floor jack with a piece of wood on it under the bike to put upward pressure on the socket so it would not slip off. That soft alum just kept falling apart. Its really bad now. Really pissed because I leave for the TAT Friday.......
'00 BMW R1100S - 4 Sale! '01 BMW F650GS Dakar '06 Yamaha FJR1300A Yamaha 360(sold) Kaw H2 750(sold) Kaw KZ1000(sold) Ducati 900SS CR(sold) ....and the struggle for the legal tender.... |
05-05-2012, 07:01 AM
#8098 |
Oddometer: 13,716
All I could think about while I was changing it was "Well that's stupid, all they had to do was (xxxx)." It's as though they were mad at mechanics that day.
05-05-2012, 07:36 AM
#8099 |
Ride Far - Ride Fast
Oddometer: 4,781
I bought one of those cheap pumps that you attach to the end of a drill and it works great to empty the resevoir. No need to remove any bodywork.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS, 99 R1100S, 2002 R1150GS, 2005 F650 Dakar Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
05-05-2012, 07:46 AM
#8100 | |
Almost there
Oddometer: 305
