Old 06-11-2013, 01:06 AM   #6271
alamo
are we there yet?
alamo's Avatar
Oddometer: 66
Cheers for that Smithy, what wattage Leds did you go for
stay upright
alamo is offline   Reply With Quote
Old 06-11-2013, 03:26 AM   #6272
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,567
I have a light bar that is supposed to draw 42w running pretty much straight off the rec/reg. have run it a few times in a couple of hours stints and hasn't broken yet.
broom broom
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 06-11-2013, 04:17 AM   #6273
GSXR
Trail Rider
Oddometer: 920
I don't know what wattage they are. A mate got 'em for me while he was in Canada.
Here's a pic of what they look like. Jetco is the brand, and I don't see them in their online products list.
HP shows when go flat strap
GSXR is offline   Reply With Quote
Old 06-11-2013, 04:24 AM   #6274
KASUYAHO
Road Hog
Oddometer: 3,651
You running the standard stator Smithy ?
KASUYAHO is offline   Reply With Quote
Old 06-11-2013, 03:55 PM   #6275
GSXR
Trail Rider
Oddometer: 920
Yes, standard stator. The only time I've ever considered a stator upgrade was whilst negotioating the Vic High Country & Kosciusko NP in the snow & ice. Hmmm, heated grips would be nice I thought. Snapped out of it pretty quickly though. Not an option for a bloke whose mantra is Keep it Stock.
Old 06-11-2013, 05:07 PM   #6276
DustyJohn
DustyJohn's Avatar
Oddometer: 63
From Jetco Site
Part #: 123-80000S-8 Spot version
Part #: 123-80000F-8 Flood Version
Do you you have the floods or the spots Smithy?
DustyJohn is offline   Reply With Quote
Old 06-11-2013, 05:57 PM   #6277
GSXR
Trail Rider
Oddometer: 920
Nice one DustyJohn. They are the spots.
http://jetcolighting.com/?q=node/203
So, would these be considered a relatively low current / power draw light compared to others?
Old 06-11-2013, 08:42 PM   #6278
DustyJohn
DustyJohn's Avatar
Oddometer: 63
0.31 amps each is a very low current. Combined the two lights are only using about 8 watts of power in a 12v system.
Old 06-12-2013, 04:19 PM   #6279
GSXR
Trail Rider
Oddometer: 920
That's a good result then I'd say. How do you work that wattage stuff out?
I'll have a look for Montana GPS current draw, then we'll know the total.
The GPS worked a treat, except vibrations got to it a bit on the higher revs sections. I used the Ram cradle and wiring package, and it wasn't isolated at all really, just a u-bolt around the bars. Am in the process of modifying a Nolathane sway bar bush from my falcon. Plan is to just slip the same ram u-bolt over the bush and give it a try on the next ride.
Old 06-12-2013, 05:27 PM   #6280
KASUYAHO
Road Hog
Oddometer: 3,651
volts divided into watts = amps
eg:
12 volts / 6 watts = .5 amp
12 volts / 12 watts = 1 amp
12 volts / 24 watts = 2 amps
12 volts / 100 watts = 8.33 amps
24 volts / 100 watts = 4.16 amps
240 volts / 100 watts = 0.416 amps
Old 06-12-2013, 08:21 PM   #6281
DustyJohn
DustyJohn's Avatar
Oddometer: 63
Was going to ask if it was the Montana . Isolating vibration can be tricky with a ram mount. Another option would be to use a hydraulic pipe mount on the handle bars then the Ram Mount which would isolate some of the vibration?
Old 06-12-2013, 10:44 PM   #6282
GSXR
Trail Rider
Oddometer: 920
Cheers Glen. I'll remember that one.
John, hydraulic pipe mount indeed could be the answer. I'll try Nolathane and see what happens. It's such a pretty red.
Old 06-12-2013, 11:38 PM   #6283
DustyJohn
DustyJohn's Avatar
Oddometer: 63
Look here Smithy ( http://youtu.be/GfWrFKUyEvY ) it can be fixed with a cheque book!
Old 06-13-2013, 03:15 AM   #6284
GSXR
Trail Rider
Oddometer: 920
Yeah a few people on the recent ride suggested the Touratec setup. Broke up the visa card a few weeks ago.
Old 06-16-2013, 02:28 PM   #6285
DustyJohn
DustyJohn's Avatar
Oddometer: 63
Is this correct???
Paint it black.
Oddometer: 13,021
I hope you didn't spend much time or money on the cush hub conversion because the XRR already has a cush drive that is the best ever made...it's on the clutch.
Have you ridden it much with the double cush? Seems like it might have a lot of drivetrain slop now?
Times are GMT -7.   It's 06:24 PM.
