Old 08-16-2012, 07:49 AM   #8941
Barnman
Barnman's Avatar
Oddometer: 203
Originally Posted by Parx400 View Post
The TT one has good side protection IF you move it up all the way. Mine sits flsh on the front frame but with the normal rear mounts its bent up a little. It needs something like this in the rear to move it up more.
Its the crankcase cover on the side that I mean? All the pictures I have seen show this quite exposed. Although I am not sure if it is an issue or not. Maybe the picture is a little deceptive as the cover and guard look almost flush, when maybe the guard is higher then the cover
Not sure I understand you Parx, Can it be mounted higher than this picture? I am guessing the exhaust on the opposite side is going to be the thing that sets the height
Barnman is offline   Reply With Quote
Old 08-16-2012, 07:52 AM   #8942
Barnman
Barnman's Avatar
Oddometer: 203
Originally Posted by michael1968 View Post
I made this about a year ago, it doesn't tick all your boxes but that's why your building it yourself! The black box on the front is removable, it's all made of Kevlar and some fiberglass to give it thickness, the box is just painted black cos the surface finish wan't great.
It's survived some prettry big hits.
That's a nice looking guard Michael, Sadly I don't have the fibreglass and kevlar skills so mine will be aluminium. I like the black, as it breaks the line and makes it look more slim line than the TT one - great job
Old 08-16-2012, 09:39 AM   #8943
kubiak
Oddometer: 4,829
nice setup gravel seeker!
Old 08-16-2012, 09:47 AM   #8944
Parx400
Oddometer: 1,735
The skid plate is wider than the crank case. The skid plate in the picture has spacers in place to keep it lower. This is because the from bolt on frame piece hangs low and touches it. You have to cut it off just bellow the bolts. Then you can move the skid plate up in the front and back until it touches to exhaust. When you do that the front is a little higher than the back and it puts a slight bend in the skid plate. You need to do something Like I showed in the picture before to rise the back. That will be my next project.
The TT skid plate also comes with different lower engine bars. These are much higher. I have debated ditching the engine bars as my kick stand does not mount there anymore.
Parx400 is offline   Reply With Quote
Old 08-16-2012, 09:51 AM   #8945
Parx400
Oddometer: 1,735
More pics of skid plate
Old 08-16-2012, 12:51 PM   #8946
kubiak
Oddometer: 4,829
thats one tough looking bike!
Old 08-16-2012, 03:20 PM   #8947
Sparqq
Oddometer: 67
ABS light
When converting to another dashboard I run into a problem with the ABS light. It turns out that the ABS signal light bulb is driven by the tacho/speedo unit. I put a small circuit on the connector that normally is connected to the tacho/speedo unit.
The circuit uses only 3 parts, resistor, diode and transistor. There will be a small current on the base of the transistor when the key is turned in the on position. When the ABS led should be off pin (10) is pulled down and there will be no current on the base anymore, when the ABS led should be on pin (10) is floating.
Sparqq screwed with this post 08-16-2012 at 03:41 PM
Sparqq is offline   Reply With Quote
Old 08-16-2012, 03:50 PM   #8948
LoJack
LoJack's Avatar
Oddometer: 1,572
Looks Great! Good work on the dash.
Who got inspiration from whom?
LoJack is offline   Reply With Quote
Old 08-16-2012, 04:41 PM   #8949
Barnman
Barnman's Avatar
Oddometer: 203
Thanks Parx, that makes more sense now
Old 08-16-2012, 08:41 PM   #8950
michael1968
michael1968's Avatar
Oddometer: 786
Thanks, I made mine out of composites beacuse I don't have the aluminium skills!
I still have the molds so if your aluminium one doesn't work out I know knock one out for you pretty cheap. Not sure on the differences on mounting on the later bikes.
michael1968 is online now   Reply With Quote
Old 08-17-2012, 12:47 AM   #8951
Baams
n00bs FTW
Oddometer: 35
Wp 48
Anybody know anything about using the WP 48 forks instead of YZ?
Baams is offline   Reply With Quote
Old 08-17-2012, 12:47 AM   #8952
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,980
What headlight is that ?
I think I asked Kubiak a while back having mixed up the bikes/ headlights, but it's this one I thought looks like it has a very good/ bright light.
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 08-17-2012, 12:53 AM   #8953
Gravel Seeker
Thomas
Oddometer: 3,980
Bah. Thanks.
Nah, never even crossed my mind. I think the BMW is to round in its shapes to resemble the Husky.
Gravel Seekers.com
Hey !
Old 08-17-2012, 12:57 AM   #8954
Gravel Seeker
Thomas
Oddometer: 3,980
http://www.f650gs.crossroadz.com.au/ForkUpgrades.html
Gravel Seekers.com
Hey !
Old 08-17-2012, 01:54 AM   #8955
Sparqq
Oddometer: 67
I put a WP48 in my Dakar, it will take some time and engineering but it is possible.
I made a new steering stern, to fit the BMW bearings and tensions system;
Milled the top plate to make some space for the tension system. Also made an adapter for the steeringlock;
Adjust the brake hose mountings;
Mounting of the front ABS sensor;
I made a new 17mm axle out of steel. I made two aluminium cylinders to make it possible to clamp the 17mm axle in the 24mm forks. It is important that the right cylinder can float when the axle is in place and not clamped yet to prevent "stick slip".
I still use the same BMW Brembo caliper, I used the mounting bracket of a KTM950 adventure.
Times are GMT -7.   It's 04:28 AM.
