Old 03-11-2009, 10:01 AM   #1
JayRitz OP
Oddometer: 19
1997 BMW F650 Funduro - reliable?
Well, I finally did it. It has always been a dream of mine to have a dual sport and a few days ago, I bought a well maintained 1997 BMW F650 Funduro for under $1k. The couple that sold it to me had hardly ridden it lately, and since I was riding it to maintain it for them, they cut me a sweet deal (I can't tell you how grateful I am to them)! It came with the Corbin seat, Olins shock, aluminum hard bags, helmet, tubes, Kevlar riding suit, only 32k miles, and so on! I had ridden 4 or 5 times before, so I was familiar with it. The guy was the only owner, and did all the maintaince work.
Ok, to the point. I understand that sites like advrider and the chain gang are there for support and technical help, but there seems to be so many things that can go wrong with the bike (wheel bearings, chain/sprocket, battery, etc).
My questions:
1. Have other Funduro owners found their bikes to be reliable?
2. Should I plan to spend a lot of time working on the bike?
Not to sound like a "Johnny Raincloud", but my previous bike, a 1984 Honda Magna 700, cost me over $2k in repairs in two years. Not the best of experiences.
All that aside, I still am very excited about my new bike. It handles the rodes like a bike should, and I intend to ride it as much as possible. I have taken down a rough trail and it did fine. Love the torque, love the height. Seems to be a great bike!
JayRitz is offline   Reply With Quote
Old 03-11-2009, 10:16 AM   #2
ADVCoop
ADVCoop's Avatar
Oddometer: 792
I can't help you as I have never owned a Funduro, but congrats on the new bike and the sweet deal!
2006 Husqvarna TE610 - 1982 Suzuki PE175 - 2009 Yamaha XT250 (wife's)
ADVCoop is offline   Reply With Quote
Old 03-11-2009, 10:18 AM   #3
foster
Huh?
foster's Avatar
Oddometer: 771
That motorcycle has a strong following for a reason. Quit worrying and start riding.
foster is offline   Reply With Quote
Old 03-11-2009, 10:27 AM   #4
Mtncrzr
Just Kidding, not really
Mtncrzr's Avatar
Oddometer: 1,213
Check out www.f650.com for all the Funduro info you can stand. Check out the Technical FAQ sections for the "Classic F650."
I had a 2000 Funduro and it was a good bike. Not really much maintenance. Good dual-sport and comfy.
Mine did not like Donner pass or boulder gardens too much though (only 7 inches of travel).
Wires on the bottom of the ignition key module broke and almost left me stranded once. That was the only problem.
I'll be the one on the horizontal silver 640 KTM Adventure.
Mtncrzr is offline   Reply With Quote
Old 03-11-2009, 10:45 AM   #5
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,673
You got a steal! I had a 97 and it was a great bike. Steering head bearings and water pump seals were easy fixes and after that it was totally bullet proof. If yours has low miles, you may not even have to consider that work for a long time. Change your coolant though to make sure its anti-corrosive qualities are up to snoff.
Now, get riding!
"If you don't peer over the edge now and then, how do you know where it is?" The venerable Mr. Cob
Mista Vern is online now   Reply With Quote
Old 03-14-2010, 04:52 PM   #6
markcap
markcap's Avatar
Oddometer: 362
Hey Jay,
I just picked a '97 Funduro late in 2009.
Winter here in PA has kept me grounded except for maybe 200 miles of some cold weather rides. I had plenty of spare time so I performed the water pump & steer head repairs. ( Both were necessary ) Parts for both repairs, relatively cheap. The tasks were very easy bordering on simple thanks to the great write ups over at the chaingang site. I love this bike. I owned a KLR650 just prior to trading up for this Funduro. I couldn't be happier with this deal. This bike may be nearly as fast & fun as my DL650 Vstrom. I have a real delema this season....
Enjoy. You bought yourself a great ride.
Cap
'07 DL650
Lehigh Valley, PA
markcap is offline   Reply With Quote
Old 03-14-2010, 05:35 PM   #7
GB
Mod Squad
GB's Avatar
Oddometer: 56,854
For all your FAQ's, check out http://f650.com/phpbb3/index.php
Old 03-14-2010, 06:51 PM   #8
Scottysix9
Shhh...
Scottysix9's Avatar
Oddometer: 919
Yes. It is reliable, but as with any used bike, there will be some things to fix. I bought mine with 20,000 miles and have put 25,000 more on it.
Here were my problems.
The most expensive fix was when the chain broke in Carlsbad New Mexico. Once I got it home, a tape measure showed the factory stamps in the swingarm were 1/4 inch off, side to side. I have worked on a lot of bikes and never seen this large of an error. I now adjust my chain using a tape from the swingarm pivot to the center of the axle.
