Old 01-12-2013, 06:02 AM   #5116
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,087
Are the subframes heat treated after manufacture?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 01-12-2013, 06:29 AM   #5117
KASUYAHO
Road Hog
Oddometer: 3,646
Is it the weak subframe or crap setup suspensions ( shim stack ) that cracks the subframe ?
Corrigations ? what corrigations
KASUYAHO is offline   Reply With Quote
Old 01-12-2013, 02:19 PM   #5118
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,540
Originally Posted by Lostsaffa View Post
My understanding is that the weld is just to hold the block in place, not to take weight. The weight is on the holes in the square tube pulling the subframe towards the front of the bike. The block is more to keep the tube in shape when bolted tight. I had the weld break on my previous pig, but it never got any worse, the block just rattled in the tube when loose, but otherwise it still did its job In my opinion.
so what you are saying is the block is superficial and the entire subframe is hanging from 2 bits of 1.5mm alley tube about 10mm long?
on that left hand mount, it is threaded. so the load goes straight to the solid bar and then transfered to the tube through the weld. nearly all the beaks i have seen have been from slightly different variations of this.
i think will hit it on the head
not a expert
strenthen mounting points ,simple eh
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 screwed with this post 01-12-2013 at 02:49 PM
digga1111 is offline   Reply With Quote
Old 01-12-2013, 02:51 PM   #5119
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
Originally Posted by digga1111 View Post
iam not the one spending 6000 bucks on some wank steel replacement one
its 4000 bucks and its my dick so i'll wash it as hard and fast as i can
looks like me and smithy will be the only 1's on this trip
poppy will do his magic and im sure he will fix the sub up on the xrr's ... i just like the idea of steal to weld to if need be
where did nettys snap?
is it due to incorrect load placement stock suspesion and to much load at the rear
changeing out the the top bolt with a bit longer and a lock nut on the other side
Growely has his sub mods he done few pages back .....they carried alot of weight
smithy seems to carry alot of gear and worked out for him ....
all posted pages back in this thread ......drop a few kg's of the rider wouldnt go astray
are we there yet
Sean-0 is offline   Reply With Quote
Old 01-12-2013, 02:59 PM   #5120
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,332
Its a piss weak subframe for carring a load. No suspension(shim stack) is going to counteract vibration, oscillation, laterall movement on a loaded bike. For racing or just trail riding unloaded, non issue and a totally different kettle of fish. Suspension works in a single plane, not a 4 dimensional axis.
poppy is offline   Reply With Quote
Old 01-12-2013, 03:01 PM   #5121
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,540
looks like me and smithy will be the only 1's on this trip i doubt it
poppy will do his magic and im sure he will fix the sub up on the xrr's ... i just like the idea of steal to weld to if need be. yeh me too, is there much to do to make those steel ones work?
is it due to incorrect load placement stock suspesion and to much load at the rear they are pretty ordinary to start with
changeing out the the top bolt with a bit longer and a lock nut on the other side that is a temporary fix
smithy seems to carry alot of gear and worked out for him ....think you will find he snapped one of the legs last time
all posted pages back in this thread ......drop a few kg's of the rider wouldnt go astray get fucked
are we there yet
getting closer
Old 01-12-2013, 03:01 PM   #5122
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
you making a rack for yours poppy ..beefing up the stock sub or making a new 1
keen to hear your idea's ...
Old 01-12-2013, 03:06 PM   #5123
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
easy to get those steal subs to work ...take it down the the fence builder and get him to fit it
did he break the sub or the rack .. ..who rides with 2x20ltr jerrys on the back of and xrr
bloody kiwi
Old 01-12-2013, 03:18 PM   #5124
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,332
When is your steel one arriving?
Mate personally i like the idea of steel, mainly because if there is a need to repair it, chances are we would be able to have a helpful property owner loan us a stick welder, maybe even a mig to do repairs. Not many have ali migs or tig welders set up kicking around. The standard subframe can be made stronger though and there are people that carry a lot on them.
Old 01-12-2013, 03:22 PM   #5125
KASUYAHO
Road Hog
Oddometer: 3,646
Ok,
Just saying what i experienced with mine that all.
Old 01-12-2013, 03:24 PM   #5126
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,540
hope he doesn't have much to do between now and the end of July. will prolly take him that long to make em work
Old 01-12-2013, 03:30 PM   #5127
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
plan was to order at the end of jan
all self ordered with a discount code for our group buy .....i recon its the way to go ....few tweaks need to be done for fitment but im sure it aint to hard .....
like you said beefing up the stock frame aint gunna solve the sideways flex ..hence steal
Old 01-12-2013, 03:30 PM   #5128
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,087
Will depend if you want it polished or painted!
xronly
Old 01-12-2013, 03:32 PM   #5129
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,540
ha ha, i haven't told you what the fix plan is yet
how much did you get em for on a group buy?
sounds like you might need to take ya swag to the shop mate, few late nights comming up
digga1111 screwed with this post 01-12-2013 at 03:38 PM
Old 01-12-2013, 03:44 PM   #5130
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,332
The personal journey getting to the ride is as much a part of the adventure as the ride itself.
(poppy)
Times are GMT -7.   It's 10:16 PM.
