Old 09-27-2012, 02:46 AM   #4126
ditchwitch650
ditchwitch650's Avatar
Oddometer: 834
ditchwitch650 is offline   Reply With Quote
Old 09-27-2012, 03:48 AM   #4127
KASUYAHO
Road Hog
Oddometer: 3,593
What are you doing there Ditchy ?
KASUYAHO is offline   Reply With Quote
Old 09-27-2012, 03:54 AM   #4128
ditchwitch650
Oddometer: 834
installing new timing chain piston and rings into my 2000 model that has been a bench weight for too long
Old 09-27-2012, 04:11 AM   #4129
KASUYAHO
Road Hog
Oddometer: 3,593
Is it going to be a project bike ?
Project bikes are common at the moment it seems
Old 09-27-2012, 04:27 AM   #4130
ditchwitch650
Oddometer: 834
i started the fad! I stripped it down November 2010 the get a parts list for my visit to the states, I have done a fair bit to it but have alot left to do,
hope to have it back on the road under 2 years Big willy is getting antize
Old 09-27-2012, 05:04 AM   #4131
KASUYAHO
Road Hog
Oddometer: 3,593
You'll get there Ditchy.
I got mine apart changing out the radiators, just too much going on to get to it,
so a couple of weeks back i mounted up the radiators to find that they hit the exhaust headers,
so there back at PWR getting modified.
A bit of a plug for PWR,
They gave me a good price, then changed the lower tanks for me no charge,
and now changing the side radiator brackets no charge.
And with no fuss, no blaming or excuses, very helpfull guys.
Old 09-27-2012, 01:32 PM   #4132
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,216
'bout time you got off your arse
A vewwy good fwiend in Wome
Big Willy is offline   Reply With Quote
Old 09-27-2012, 04:21 PM   #4133
jm-2008
jm-2008's Avatar
Oddometer: 507
Thermostats
Noting Burpsa's comment -
For bleeding the cooling system I drill a small hole (3mm dia) into the rim of the thermostat. This hole also increases the flow with a shut thermostat which is a good thing, marginally cooler running if you will, but any air in there will find 'top' super quick.
Found my OEM item had the centre pin bent as many appear to do, decided to leave the thermostat out.
Have run the bike for some time without the thermostat with no apparent issues.
Did not have the TT Vapor fitted prior to removing the thermostat so have no comparative temp data to compare with and without.
Don't usually ride in freezing conditions so quick warm up assistance isn't an issue.
Was more concerned with it jamming shut with obvious consequences hence not fitting another one.
Any thoughts out there re not having it in?
JM
jm-2008 is offline   Reply With Quote
Old 09-27-2012, 05:40 PM   #4134
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,459
do you have a temperature measuring device fitted currently?
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 09-27-2012, 07:58 PM   #4135
jm-2008
jm-2008's Avatar
Oddometer: 507
Temperature
Digga,
Have a Trail Tech Vapor fitted.
Set the temp warning for 110C (memory not good will check tonight)
Light has only come on a couple of times but never had any boiling issues.
Mainly ride rocky 4WD tracks down here no single track stuff where you might get caught stopping with motor running.
Had no issue on Black Saturday when all the big fires were on in 45+ degree heat.
Why you ask?
JM
Old 09-27-2012, 09:43 PM   #4136
ditchwitch650
Oddometer: 834
which cam you want in it?
waiting for your decision
ditchwitch650 screwed with this post 09-27-2012 at 10:20 PM
Old 09-27-2012, 09:45 PM   #4137
KASUYAHO
Road Hog
Oddometer: 3,593
JM
Myself not a fan of Not running a Thermostat.
Causes:
Reduced engine life, less fuel economy and reduced power.
Old 09-27-2012, 11:51 PM   #4138
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,459
Digga,
Why you ask?
JM
was thinking more the lower end of the scale. what temp does it run on average? i think from memory the vapour only kicks in at about 40C.
Old 09-28-2012, 05:53 AM   #4139
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 644
Super cheap do an ideal replacement thermostat that has the small hole in the rim with a small toggle in it that opens and closes depending on the direction of flow. It fits straight in and costs a few dollars. ;)
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 09-28-2012, 03:13 PM   #4140
jm-2008
jm-2008's Avatar
Oddometer: 507
Part no ?
Times are GMT -7.   It's 12:13 AM.