Cost-Chain, sprockets, rear wheel bearings and seals.
The oil plug stripped the threads in the crankcase..
Cost- Big tap, new oil plug.
The plunger that engages the clutch broke a tooth.
Cost- Plunger, fiber plates (since I had it apart and the plates were worn enough to change).
While riding to work, it started missing and then quit. Once at the shop, I diagnosed a dead reg/rec.
Cost- new r/r and time to relocate it from under the seat to the side of the bike where it can get some cool air.
Other items- tires, brakes, brake discs, fork seals, battery, steering bearings.
I have also added a temp gauge in place of the clock, heated grips, XM, GPS, Corbin seat, rejetted the carbs for Colorado, driving lights, etc.
It's a fun little bike, but with 30,000 miles, don't expect it to be maintenance free.
One more thing. Change the spark plug boots. The stock boots are junk. The resistor corrodes internally and will cause starting and/or running problems. Throw them as far as you can and buy some nice, new NGK's.
BMW 650 KDX 220 TS 400
If they can't hear you, they won't know you're there.
Scottysix9 is offline   Reply With Quote
Old 11-27-2010, 12:52 PM   #9
zataomm
zataomm's Avatar
Oddometer: 360
Thinking about getting one...
I'm reviving this thread because I just sold my airhead and am thinking about getting a '97 f650 for sale locally. Bike has less than 6k miles and he's asking $2700, which seems like a good deal.
One concern I have is that the closest BMW dealer is about 4 hours away. What's routine maintenance like on these bikes? Any special tools required? I have heard from friends who've owned them that with regular servicing they are very reliable.
This particular bike does not have hard bags; owner said he thought the bag mounts are built in to the bike. Is this the case?
If I go to look is there anything unique to these bikes I need to check out?
Thanks for any input you might have.
zataomm is offline   Reply With Quote
Old 11-27-2010, 01:07 PM   #10
Railbender
Oddometer: 1,044
Routine maintenance is not hard. Probably the worst project is getting the carbs back on if you should remove them.
On a '97 the bag mounts are not built in.
Take a look at the FAQs on www.f650.com The Chain Gang is THE source for all things F650. Take a look at the voltage regulator FAQ. That may be the weak point. I did the relocation and have never had a problem.
For that price/mileage go for it. I like mine much more than the R90/6 I had.
The shortest distance between two points is boring.
Railbender is offline   Reply With Quote
Old 11-27-2010, 03:30 PM   #11
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 390
Great bike.
I had one from new in 1995. Apart from maintenance just a few main things to look out for.
Steering head bearings: because the oil tank is in the frame. bearings get hot. Just replace them when they get notchy and get riding. No drama.
Other than that they are dead reliable.
re the sump plug. If you tighten them to the specified 40Nm torque they will strip. especially if torqued when they have oil on them. 25NM is enough.
If you accidentally do this, the cheapest fix is to use the plug from a BMW K75 gear box Filler plug. Part number 07119919143. This has the same thread but the thread is longer and will bite into the undamaged thread. Only half of the available thread is used by the original plug so it is as strong as original. No problem. Also, a scab of RTV makes an effective way of avoiding loss of the plug if it comes loose.
Kiwi Tinkerer is offline   Reply With Quote
Old 06-22-2013, 09:07 PM   #12
rride
Honda NH 750
rride's Avatar
Oddometer: 133
And the OP's last post was where are trails in Chattanooga, TN as he rode off into the sunset almost 3 years ago!
A good story for a great motorcycle
rride is offline   Reply With Quote
Old 09-25-2013, 06:57 AM   #13
JayRitz OP
Oddometer: 19
LOL!!! That does sound really good. Sorry for the long time away from the site. Been doing life - work, 1 more kid since last post, job changes, and back to school for my 3rd degree.
Still riding the Funduro - ride almost daily to work. Have had a few issues with the bike, and have a few more to iron out. Love it when its running tip-top shape.
Old 11-26-2013, 09:55 AM   #14
alma1759
Nothing
Oddometer: 116
Jay, give us the summary? How many miles? What have you done to it?
Had one myself from new in 1995, ex-wife hated it, sold it with less than a year ownership. I still look at it longingly and I'm trying to steer my son towards one as his second bike...
alma1759 is offline   Reply With Quote
Old 11-26-2013, 10:19 AM   #15
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 1,399
A neighbour up the street had one for sale in the summer, it had 140,000kms on it. That would make it reliable in my books.
He was however asking $3500.00 dollars for it. Needless to say, he still has it.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is online now   Reply With Quote
Times are GMT -7.   It's 11:34 AM.
