Old 07-15-2013, 02:30 AM   #6361
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,439
hahahahaa ..nicely played
Sean-0 is offline   Reply With Quote
Old 07-15-2013, 02:51 AM   #6362
What's his Face
lost as
What's his Face's Avatar
Oddometer: 3,633
as if i'd buy an xr
i still like girls.. but when that changes sean.. you'll be the first to know
Remember Abe Lincoln said "Don't believe everything you read on the internet."
What's his Face is offline   Reply With Quote
Old 07-15-2013, 03:25 AM   #6363
slickwill
Exhiled
Oddometer: 209
Originally Posted by patrick1 View Post
so now that that im about to fire up the engine for the first time since the rebuilt, how long / far should i run it before changing the oil / filter?
Did you clean or replace the oil lines/tube and flush the frame?
I changed mine the first two times after about 50 miles.
Sent from my DROIDX.
slickwill is offline   Reply With Quote
Old 07-15-2013, 05:41 AM   #6364
patrick1
patrick1's Avatar
Oddometer: 48
yes and yes.
http://www.youtube.com/watch?v=pIacbpwzLzo
patrick1 is offline   Reply With Quote
Old 07-15-2013, 02:13 PM   #6365
GSXR
Trail Rider
Oddometer: 920
Originally Posted by What's his Face View Post
as if i'd buy an xr
i still like girls bikes.. but when that changes sean.. you'll be the first to know
Fixed.
HP shows when go flat strap
GSXR is offline   Reply With Quote
Old 07-15-2013, 06:26 PM   #6366
Crobbo
Oddometer: 13
Hi Guys,
Newish owner here long time lurker. Got sick of my XR400 so grabbed a 650.
What a beast. When its running at-least.
Bike got yellowed with the Staintune exhaust so I swapped back to the Honda muffler with competition baffle. Now it looks stock but the sound isn't.
Problem is it just wont start and run easily.
I've had the carb off and had that ultrasonically cleaned, 175 main 68s pilot 2.5 turns on the idle air and I think B53 needle.
List to do until I'm really stumped.
Fix float valve which seems to leak in some positions and check out that ACV valve. I hope it wasn't damaged in the cleaner.
Also I seem to be hitting a second TDC at the bottom of my kick which didn't happen when I bought it.
Crobbo is offline   Reply With Quote
Old 07-15-2013, 06:31 PM   #6367
Crobbo
Oddometer: 13
A pic for good measure.
Old 07-15-2013, 06:36 PM   #6368
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,439
1.5 turns out on air mix set valves to 0.006 inlet 0.008 exhaust set float to 18mm
Sent from my phone while swerving over the road in my car
Old 07-15-2013, 07:08 PM   #6369
Crobbo
Oddometer: 13
Cool mate Ill try that, valves checked out ok but Ill have another look. I think it may have a hotcam.
Old 07-15-2013, 10:22 PM   #6370
GSXR
Trail Rider
Oddometer: 920
I fucked up the valve clearances 1st time round on seans bike on the weekend Crobbo. He's got a stage 2 hotcam in there and it threw me a bit at first just finding TDC the way I always have, just used to working on stock stuff. It feels alot different & was good to learn.
So I'd pay particular attention to finding TDC, ie valve covers off so you can be sure they're not rocking, ie wrong stroke, and someone to look in the timing hole to be sure while you're rolling the kickstart through compression.
Make sure needle is B53E & clip in middle slot. Check the throttle slide. Any sign of wear will usually result in poor idle type problems.
Make sure cables have free play.
Take alot of care to set the float valve to 18mm and you should be right.
Old 07-15-2013, 11:26 PM   #6371
GSXR
Trail Rider
Oddometer: 920
So is it all good Sean? Have you started packing the bike yet or what.
Old 07-15-2013, 11:41 PM   #6372
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,439
not yet mate..got to install fuel filters and change loops out ....change oil and wash the bike ....zac is packed ..but he wants to unpack and lay everything out again...he knows I tend to forget shit
got last of the supplies today .....so all set ..gunna wag work on Friday and get into it ....we head of sunday morning
Old 07-15-2013, 11:57 PM   #6373
QDogg
QDogg's Avatar
Oddometer: 223
Originally Posted by Smithy69 View Post
I fucked up the valve clearances 1st time round on seans bike on the weekend Crobbo. He's got a stage 2 hotcam in there and it threw me a bit...
I have the stage 2 hotcam as well, did my valves a few weeks ago.
Couldn't see shit through the inspection hole, and too much rooting around taking the bash plate off to get the stator cover off.
I went with the plug out option with a straw in the hole to find TDC and that worked fine for me.
Hope this helps.
Husqvarna Nuda 900
QDogg is offline   Reply With Quote
Old 07-16-2013, 12:20 AM   #6374
GSXR
Trail Rider
Oddometer: 920
Yeah I agree Q, forget taking the cover off. TDC through the plug hole is easily accurate enough. the main thing I reckon is to be looking at the valve movement at the same time. It caught me out, but I am no guru.
Old 07-16-2013, 12:49 AM   #6375
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,439
shit not a guru .......that's the last time I ask you to sort my bike out ..like ya did on the weekend and got it ticking like a clock
if ya ever do take the stator cover off ..get some white paint pen or liquid paper and mark your T ....then you can see the mark easy through the sight hole ...the 2 lil marks in the hole is where the T lines up with
but I also use the zip tie down the plug hole .....
Times are GMT -7.   It's 09:41 AM.
