Old 07-09-2012, 11:56 PM   #8656
Sparqq
Oddometer: 67
Originally Posted by Damian_74 View Post
Hi Sparqq,
Where did you get this case saver from - best one that I have seen?
from Scheffelmeier
Sparqq is offline   Reply With Quote
Old 07-10-2012, 12:00 AM   #8657
Sparqq
Oddometer: 67
Originally Posted by Kainic View Post
Thanks for the pictures. Any chance those extension nuts bending after getting some air and landing?
I think you have good point, I did this trick because the bracket on the X machines is overpriced. On a regular bike there is maybe a small chance the regulator will hit something in a crash. But at my bike I have a crash bar, preload adjuster and shock reservoir what will be hit first;
Old 07-10-2012, 04:05 AM   #8658
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,932
New line...
Originally Posted by mathews42 View Post
I recently purchased a 2001 Dakar with out ABS brakes and added touratech risers. I love the feel of the positioning however my front brake recently failed. When i turn the forks all the way over to lock the bike in place it seems as if there is enough room. However just recently i came back home from the weekend and the front brake was not releasing. I imagine the brakes were pumped by a buddy that climbed on it. The brake line it self started to inflate like a balloon close to where it connects to the master cylinder, so i opened up the bleeder nut to relieve the pressure. The line continued to balloon and after one to many pumps the line split. Has this been the case with anyone else? Or is it because the line is most likely 11 years old that it failed. The touratech website says that longer cables are "not required" BMW opens tomorrow so hopefully they have a line in stock! Thanks for the help in advance fellas.
Jeff
I believe the risers were 30 MM thanks!
I doubt the risers were a factor; sounds like the brake line just failed if it ballooned. Never seen that actually.
Were I you I'd get a new braided stainless aftermarket brake line that's slightly longer (like 1-2"). These are available from several sources and will likely be cheaper than a BMW part. I think the one I got was made by Russell. Just make sure you get the right diameter and thread pitch for the caliper and master cylinder. When I did the forks conversion on my Dakar I went with the YZ front wheel and caliper/disc but kept the BMW master cylinder, which are different sizes. This meant I had to get a "universal" line with two adapters for the two sizes of tips for the banjo bolts. Was still only about $40-45. The BMW one (which would've been too short with the longer forks anyway) was more than $80.
Good luck!
GSBS is online now   Reply With Quote
Old 07-10-2012, 08:44 AM   #8659
mathews42
mathews42's Avatar
Oddometer: 336
Thanks for the info GSBS!
mathews42 is offline   Reply With Quote
Old 07-10-2012, 09:19 AM   #8660
Parx400
Oddometer: 1,745
I would be more worrined about the engine casting breaking. There is a bracket for mounting the RR there off a G650X.
Parx400 is offline   Reply With Quote
Old 07-10-2012, 10:53 AM   #8661
Sparqq
Oddometer: 67
Number of that part; 62167696798, 70 euros
Old 07-10-2012, 11:53 AM   #8662
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,276
Absolutely not. I've had mine this way for a few years now and have crashed, taken big jumps, ridden through thickets, done pretty much everything you shouldn't do. Mine are completely fine and intact. Before you rip the casting apart, the regulator itself will crack apart next to the bolts.
notmybikemodelname is offline   Reply With Quote
Old 07-10-2012, 12:52 PM   #8663
mathews42
mathews42's Avatar
Oddometer: 336
update
BMW wanted 82 dollars for thier Stock brake line and would of had to wait on shipping. They suggested i check out a local shop that specializes in brake lines. So I'm having a steel braid one made +2inch for 47 bucks!
Old 07-10-2012, 05:14 PM   #8664
Baams
n00bs FTW
Oddometer: 35
Question Chain kit
hey i'm changing chain kit, any brands i should/shouldn't go for?
Baams is offline   Reply With Quote
Old 07-10-2012, 05:29 PM   #8665
Sparqq
Oddometer: 67
I really like DID X ring chains
Old 07-10-2012, 05:51 PM   #8666
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,370
I bought an EK gold x-ring chain and two JP sprockets off Amazon for $119.
http://www.amazon.com/gp/product/B00...ls_o01_s00_i00
http://www.amazon.com/gp/product/B00...ls_o02_s01_i00
http://www.amazon.com/gp/product/B00...ls_o02_s00_i00
Or if you want a 15t CS.
http://www.amazon.com/gp/product/B00...ls_o01_s00_i01
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 07-10-2012, 05:59 PM   #8667
Parx400
Oddometer: 1,745
I went for the Gucci sprocket.
Old 07-11-2012, 12:16 AM   #8668
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,370
Doing my sprocket/chain change tomorrow and just wanted to reaffirm that there are no downsides to going with the 15T CS. Most of my riding is below 80mph and would like more grunt at lower rpms.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 07-11-2012, 03:01 AM   #8669
ferals5
865+652
ferals5's Avatar
Oddometer: 1,127
The easiest performance mod you can make slight increase in buzz at 60mph, slight increase in fuel consumption, huge increase in the bikes ride-ability
ferals5 is offline   Reply With Quote
Old 07-11-2012, 03:29 AM   #8670
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,370
Thanks for the info, how much more grunt does it deliver in the lower RPMs? Are 2nd gear power wheelies possible?
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Times are GMT -7.   It's 01:37 PM.
