Old 07-11-2013, 11:52 PM   #6346
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,238
Originally Posted by patrick1 View Post
good idea about the lines, forgot about them. But how quick is quick? It requires 500km oil changes anyway, are we talking like running the engine up to temp then dropping the oil?
hose? As in water? Looks like im gonna need to borrow a compressor. This is what my oil screen looked like when I took it out
brake cleaner would be good cause it evaporates, but degreaser usually does a better job when Im cleaning stuff, would the residue left in the frame from degreaser hurt anything I wonder
I'm a big fan of petrol for cleaning stuff but it is not usually advised because of it's volatility.
I'd be filling the tank to nearly full and giving it a bit of a shake to loosen stuff sticking to the sides. Drain...let settle then do it again using the same petrol leaving the sediment in the container.
Repeat.
Then renew petrol. Follow above procedure. Drain
Then renew petrol once again. Drain.
Dump petrol in creek and throw a match to it or leave it in a separate marked container until you need it for something.
I normally pour it around the boundary to kill weeds.
If you can get your hands on one of those cheap chinese compressors, they are plenty good enough for most jobs in the shed
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 07-11-2013, 11:53 PM   #6347
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,238
Originally Posted by digga1111 View Post
pull the screen in the frame and flood it with kero. fill it up, slosh it round, and drain it into a clean container. let it settle for a minute or two and look for metal in the bottom of the container. repeat. when you stop seeing metal in the bottom of the container......... stop
You copied what I said...only you said it first
Old 07-12-2013, 12:09 AM   #6348
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,545
Gday Wayne, hows it going mate? knocked off any kids chips lately.
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 07-12-2013, 01:11 AM   #6349
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,238
Hey Rick. Don't do chips anymore. Too dangerous
I'm going good thanks mate. And you?
Old 07-14-2013, 03:33 AM   #6350
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
Team Honda's lead rider dropped over today to play broom brooms with my broom broom ......he was all over it like a fat kid a lamington
Seems the last person inside my carb broke the top rubber seal on the slide cap ...then thought it would be a good idea to fix it with some black silicon .....it was peeling off into the carb
The lead rider was not happy ..nor was I .....my slide has scuff marks on it ...got swapped out ...moved the c-clip back to the middle notch ...air mix out 1 3/4 out ...its better but the lead rider is still not happy ...there may be a valve issue
Lead rider is coming back again tomorrow for more broom brooming ......
Smithy ...your a fucking good bloke mate .....
Sean-0 is online now   Reply With Quote
Old 07-14-2013, 04:37 AM   #6351
GSXR
Trail Rider
Oddometer: 914
The main concern in life would idealy be "how am I going to keep tyres up to this thing?"
That's the aim....
....we are not talking about a ride around the block here. 8000km+
Team Honda needs an injection, and it's up to you lol
HP shows when go flat strap
GSXR screwed with this post 07-14-2013 at 04:45 AM
GSXR is offline   Reply With Quote
Old 07-14-2013, 11:05 PM   #6352
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
Smithy .....ya fixed it bro ...goes like it should
Old 07-15-2013, 12:00 AM   #6353
patrick1
patrick1's Avatar
Oddometer: 49
rebuilt pig
so now that that im about to fire up the engine for the first time since the rebuilt, how long / far should i run it before changing the oil / filter?
patrick1 is offline   Reply With Quote
Old 07-15-2013, 12:17 AM   #6354
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
think poppy ran his for a 100kms then drain cleaned screens ...then 500kms drain clean screens ...
how many km did it have for the rebuild ? what happened
Old 07-15-2013, 12:53 AM   #6355
patrick1
patrick1's Avatar
Oddometer: 49
about 16,000kms, I bought it at 10,000km.
i was changing the oil an found magic gold dust in it, ann bigger bits in the screen. It did the big end bearing
Old 07-15-2013, 01:03 AM   #6356
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
sumofabitch ......was not looked after? ran low on oil ...do any go fast bits to the new motor
Old 07-15-2013, 01:03 AM   #6357
GSXR
Trail Rider
Oddometer: 914
Good stuff!
Old 07-15-2013, 01:36 AM   #6358
What's his Face
lost as
What's his Face's Avatar
Oddometer: 3,631
is 16000 kms good for an xr
Remember Abe Lincoln said "Don't believe everything you read on the internet."
What's his Face is offline   Reply With Quote
Old 07-15-2013, 01:54 AM   #6359
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
shut up hillbilly
Old 07-15-2013, 02:26 AM   #6360
What's his Face
lost as
Oddometer: 3,631
shut up hillbilly
i didnt realise that the rules had changed here on advrider and personal attacks were allowed..
it's a real shame when a fellow enthusiast can't ask a legitimate question about the longevity of the xr
i was all set to buy one, but you sir, have made me think again
Times are GMT -7.   It's 03:22 PM.
