Old 05-09-2013, 07:38 PM   #10621
guavadude
de-composer
guavadude's Avatar
Oddometer: 827
chain guard
I'm wanting to lose the possum scraper stock chain guard. Seems like the touratech chain guards break. Any good suggestions for a replacement?
Or I can take the dremel tool to the plastic one on there now or I can go without. Any issue I don't know about if I just take it off?
guavadude is offline   Reply With Quote
Old 05-09-2013, 07:52 PM   #10622
WayneC1
Oddometer: 2,515
You can dremel the plastic one, or there was a stainless steel one out of the UK advertised on ebay
http://www.ebay.co.uk/itm/Chain-guar...item5aeeb9bff6
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is offline   Reply With Quote
Old 05-09-2013, 08:53 PM   #10623
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,171
Orilly? Mine hasn't despite being flogged as recently as about an hour ago. I'm sure it happens...... Mine hasn't.
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 05-09-2013, 09:26 PM   #10624
guavadude
de-composer
guavadude's Avatar
Oddometer: 827
I'm liking that! Thanks
Old 05-10-2013, 12:06 AM   #10625
Damian_74
Damian_74's Avatar
Oddometer: 419
Chain Guard
Can confirm - the TT chain guards will crack over time, fatigue cracks.
Bought a steel one out of Germany – much more robust but with a weight penalty!
http://www.ebay.de/itm/Chainguard-BM...item48551c9425
For my other Dakar – have just taken the grinder to the possum scrapper – more than does the job and looks neat/ factory.
Here in Australia the local CONsTabulary take a dim view on removing the chain guard and class it as a major defect – I think that it is three demerit points, tow home and $$$$$.
Damian_74 screwed with this post 05-10-2013 at 02:07 AM
Damian_74 is online now   Reply With Quote
Old 05-10-2013, 01:05 AM   #10626
KG6BWS
KG6BWS's Avatar
Oddometer: 895
I threw mine away not long after I bought the bike and havent had any problems with it. For that matter, neither my KLR or my DR had chain guards.
"But I swear, a woman's breast is the hardest rock that the Almighty ever made on this earth, and I can find no sign on it." Bear Claw Chris Lapp
Justin
01 F650GS Dakar
KG6BWS is offline   Reply With Quote
Old 05-10-2013, 01:29 AM   #10627
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,994
Dremel the shit out of it or just remove it altogether.
Might run into trouble with the law though as the scraper is there to make the spray angle legal.
If you remove it you should in theory extend the fender/ license plate down to compensate for the spray angle at full extension of the shock, which is why it is easier to have the static scraper on the swing that takes the shock out of the equation
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 05-10-2013, 01:43 AM   #10628
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,945
Sertao guard...
Seems like I've read that some are using the Sertao guard on their Dakars, though I've not seen it personally. I just looked and it's like $21 on Max BMW's parts fiche...
GSBS is offline   Reply With Quote
Old 05-10-2013, 02:24 AM   #10629
WayneC1
Oddometer: 2,515
Damian
Re rego requirements on chain guard in Oz, I wondered and spoke to a blue slip inspector in NSW, He smiled and indicated basically if it is there it is OK, it seems there is some confusion of what is required and to read the precise wording I needed to pay $300+ to buy the ADR which I grumped to the feds about
I understood it needed to go to the most rearward part of the rear sprocket but have seen some new 1000's which dont seem to have a chain guard as such and the swing arm seems to be the guard, one was an MV
I have my own on there but have the BMW one as a rego time item if needed, that Sertao one looks like a low cost option
Old 05-10-2013, 03:17 AM   #10630
Damian_74
Damian_74's Avatar
Oddometer: 419
Damian
Wayne
Extract from Queensland transport
http://www.tmr.qld.gov.au/~/media/Sa...motorcycle.pdf
Flexible drive (chain and belt) guards
If the motorcycle has a fl exible drive, the driver and any
passenger must be protected from the front sprocket and
at least the upper part of the fl exible drive by the frame or
equipment of the motorcycle, or by the use of a guard. A guard
must cover the fl exible drive to a point at least 300 mm to the
rear of the rearmost footrest or above the centre of the rear
drive sprocket. Motorcycles must be fi tted with footrests for
the rider, and for any passenger for whom a seating position is
provided.
There another rule about the lenght of the rear guard but can't find it at the moment
It sort of goes like.......The rear wheel will be coverd when a line is projected upward at 45 deg from the rear axle with 20kg's on the seat.........or some rubbish like that.
http://www.rta.nsw.gov.au/registrati.../vsi/vsi28.pdf
Old 05-10-2013, 03:27 AM   #10631
WayneC1
Oddometer: 2,515
Damian, thanks for that, it seems the states are going in their own direction via regulations and not adhering to the ADR's
An easier to read extract is
If the motorcycle has a flexible drive, the driver and any passenger must be protected from the front sprocket and at least the upper part of the flexible drive by the frame or equipment of the motorcycle, or by the use of a guard. A guard must cover the flexible drive to a point at least 300 mm to the rear of the rearmost footrest or above the centre of the rear drive sprocket. Motorcycles must be fitted with footrests for the rider, and for any passenger for whom a seating position is provided.
My guard easily meets the Qld spec there but in NSW at least it seems it needs to go further to the rear and I heard a vague reference to protection underneath which had me mystified
Old 05-10-2013, 04:27 AM   #10632
rdalland
Dharma Bun
rdalland's Avatar
Oddometer: 344
I came across this article recently:
http://www.truegritgs.com/2013/05/07...s-chain-guard/
BMW OEM Part #01 46 62 7 727 156 G650GS Chain Guard
Enjoy today, tomorrow is not guaranteed.
rdalland is offline   Reply With Quote
Old 05-10-2013, 04:52 AM   #10633
Damian_74
Damian_74's Avatar
Oddometer: 419
Rear guard
Found the section in the ADR's
14.3.3.1. Rear „Axle’ and Side-car
The wheel guard provided for the rear wheel and for the wheel of any
side-car must extend not less than from a point vertically above the
foremost part of the wheel rearward to a point not higher than the
intersection of the arc of the wheel guard with a line through the centre
of the wheel at 45 degrees to a horizontal plane through the centre of the
wheel when a mass of 45 kg is distributed in the saddle of the vehicle at its „Unladen Mass’.
http://www.comlaw.gov.au/Details/F2011C00102/Download
Old 05-10-2013, 05:04 AM   #10634
Barnman
Barnman's Avatar
Oddometer: 206
That's what I did back in 2011 and it works just fine
Barnman is online now   Reply With Quote
Old 05-10-2013, 05:40 AM   #10635
guavadude
de-composer
guavadude's Avatar
Oddometer: 827
Thanks! Sertao guard looks good and cheap.
guavadude screwed with this post 05-10-2013 at 07:22 AM
Times are GMT -7.   It's 07:15 AM.
