Old 02-20-2013, 12:57 PM   #5641
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 656
Originally Posted by poppy View Post
About 6 day's. I ordered on Thursday and had parts the following Wednesday.
Also got my thrust washer from Honda Aus. What are the chances of them having it in stock, an internal gearbox washer, amazing. Ordered on Monday, had it by lunch time Tuesday.
That's an awesome turnaround time, will certainly be giving them a try once I have the $$$$$
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 02-20-2013, 11:07 PM   #5642
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,514
welcome to honda ownership
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 02-21-2013, 12:02 AM   #5643
What's his Face
lost as
What's his Face's Avatar
Oddometer: 3,631
yep.. parts come quick coz owners need lots of 'em
Remember Abe Lincoln said "Don't believe everything you read on the internet."
What's his Face is offline   Reply With Quote
Old 02-21-2013, 02:40 AM   #5644
KASUYAHO
Road Hog
Oddometer: 3,641
Cheers Poppy
Yep it's good how Honda have great backup compared to the lesser brands
Have you had much experience with Mousse tubes ?
KASUYAHO is offline   Reply With Quote
Old 02-21-2013, 03:56 AM   #5645
slickwill
Exhiled
Oddometer: 209
Originally Posted by Lostsaffa View Post
Thanks Slickwill, this will add integrity to the 1x build for sure - an actual genuine floating rotor that Johnny Campbell raced with on his N2 bike! Plus a US spec front brake with the WC bling :)
Awesome. I was sad to let it go but I knew that I wasn't going to use it anytime soon since I upgraded to a 320mm rotor.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 02-21-2013, 11:46 PM   #5646
KASUYAHO
Road Hog
Oddometer: 3,641
Slickwill,
You posted up a pic awhile ago of a part of your bike bolts that were wired
so they don't come loose.
Could you post up a list or pics of the area's that JC / Honda have used wire.
If you could that would be great.
Old 02-21-2013, 11:48 PM   #5647
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,514
iam probably wrong, but wire is normally an anti tampering measure for scrutineering
Old 02-21-2013, 11:56 PM   #5648
KASUYAHO
Road Hog
Oddometer: 3,641
Thinking about getting one of these
http://www.gumtree.com.au/s-ad/north...ols/1011968340
Old 02-22-2013, 12:06 AM   #5649
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,391
drop the hammer on this Glenn ...same shit just no leavers another cheap crap
http://www.torpedo7.com.au/products/...h-bead-breaker
do it now while its on sale
Sean-0 is offline   Reply With Quote
Old 02-22-2013, 01:00 AM   #5650
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 656
There are two types of wire. One is 'wire-locking' and the other is 'tell-tale wire'. Wire locking is to prevent parts coming loose all over the race track and to prevent parts coming off in the first place. Usually wired in a tightening direction. Tell-tale is to alert anyone to the use of something. Mainly used on aircraft to indicate if a vital switch has been operated, primarily to show engineers that whatever was set off needs replacing (ie. flares or fire extinguishers). In Motorsport this can also be for in built fire suppression systems.
Tell-tale is designed to break when tampered with, wire locking is much stronger to try and resist breaking. Apologies for the geeky info, but wire-locking is something I have done too much of :)
Old 02-22-2013, 03:06 AM   #5651
GSXR
Trail Rider
Oddometer: 882
That's pretty cheap for a handy bit of kit. Have you got / used one of them Sean? I'm staying old school for now and sticking with the levers on the floor. Bloody good practice for out in the field. A few of my mates have never changed a tyre, so I either get them to come over when I am doing mine or demo on their ones. Good way to earn a carton.
Glenn, I read a write-up somewhere saying these were the go. Supposed to be real durable.
http://www.4enduro.com/mousse-tubes.html
Has anyone here used them? Thoughts?
GSXR is offline   Reply With Quote
Old 02-22-2013, 03:14 AM   #5652
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,391
you thinking mousse as well ... glenn pricked my mind on that ....no i havent got 1 of those changers thingy's .....i hate to say this but i have never had a flat on a motorcycle in my life ...touch wood ...i have however ..changed a few in the yard ....lets say it was an all day event ...but however,i did get the bloody thing on in the end
Old 02-22-2013, 03:53 AM   #5653
TB650
Would be Adventurer
TB650's Avatar
Oddometer: 752
I have tried them the Littswood ones and Pirelli one and end up back with the Michelin ones. More expensive but they last best IMO. Use good lube, not rubber grease but the genuine Michelin lube if you can. They need to be lubed regularly and keep the wheels of the ground when parking the bike for a period of time. Fronts are easy to change, rears you will need that tyre changer.
personally on my XR and the KTM I only run fronts now as heat and speed damages a mousse and they need replacing regularly. On the rear a ultra-heavy duty tube Michelin or Bridgestone will see you through.
Glen I never ran Mousses at Condo, Yellow Mountain or any of the faster events I only used them trail riding, A4DE, club rounds etc. They are confidence inspiring in the rocky going, you just wind the damper up and hold it pinned. Harder to dent rims also as they don’t compress like an air filled tube.
They also seem to last better in Michelin tyres from experience. When I did the 4 day in 2006 we were supported by Maxxis tyres and I had a 2 day old front mousse fail day two. Also most blokes use rim locks with them, I never bothered. They didn’t seem to spin on the rim and even if they did I figured there isn’t valve to rip out.
Good luck
TB
XTZ660, WR250R Prerun bike awesome!, ex GHR XR650, A second XR650R and the mighty CT110
www.rideadv.com.au
TB650 is offline   Reply With Quote
Old 02-22-2013, 03:58 AM   #5654
GSXR
Trail Rider
Oddometer: 882
One memorable day in 2000 on the cape I had to fix 11 flaties. Punters all hit the same sharp edge at speed. Bloody knuckles and pump arm pump. Remind me on the CSR trip to tell you about the 'rock painting' that the boys created to pass time. Hilarious.
Hey I'm bored with my avatar / pic etc. How do I change it? Cant seem to get in the right place.
GSXR screwed with this post 02-22-2013 at 04:05 AM
Old 02-22-2013, 04:41 AM   #5655
KASUYAHO
Road Hog
Oddometer: 3,641
Cheers TB for chiming in.
Why keep the wheels on the ground when parked for a period of time ?
I had issues with the ULTRA heavy duty tubes, being that they get hot
with high speed running, the outer of the tubes seems to rub off and then they start to leak, Robby Turton experienced the same, so run heavy duty tubes.
Glen I never ran Mousses at Condo, Yellow Mountain or any of the faster events I only used them trail riding, A4DE, club rounds etc. They are confidence inspiring in the rocky going, you just wind the damper up and hold it pinned. Harder to dent rims also as they donít compress like an air filled tube.
What do you mean by don't compress like air filled tube ?
Whats the feel.
Yep i heard that, matching the inner profile of the tire i believe,
different non matching profile to inner, more movement, more fiction,
more heat etc.
I'll run Desert rear 140/90/18.
HP4 front with a 1.80/21 rim i am thinking, GHR.
When I did the 4 day in 2006 we were supported by Maxxis tyres and I had a 2 day old front mousse fail day two. Also most blokes use rim locks with them, I never bothered. They didnít seem to spin on the rim and even if they did I figured there isnít valve to rip out.
Did you balance the wheel ? not saying that was the problem.
Good luck
Cheers
TB
Times are GMT -7.   It's 03:29 PM.
