Go Back   ADVrider > Riding > Regional Forums > Australia
Old 04-24-2013, 01:42 AM   #6061
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,284
Originally Posted by Smithy69 View Post
Hey cruz, went Imbil, Elgin Vale, West & East Branch, Monsidale, Jimna, Sunday Creek. Found heaps of single track stuff, was quite tough in places.
Still wet and slippery here and there?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 04-24-2013, 05:39 PM   #6062
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,656
little bit biased I know, but they are still a good lookin dirt bike.
do you like it?
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 04-24-2013, 08:39 PM   #6063
DRjoe
DRjoe's Avatar
Oddometer: 5,315
Well done doug very nice job mate.
What's next?
And yea digga there not a bad looking motorcycle.
Old 04-25-2013, 01:17 AM   #6064
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,562
do you like it?
If I was done and dusted on the KLX's I would be all over one of these.
Fogo72 is offline   Reply With Quote
Old 04-25-2013, 01:22 AM   #6065
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,512
fogo time to upgrade mate
looks good doug ....thanks for the lil test ride today ...it goes well
Sean-0 is offline   Reply With Quote
Old 04-25-2013, 02:54 AM   #6066
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,387
Thanks all, its been a bit of a project thats for sure. One of those jobs were you just keep replacing things until just about everything is new. Still got a way's to go, but at least i can ride it while i get the rest sorted.
Got to take it for a ride today. Had a fun few hours out and about getting to know it and only lost 3 things. Lost the 2 speedo nuts and the rear brake pad pin cover screw. So not to bad, no oil leaks, no water leaks and it still goes, whoo hooo.
1st light of day since i bought it home
Heading up toward Mt Tamborine. Plenty of whoa boy's on this track to test the suspension.
Up at the lookout on Mt Tamborine
Nice place here. There were a couple of people just about to load some canoes into the water for a paddle.
Found some long grass to play in
Back at home, most things in tack
poppy screwed with this post 04-26-2013 at 05:49 PM
poppy is offline   Reply With Quote
Old 04-25-2013, 03:17 AM   #6067
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,284
So, compared to your Husky, how is it Poppy?
xronly
Old 04-25-2013, 03:43 AM   #6068
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,387
G'day Bruce, different bike to ride. Feels bigger than the 610, it feels like it has more torque and power than the husky, which it should, i need to have a play with the carb still. The brakes have less feel to them than the husky, but that is probably more personal and just need time to adjust. Ha, and get this, no magic button, not sure on this yet.
poppy screwed with this post 04-25-2013 at 04:31 AM
Old 04-25-2013, 09:58 PM   #6069
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,512
Looking for a rad guard for the right hand rad ... mine fell off
Old 04-26-2013, 04:16 AM   #6070
ditchwitch650
ditchwitch650's Avatar
Oddometer: 918
does it still have the rubber front brake line mate? they need to be upgraded to braided to get any real power to the caliper, from memory that bike already had a 280mm oversize ebc rotor, they don't stop any better till the line is upgraded
jetting
68S pilot S is for small hole, I think they are Honda genuine only.
170main
2 turns out on the air screw then fine tune,
stock needle on 3rd clip down (middle clip)
trim the float level up (less fuel) about 2 or 3mm from spec
ditchwitch650 is offline   Reply With Quote
Old 04-26-2013, 06:07 PM   #6071
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,387
G'day Ditchy, yeah mate it has the 280 rotor and rubber Michirin hose on it, which i would assume as standard. I will have a look into the braided line for sure. Dont see there is much to be gained from just adding the large rotor apart form surface area, caliper can still only apply so much pressure.
Thanks for the tips on the carb, no idea how it is set up, just as it was when i bought the bike, so will pull it apart and have a play.
Old 04-26-2013, 07:55 PM   #6072
ditchwitch650
Oddometer: 918
shame lostsaffa just sold a good 2nd hand goodridge braided line a few weeks ago,
You can get Goodridge brake lines in several color options from most bike shop they are supplied by John Stamos I think it is,
I have had 1 made at Enzed before, the braided lines from USA will fit but aren't quite right and end up having a half twist in them as they run A different master cylinder crf style
grab the rubber line as you squeeze the lever you will most likely feel it bulge as it pressures up
Old 04-26-2013, 08:43 PM   #6073
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,284
You can get Hela braided lines off of their website and they are local around Redcliffe or Scarborough some where. Good price too, fitted one to the Transalp.
xronly
Cruz screwed with this post 04-26-2013 at 08:51 PM
Old 04-27-2013, 05:08 AM   #6074
slickwill
Exhiled
Oddometer: 209
I run a Goodrich on mine. I've had a few brands of SS lines over the years and I really like the build quality of the Goodrich.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 04-27-2013, 02:07 PM   #6075
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,962
http://helperformance.com.au/
Yeah I second that Cruz. I have bought several lines from HEL. Grat to deal with Brisbane based. He has made custom brake lines when I needed extra length, also made a clutch line for a KTM for half the price of an OEM one.
Joe
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Times are GMT -7.   It's 07:12 AM.
