Old 04-29-2013, 08:50 AM   #10531
WayneC1
Oddometer: 2,557
KG6BWS, Interesting, you saying you have a faulty injector ?, also interested in what RPM the surging shows up
WayneC1 is offline   Reply With Quote
Old 04-29-2013, 08:52 AM   #10532
Don Coyote
Don Coyote's Avatar
Oddometer: 1,311
What have y'all found successful for turn signal replacement? I bought some internet LED cheapies ($8 per) last year and they have me regretting switching from stock. Even though i bought 7 and installed them last year, they are all already used and i am missing parts. they are brittle and prone to come apart when bumped with a boot or hip.
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Old 04-29-2013, 09:38 AM   #10533
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,004
I don't have the name of mine, but I've been using them since 2006. They show some signs of wear (a little dust and water) and I would've loved to open them and wipe them clean, but don't dare in case I break them and can't get them back together. Pretty sure I payed around NOK 250 per pair back then which would be around USD 45 or $22,50 per turn signal. The stalk is flexible and the led's themselves are bright as hell. No way anyone can't see them. I'll try to get some close up pics so you can at least try to find them. Bought mine in a countryside MC shop, so pretty sure they are very universal and not at all hard to find.
Here's one, but I'll try to find something better
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 04-29-2013, 10:45 AM   #10534
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Dont know that I have a faulty injector. I read a service bulletin (think it might have been over in the F650 FAQ's) that said to cure the surging/stalling, update the firmware AND replace the injector. The injector recommended was from a 1200C but I dont have the part number handy. When I took the bike in to the dealer, they said no faults/errors showed and it had the most current firmware. When I checked the part numbers, mine still has the original injector, so the PO had it updated but never swapped injectors. Thats the only reason I want to replace it.
Once I get the injector changed, Ill try plugging the O2 sensor back in and see what it does. In the meantime, while not perfect, it runs much better than it did and doesnt stall at all. And at 57mpg average, quite acceptable on that score.
"But I swear, a woman's breast is the hardest rock that the Almighty ever made on this earth, and I can find no sign on it." Bear Claw Chris Lapp
Justin
01 F650GS Dakar
KG6BWS is offline   Reply With Quote
Old 04-29-2013, 10:48 AM   #10535
KG6BWS
KG6BWS's Avatar
Oddometer: 895
How did you get the LEDs to work? I want to do the same thing but Im still trying to sort through all the various ways Ive read to get them to work on our bikes.
Justin
01 F650GS Dakar
Old 04-29-2013, 10:50 AM   #10536
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,551
Could it be that the O2 sensor is faulty? Have you ever replaced the fuel filter/regulator? I have started to ride with a filter/regulator packed after as I am about 20,000 miles past the recommended replacement interval.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 04-29-2013, 10:57 AM   #10537
racergirl479
Flying Merkel
racergirl479's Avatar
Oddometer: 623
Anyone know what fuse disables the ABS system...?
I need to pull the fuse for this weekend, yet I cant find it...
OR - any other quick way to disable the ABS for the entire weekend. My switch on top is not connected.
Marisa
"This bitch don't ride bitch!"
950 ADV
racergirl479 is offline   Reply With Quote
Old 04-29-2013, 11:56 AM   #10538
rdalland
Dharma Bun
rdalland's Avatar
Oddometer: 344
I disconnect the front ABS sensor when I want to disable the ABS on my '06. There is a connector attached to the bodywork near the steering head on the left side. Follow the cable up from the wheel to find the connector.
It is tight squeeze, but it is easy to disconnect (do be careful not to break it). Tape or zip tie the disconnected wire out of harms way.
Enjoy today, tomorrow is not guaranteed.
rdalland is offline   Reply With Quote
Old 04-29-2013, 12:11 PM   #10539
Don Coyote
Don Coyote's Avatar
Oddometer: 1,311
I think WayneC1 has a PDF at his site that worked for me, but i don't have it bookmarked on this computer.
Wayne, how about a link in you .sig? What you have assembled seems to rival the chain gang FAQs...
'06 F650GS Dakar
Old 04-29-2013, 12:12 PM   #10540
racergirl479
Flying Merkel
Oddometer: 623
Great, thanks! I will try this first... It will disable the front and rear abs?
Marisa
950 ADV
Old 04-29-2013, 01:05 PM   #10541
Gravel Seeker
Thomas
Oddometer: 4,004
hhhh (that's Norwegian for Uuuuhhh)
Think I just replaced the relay
I believe I had to replace the blinker relay when I changed out the 10W OEM bulbs for 21W Osram Diadem bulbs many, many years ago. I think that realy is the same I have in now and that it works with the LEDs. Either that or I've just bought a relay for LED turn signals. LED blinker relays are $15 here http://www.biltema.no/no/Bil---MC/Bi...ele-LED-42200/, so I'm sure they're half that in the US. They have one for European cars and one for Japanese, doesn't say what the difference is though.
So there are 18 leds in each blinker. There's also at least 4 resistors in there
Gravel Seekers.com
Hey !
Old 04-29-2013, 01:25 PM   #10542
rdalland
Dharma Bun
rdalland's Avatar
Oddometer: 344
Yes, it will disable the front and rear ABS. The ABS light will blink to let you know that you have no ABS.
Old 04-29-2013, 01:53 PM   #10543
Gravel Seeker
Thomas
Oddometer: 4,004
.......It is the angle of the mount coming off the bracket which would be good to add in text as well as how much the stand is shorter compared to a stock stand.....
I'll get some measurments
  • Length vs OEM
  • Lean angle vs OEM
  • Forward angle
Length
Original: 36cm
New: 26 cm
Angle - cm off center....Someone probably aced algebra and can work out the angles based on that
Forward: Center of bolt to center of stand at ground - ca 5,5 cm (green line)
Lean: Center of bolt to inside of stand at the ground (so shortest point) - 12 cm (again, green line)
Gravel Seekers.com
Hey !
Old 04-29-2013, 05:46 PM   #10544
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Forgot to mention also Wayne, the stumble is the worst between about 3200 and 3800 rpms. I just try and keep it below 3k and above 4k and it runs pretty good with the occasional stumble.
Thanks Gravel Seeker. Ive read Wayne's page. Like I said, just trying to sort through the 5 or 6 different variations that Ive read and basically see which is the easiest to use.
Justin
01 F650GS Dakar
Old 04-29-2013, 06:04 PM   #10545
Damian_74
Damian_74's Avatar
Oddometer: 425
Aprilia pegaso 125 hub
Was looking for a spare front wheel - the wreckers want a small fortune for a Dakar front wheel and BMW wants your first born!
Found an Aprilia Pagaso 125 front hub on UK eBay, freighted to my door for less than $40 AUD. When you look up the Aprilia part numbers for the 125 and the 650s front hub they are the same.
The difference between the FI BMWs and the Aprilia is that the Aprilia has provision for a speedo drive, hence different seal size etc.
30 min on the lathe latter Ive machined the speedo drive area to suit a different seal, now we have a BMW friendly hub.
I realise that not everyone has access to a lathe but I am sure that your local engineering works could do the job easily for minimal cost very little set up work and if they have a larger machine might even be able to fit in a complete wheel?
STD BMW seal 40mm x 25mm x 7mm
STD Aprilia seal - 50mm x 40mm x 4mm (plus the drive tang)
Modified seal 50mm x 25mm x 8mm
Aprilia STD hub
Aprilia STD hub
BMW STD hub
Quick lick in the lathe
Finished
Damian_74 is online now   Reply With Quote
Times are GMT -7.   It's 09:03 PM.
