Old 04-29-2013, 08:54 PM   #10546
isgila
isgila's Avatar
Oddometer: 109
Originally Posted by racergirl479 View Post
Anyone know what fuse disables the ABS system...?
I need to pull the fuse for this weekend, yet I cant find it...
OR - any other quick way to disable the ABS for the entire weekend. My switch on top is not connected.
Put a washer or two in between the bolt that holds the front sensor.
This will space out the distance of the sensor to the abs ring. Works for my dakar and 800gs.
isgila is offline   Reply With Quote
Old 04-29-2013, 11:06 PM   #10547
WayneC1
Oddometer: 2,434
KG6BWS, Damian has bitten the bullet with the injector used by the 650X guys to improve their beasts you should be able to pick one up at a good price rather than the BMW one, his post is back on page 699 - post 10482
Re the indicators, it is all straight forward other than the dash lamp, the diode kits out there are the neatest quickest solutions
Damian, where did you pick up that injector in Oz and at what price ?, Nice adaption of the Pegaso wheel, Gravelseeker will be drooling over it
Don Coyote, have added a link to the info I have online in my signature, there is still a lot over at F650.com I dont cover but the FAQ over there needs a clean up and they dont cover the sorts of mods I was doing or we are all doing over here at advrider
Gravel Seeker, have grabbed the info you posted up and will update that pdf later today or tomorrow, it now appears on my updated side stand page
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 screwed with this post 04-29-2013 at 11:25 PM
WayneC1 is online now   Reply With Quote
Old 04-29-2013, 11:29 PM   #10548
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,907
Fwiw...
...I'm sort of rethinking the whole kickstand/lean angle issue. Last Sunday I had a photo assignment for a magazine to shoot a century bicycle ride with around 600 bikes participating. I rode the Dakar and would park on the road shoulder, shoot that section as bikes passed, then go to the next good spot and repeat. I must've stopped fifty times doing this.
I quickly found that the Dakar's side stand was ideal for parking on the sloped shoulder where the ground was higher on my left side than on the right. With a regular side stand I've have spent as much time finding a place to park the bike as I did shooting.
Guess there's an upside to anything.
GSBS is offline   Reply With Quote
Old 04-29-2013, 11:32 PM   #10549
wpoll
wpoll's Avatar
Oddometer: 126
Won't that kill the speedo too?
Wayne
New Zealand
'01 F650GS Dakar ("Checkers")
"...The world is actually on your side..." - Ted Simon
wpoll is offline   Reply With Quote
Old 04-30-2013, 12:14 AM   #10550
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,979
Originally Posted by Damian_74 View Post
]30 min on the lathe latter – I’ve machined the speedo drive area to suit a different seal, now we have a BMW friendly hub
crap
Seems I've done the theoretically easier, but practically harder route with mine by also picking up a speedo drive to use as a spacer
FYI, the Pegaso hub is identical to the Funduro hub which also has the speedo drive at the front wheel
Just picked my hub up from powder coat yesterday and if I ever get the coating out of the places it wasn't supposed to be, like the screw holes for the brake disc, I'll be happy enough.... who knew you had to mask it yourself....
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 04-30-2013, 12:20 AM   #10551
Gravel Seeker
Thomas
Oddometer: 3,979
Originally Posted by WayneC1 View Post
Damian, Nice adaption of the Pegaso wheel, Gravelseeker will be drooling over it
Gravel Seekers.com
Hey !
Old 04-30-2013, 02:52 AM   #10552
Damian_74
Damian_74's Avatar
Oddometer: 413
If anyone can find a 50mm x 25mm x 4mm seal - there would be no lathe work required!
I couldn't find one - doesn't mean that it isn't made - but it will more than likely $$$.
Originally Posted by Gravel Seeker View Post
Damian_74 is online now   Reply With Quote
Old 04-30-2013, 04:41 AM   #10553
Damian_74
Damian_74's Avatar
Oddometer: 413
I powercoated my KLX400 frame a few years ago - Must have taken me two days to clean up all the faces and threads. Scotch-brite pads on a die grinder is the best - but don't get the powercoat too hot - it melts.
Old 04-30-2013, 04:41 AM   #10554
michael1968
michael1968's Avatar
Oddometer: 772
Or just don't run a seal like I do.
I have a Funduro front hub (becasue I have a Funduro) and YZ forks, I just have a plain spacer between the fork leg and bearing. The wheel bearings are sealed anyway, come to think of it I don't think there is one on the brake side either...
Cheers,
Michael
michael1968 is offline   Reply With Quote
Old 04-30-2013, 04:51 AM   #10555
Damian_74
Damian_74's Avatar
Oddometer: 413
Cheers,
Michael
Michael - I've made the spacers a little different on the brake side. There is a flange to help protect the bearing.
Old 04-30-2013, 05:33 AM   #10556
Damian_74
Damian_74's Avatar
Oddometer: 413
Damian, where did you pick up that injector in Oz and at what price ?, Nice adaption of the Pegaso wheel, Gravelseeker will be drooling over it.
Wayne - The injector was on US eBay. At the time I paid about 75$ plus $20 freight to Australia.
The same bloke now has them for $100 + freight.
If someone finds them cheaper please let me know as I want one for my other Dakar.
http://stores.ebay.com.au/deutschepartsusa
Old 04-30-2013, 05:41 AM   #10557
WayneC1
Oddometer: 2,434
Damian, thanks, that is a good price based on my memory of looking about a while back, KG6BWS here can now look at one of those courtesy of you giving one a try, I was going to give one a run but you know gunna too many things too little time
Old 04-30-2013, 05:43 AM   #10558
isgila
isgila's Avatar
Oddometer: 109
My dakar has gone south a long time ago. But the 800gs speedo still work when i did it...
Old 04-30-2013, 05:54 AM   #10559
rdalland
Dharma Bun
rdalland's Avatar
Oddometer: 341
The speedometer works off the rear ABS sensor, as long as it is connected and functioning the speedometer will work. That is why you want to disable the front sensor (at your own risk of course).
Enjoy today, tomorrow is not guaranteed.
rdalland is offline   Reply With Quote
Old 04-30-2013, 05:58 AM   #10560
Aquatic
Aquatic's Avatar
Oddometer: 1,571
Please can I laugh!
Like the buggers that laughed at me.
Aquatic is online now   Reply With Quote
Times are GMT -7.   It's 02:37 AM.
