Old 11-22-2012, 02:46 AM   #4861
johnno950
Oddometer: 1,076
you guys should go work for nasa
johnno950 is offline   Reply With Quote
Old 11-22-2012, 02:56 AM   #4862
KASUYAHO
Road Hog
Oddometer: 3,646
NASA works on 99.999999999 percent accuracy.
Theres way too many fuckups in here for that Johno
KASUYAHO is offline   Reply With Quote
Old 11-22-2012, 02:57 AM   #4863
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,328
G'day Johnno, i tried ringing Serco today(thanks for the heads up), but the workshop must shut around 4.00. I have a couple of leads now so will chase them up tomorrow.
poppy is offline   Reply With Quote
Old 11-22-2012, 03:08 AM   #4864
johnno950
Oddometer: 1,076
ground control to major f-ckup happens quite a bit when i work on my bikes
Poppy if you want a loan of a clymer xr650r manual for a couple of months give me a pm and i will send it to you in the next week or so.
Old 11-22-2012, 03:10 AM   #4865
DRjoe
DRjoe's Avatar
Oddometer: 5,136
nasa don't even know if there working in metric or imperial let alone getting down to a 99.999999999 % accuracy
Old 11-22-2012, 04:03 AM   #4866
KASUYAHO
Road Hog
Oddometer: 3,646
Yeh i have days like that
Old 11-22-2012, 04:04 AM   #4867
KASUYAHO
Road Hog
Oddometer: 3,646
Whys that Joe
Old 11-22-2012, 11:09 AM   #4868
Andy-Gadget
Any bike can go anywere
Andy-Gadget's Avatar
Oddometer: 1,351
I agree that these don't look like cracks to me, casting mold is the most likely cause.
If you want to be completely sure, do a dye penetrant crack check, but my bet is they won't show anything.
The non-rotating side of a bearing is usually size for size fit, called transition, only the crank side of the bearing needs interference, think about a rear wheel drive vehicle front wheel stub axle and hub, and where the interference is and which parts turn.
For reassembling and truing the crank, buy a copy of "Tuning for speed" by that great Aussie engineer, Phil Irving, and all will be described in practical terms.
Originally Posted by poppy View Post
Push
Push
Push
There it is, welcome xr crank
Not sure i like the look of this bearing
or these cracks
"If a man empties his purse into his head, no man can take it away from him.
An investment in knowledge always pays the best interest"
Benjamin Franklin.
'95 Sport 1100 Guzzi,'84 Cali 2 Guzzi, '95 Guzzi mille, '84 R65LS, '84 R100, '82 R100RS, '05 DL650, '72 Bultaco Sherpa T 350, '78 Montessa 348, "00 XR650R
Andy-Gadget is offline   Reply With Quote
Old 11-22-2012, 11:56 AM   #4869
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,237
Wee bit different when talking about steel into alloy housing though otherwise when the motor gets hot, the bearing will spin in the case.
Don't forget also that some cranks are located by one of the main ball bearings.
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 11-22-2012, 03:49 PM   #4870
jm-2008
jm-2008's Avatar
Oddometer: 513
[QUOTE=KASUYAHO;20095241]I have been doing some reading etc about balancing the single engine cylinder engine.
I look at the crank on the 650R and i don't see drill holes to show that it has been balanced.
Thumpers generally have 'Pork Chop' flywheels (not full circle like the two strokes - different reason for them)
Majority of excess material is eliminated in the profile (pork chop shape) eliminating the need to remove heaps of material either side of the big end - Counter balancer addresses this issue
This is where the counter balancer comes in in that it replicates rotational mass in a 180 degree rotaion in the opposite direction to counter the effects of bigend crank mass flying around.
Big single and or (non 180degree) twins with a common throw (big ends together) benefit from a counter balancer.
In a non counter balancer type motor balancing the cranks is done with a percentage of the rod/piston weight at the bigend.
If memory serves me correctly the percentage will often come into play at different rev ranges
ie when your car wheels are 'out of balance' you will experience shake at some speeds and not others.
So what percentage do we over balance the 650R if any
Good question, theres data available for a non counterbalanced engine (if you are keen for a read find Phill Irvings - Tuning For Speed, mainly on old British singles and as he designed the Vincent has a lot on V Twins.
Certain theres a section on balancing.
Where does the counter balancer come into play, at lower RPM or High RPM's ?
Through out the range I say at a guess as it 'counters in the opposite plain'
JM
jm-2008 is offline   Reply With Quote
Old 11-22-2012, 08:00 PM   #4871
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,328
Bit more progress
Pulling the bearing off the crank
Had to do some repairs to the case were the case saver fits
Tigged up mounting lug
Cleaned & shaped up
Drilled out, ready for tapping
Bit of a chamfer just like factory
Works just like a bought one
Old 11-22-2012, 08:19 PM   #4872
ditchwitch650
ditchwitch650's Avatar
Oddometer: 868
best case saver i could find
but i suspect you might make your own might be a few here keen
ditchwitch650 is offline   Reply With Quote
Old 11-23-2012, 12:34 AM   #4873
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 656
Hey is that my one DW?!
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 11-23-2012, 01:09 AM   #4874
jm-2008
jm-2008's Avatar
Oddometer: 513
[QUOTE=DRjoe;20096765]thumper racing in the states can balance the crank and balancer for you but don't ask them how they do it because its apparently a trade secret.
I think lots of complex maths is the secret to getting the balancer shaft and the crank shaft working well together
Not certain is that big a secret.
Ref Big Willy's comment a few posts up re balancing the Bonnie at 85%
You could allways tell if some one had their late 60's early 70's Trophy/Bonnevile's balanced as the front wheel would not shake when they idled - not a guaranteed give away but a good indicator.
Back to the question -
Deducing the correct precentage of rod/piston weight to use for the desired effect is the secret.
With the old Trumpet's (Triumph's) many a percentage was tried till the 85% figure was settled on as a good target to aim at.
As for balancing a counterweighted motor one would expect balancing both together (to an appropriate % would be a good start point.
Lots of quiet lurkers out there who will know, maybe we should seek their sage advise
(This might turn into another - Whats the best oil discussion )
For the sake of the discussion would be interested to know from the learned ones
JM
Old 11-23-2012, 01:09 AM   #4875
Burkey
Burkey's Avatar
Oddometer: 260
Your bikes so clean.....it's nearly gay
Burkey is online now   Reply With Quote
Times are GMT -7.   It's 06:48 AM.
