Old 06-28-2012, 10:06 PM   #8551
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
Originally Posted by Don Coyote View Post
I recall reading that that was where the tube was supposed to be routed to, but i never traced it to double check. I have my swingarm off so i'll have a look when i get home...
I just looked and could only trace it up to around the shock reservoir/adjuster dial before it becomes hidden behind the seat/plastics. Not sure what else it might be besides the battery overflow, but seem to also remember that tube being clear at the battery...
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Old 06-28-2012, 10:16 PM   #8552
LoJack
LoJack's Avatar
Oddometer: 1,571
My battery overflow tube was black. Not sure about the routing, though that sounds about right. Pretty sure the airbox overflow is farther forward on mine.
LoJack is offline   Reply With Quote
Old 06-28-2012, 10:44 PM   #8553
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
Yeah, airbox overflow is a short tube, ends around the spark plug(s). It normally has some sort of valve on the end, but mine seems to have fallen off...
'06 F650GS Dakar
Old 06-29-2012, 01:57 AM   #8554
FinlandThumper
Has Cake/Eats it Too
FinlandThumper's Avatar
Oddometer: 7,479
Originally Posted by SpencerCompton View Post
It sounds like your speed sensor is cracked. It will get water in it when wet and not transmit properly. I've read somewhere before to try putting clear nail polish on it to seal it. or buy a new speed sensor, they aren't to much $$$
True. I got three seasons and thiry thousand kilometers out of a broken sensor by using a coating of superglue. Coil finally went tits up this spring and after my summer vacation ( doing other things unfortunately) I will replace it. According to max BMW they are about 85 bucks so it's worth trying the superglue/nail polish thing first.
FinlandThumper is offline   Reply With Quote
Old 06-29-2012, 02:53 AM   #8555
ferals5
865+652
ferals5's Avatar
Oddometer: 1,125
LED indicators
Originally Posted by tmotten View Post
Which one. I've got the zeta ones art the front and nothing. Standard ones at the rear from an auto shop and they are weak
Sorry about the delayed response.. can't find the packet. Not that it matters cause I can't recommend them, bright but they ingest water if I wash it or ride in the rain...
Has not stopped them working though.
ferals5 is offline   Reply With Quote
Old 06-29-2012, 05:55 AM   #8556
rdalland
Dharma Bun
rdalland's Avatar
Oddometer: 349
I think I am chasing a different issue right now. The ABS seems to cut out at low RPM's. If I keep the RPM's above 3k, everything seems to be fine. The rear sensor is bone dry. I have a new battery on order, the old one is in questionable condition and it was time to replace it anyway. When it arrives I will have a thorough look at all the connections and wiring for damage. I cleaned some rust from the front sensor ring, I don't know if that is an issue or not.
I bought some 5 minute epoxy to "seal" the sensor, but I like the idea of using superglue so I will probably do that today.
Enjoy today, tomorrow is not guaranteed.
rdalland is offline   Reply With Quote
Old 06-29-2012, 07:24 AM   #8557
Sparqq
Oddometer: 67
A photo of my F650GS Dakar in the current composition;
With WP48 USD, low fender, 19 inch wheel, custom wind screen, luggage rack, laser duo tech exaust and much other changes.
Sparqq is offline   Reply With Quote
Old 06-29-2012, 08:35 AM   #8558
Aquatic
Aquatic's Avatar
Oddometer: 1,587
Very nice squire!
Where did you aquire that front fender? (More pics please)
Aquatic is online now   Reply With Quote
Old 06-29-2012, 08:45 AM   #8559
LoJack
LoJack's Avatar
Oddometer: 1,571
Ditto on the fender. Those aren't the TT forks, right? Triples look different.
Great looking bike!
Old 06-29-2012, 09:32 AM   #8560
kubiak
Oddometer: 4,829
nice looking bike! got some good stuff on there!
Old 06-29-2012, 10:02 AM   #8561
Sparqq
Oddometer: 67
KTM forks and clamps, with a new steering pin:
ABS sensor mount;
Switches on a fatbar magura
Front view;
Angles view
I bought the fender from a guy in Holland, it is used on the BMW of Frans Verhoeven in the Dakar rallye.
Old 06-29-2012, 11:45 AM   #8562
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,980
Fuel overflow ? Mine overflows like a motherfucker when parked in the sun with a full tank
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 06-29-2012, 12:39 PM   #8563
LoJack
LoJack's Avatar
Oddometer: 1,571
If it's a 'Merican bike, fuel overflow goes to the charcoal canister on the lower left side of the tank. There is a port at the bottom of it where I think it ultimately vents. Not sure it that'd be it, then. Unless Parx is lucky enough to have a euro/TT tank
Old 06-29-2012, 12:49 PM   #8564
LoJack
LoJack's Avatar
Oddometer: 1,571
Do you like the handling, and is there any noticable loss in steering lock? Kinda a downside with USD forks, I think. If I didn't already have USD WP's, I'd want to put 50mm Extreme's on.
That's a killer looking fender.
Old 06-30-2012, 02:10 AM   #8565
Sparqq
Oddometer: 67
I'm not familiar with the term steering lock, so can you explain the question?
Times are GMT -7.   It's 02:46 PM.
