05-27-2012, 01:14 AM
#8281 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,390
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! Gravel Seeker screwed with this post 05-27-2012 at 01:32 AM |
05-27-2012, 01:22 AM
#8282 | |
Thomas
Oddometer: 3,390
When buddy's are 1st gear I'm alternating between 1st and pulling the clutch in. When they're in 2nd I'm going back and forth between 1st and 2nd. And there's no power to pop the front wheel over rock and pot holes. Have a 13/49 set my friends gave me for my birthday a few years ago mostly as a gag, but that combo really shows the potential of the bike. Also helps with a bit less saggy rear shock when trying to throw the bike around so it just doesn't sit down on you when you hi tthe throttle.
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
05-27-2012, 01:29 AM
#8283 | |
Thomas
Oddometer: 3,390
The real mind tickler though is the largest glass/ lamp which has a 25w bulb. Seller can't answer me if the refelctor can take larger (hotter) bulbs or not and he can't answer what the purpose of that lamp is either. It's not like it's the parking light since it's 25w, but I might put a 10w in there since parking light is mandatory over here. Don't know if the halo is considered a parking light or a Daytime running LED whcih is mandatory for at least all new cars sold in the EU or EEC.
05-27-2012, 01:32 AM
#8284 | |
Thomas
Oddometer: 3,390
05-27-2012, 05:30 AM
#8285 | |
Oddometer: 719
The added protection looks a bit agricultural, but looks like it did its job. Nice ![]()
Uniden UH076/78 Lockable Radio Mount |
05-27-2012, 07:45 AM
#8286 | |
Master of None
Oddometer: 5,050
Originally Posted by Javarilla Evolution, or, natural selection, has nothing to do with better. It merely weeds out what is no longer suitable for the given context. Originally Posted by Dragoon I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle. |
05-27-2012, 08:02 AM
#8287 |
KJ4WMZ
05-27-2012, 10:09 AM
#8288 |
Oddometer: 101
Chip/broken front sprocket cover mounting point
Need some metalurgy advice..
The top mounting point of my front sprocket cover chip/broke. What are my options? Can quick steel work? I cannot get JB weld here in singapore. Can the case be alu welded without splitting the case? Pls help.. |
05-27-2012, 10:16 AM
#8289 |
Dad and husband
Oddometer: 5,465
If you're just talking about the mount for the plastic cover, I'd just epoxy it back on (qwik steel, jb kwik, etc). Make sure you clean up the fracture before you put it back together. Get in there with a tooth brush and some good cleaner that wont leave a residue.
2007 Aprilia RXV 5.5 |
05-27-2012, 10:28 AM
#8290 | |
Oddometer: 101
05-27-2012, 11:54 AM
#8291 |
Oddometer: 20
New to my '02
Hey all...about a month and a half ago I picked up an '02 Dakar (42k miles, ohlin rear, stock bags, etc...) I've put ~1,500 miles on it now and am LOVING the bike. Do have a couple little things I'm working out I thought you guys might have a good recommendation on:
1) The horn switch & high-beam flasher both don't work. I tested the horn switch (on the bars) today and with the multimeter can see it open/close, can't test the high beam flasher in the same way as I can't get in there, but everything else on that control works (turn signals, high beam on/off) so I'm wondering if those two are wired together into the same "multi-function" switch in the box? Wondering if anyone knows. 2) on the far right hand side of the dash (off in that empty space) there's a LED there that's normally green with the bike on and running, but seems to be red when the ignition switch is on, but the bike is off, is that an alternator LED or something? 3) Sometimes (not all the time, but SOMEtimes) when I turn the ignition on the bike, the gauge cluster doesn't light up, no tach, no headlight, nothing. If I turn it off and back on enough after this it'll work normally, but it's just often enough to make me a little concerned with some of the long trips I plan to take. Would hate for an "occasional problem" to turn into a BIG problem. It doesn't seem to be related to the side-stand (can happen with SS up or down), but I'm wondering if maybe replacing the SS switch might be the 1st place to start? Figured maybe someone here had had the same issue, and might be able to give me a heads up. TIA |
05-27-2012, 11:58 AM
#8292 |
Oddometer: 20
![]() Finally getting around to posting the pic of my new bike...now that I'm asking for help with it LOL. That's it at the top of Soledad Mountain in San Diego on one of our RARE sunny days. |
05-27-2012, 02:33 PM
#8293 |
Omnipresent
Oddometer: 298
Fumoto quick valve
Installed a Fumoto Quick valve on my Dakar yesterday. Pretty easy to do as it was time for an oil change anyway.
Some things to note, the valve comes with a fibre crush washer, after installation my valve was weeping from one side. I believe it was due to the fibre washer being just slightly bigger than the recess where the old bolt and copper washer used to go. So, I took the empty oil containers that I had just used to fill the bike and used the Fumoto to drain back into them...pretty slick! I then took the valve out and replaced the fibre crush washer with an OEM copper one, I also put a bit of permatex thread sealer on the threads. Snugged the Fumoto back up, put my oil back in and went for a test ride...no more leaks. I was real careful not to over tighten when I put the valve back in with the copper crush washer, I went maybe an 1/8 of a turn past contact and that is as far as it really wanted to go...I didn't use much force as I was paranoid about stripping threads. Here are some photos [IMG] [/IMG][IMG] [/IMG]
Lady Astor: "Mr. Churchill, you're drunk!" Winston Churchill: "Yes, and you, Madam, are ugly. But tomorrow, I shall be sober." 72 Yamaha 350 street 07 650 Dakar, 2010 KTM 690 Duke |
05-27-2012, 03:28 PM
#8294 | |
Oddometer: 4,115
05-27-2012, 07:34 PM
#8295 | |
Omnipresent
Oddometer: 298
