Old 03-11-2009, 03:27 PM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,741
Question R80 G/S, Balancing new clutch
When installing a new clutch, my Chilton manual says to balance it. The flywheel has a white balance mark on it, but the original hosing cover and compression plate had nothing.
Does anyone know if factory parts will come w/ balance marks on them, if not what should I do about balancing, is it that critical???
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-11-2009, 05:30 PM   #2
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
I just put mine back on the way it came off. If you look on it you'll see holes drilled in different places around it--that's where it was balanced at the factory. The clutch disk--the part that wears--floats, so there's no need to take it into account during balancing.
Martian had some fancy space-age way to balance his and I think he ended up just putting it back on the way it was. Check Slope'rs 'tearing into my PD thread' for it.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-11-2009, 05:54 PM   #3
One Less Harley OP
Oddometer: 4,741
If I was going to put the old clutch in then it wouldn't be an issue, but I'm installing a new clutch and not sure if it has balance mark on it (haven't gotten it yet)
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-11-2009, 06:15 PM   #4
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
some engine building shops can balance flywheels. Like this:
http://www.wellsracing.com/services/.../flywheels.htm
I've read of folks on this forum taking their airhead flywheels to car shops and getting them balanced, no personal experience. With the clutch carrier the G/S has it may not be a big deal since it's so light.
so did that messed up starter end up trashing your clutch or something?
Old 03-11-2009, 06:28 PM   #5
pommie john
pommie john's Avatar
Oddometer: 1,467
The white paint is the factory balancing mark. It should be on the old parts too. Maybe they need a clean up?
The white marks should be installed at 120 degrees to each other ( evenly spaced).
pommie john is offline   Reply With Quote
Old 03-11-2009, 06:34 PM   #6
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Mine had no balance marks, came form a bike with unknown history. I remove tons of rust which left quite some pitting. Slap it together, don't waste your money on clutch balancing. I did it on none of my past and current bikes and none of them was particularly vibrant.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 03-11-2009, 07:09 PM   #7
One Less Harley OP
Oddometer: 4,741
What I want to know if ON NEW PARTS are there any marks for the heavy spots!!!! Not the old parts as they are being replaced.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-11-2009, 07:18 PM   #8
bmwrench
Oddometer: 2,178
Yes, the new parts will have balance marks.
bmwrench is offline   Reply With Quote
Old 03-11-2009, 07:22 PM   #9
StephenB
StephenB's Avatar
Oddometer: 2,044
I don't know for sure whether BMW balanced the clutch as an assembly when they built the bikes and then marked all parts. But I believe they did.
When they manufactured parts like pressure and compression plates for the after market they surely balance those parts to spec and not for heavy spots. I think you can safely assume that there will be no markings on the parts as they will all conform to spec.
And then my previous post applies.
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 03-11-2009, 08:06 PM   #10
pommie john
Oddometer: 1,467
Yes. The white marks are the balancing marks. I don't know if they are the heaviest or lightest spot, but assemble them at 120 degress apart.
There should be a mark on the flywheel ( clutch holder), pressure plate and pressure ring.
Old 03-12-2009, 05:22 AM   #11
Martian
Oddometer: 1,104
Actually, I, too, replaced the spring plate, pressure plate, and clutch so putting it back the way it was was not an option. I did place the balancing marks as close to 120 degrees apart as I could when I first assembled everything off the bike, but when I suspended it, the unitized parts listed to one side. Therefore, I started rearranging them until it hung level. There was some discussion as to whether or not my static balancing act would have any effect, but we'll know soon enough. The transmission is on its way back from rework and will be installed in a week or so. If the bike shakes like hell, it didn't work. If it doesn't, then my gravity powered, portable balancing machine may or may not be the reason. I'll keep everyone posted on the outcome.
Tom
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 03-12-2009, 01:06 PM   #12
JRP
Old guy
JRP's Avatar
Oddometer: 1,524
It seems to me if you want to balance two parts that are marked at their heavy points you would want the marks to be 180 degrees apart not 120 degrees
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 03-12-2009, 02:59 PM   #13
Martian
Oddometer: 1,104
The flywheel is part of the equation as well.
Tom
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
Old 03-12-2009, 05:45 PM   #14
pommie john
Oddometer: 1,467
Read my post. I said " There should be a mark on the flywheel ( clutch holder), pressure plate and pressure ring."
That adds up to three parts, not two. The math ain't hard.
Old 03-13-2009, 02:50 PM   #15
One Less Harley OP
Oddometer: 4,741
Just got the parts in from motobins, the Sachs clutch does have balance marks, so this shouldn't be too hard.
Looks like I'll have some work to do this weekend.
Rebuild the starter and put in a clutch.
Maybe I'll take pictures of the starter rebuild
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 12:53 PM.
