Old 10-26-2013, 03:46 AM   #6601
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 644
Originally Posted by digga1111 View Post
how does that one work?
Good question, I dug a little deeper and found very little, but did find this:
https://www.denniskirk.com/medialibr...age&sku=196719
So my guess is it adds oil capacity by filling the heat-sink with oil, which is then cooled by the increased air flow. It looks like you then have the ability to bleed the heat-sink as it becomes the highest point of the system.
and then a heat sink solution like this which is a simple stick on item:
http://michiganoffroadproducts.blogs...er-cooler.html
Then lastly, an air duct solution:
http://www.crfsonly.com/catalog/popu...e.php/pID/2501
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 10-26-2013, 04:00 AM   #6602
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,457
I wonder if and how much these additional reservoirs change the brake feel. would it make the pedal spongy?
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 10-26-2013, 04:07 AM   #6603
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 644
As long as they are rigid inside, the theory of hydraulics suggest that is should make no difference to the feel at all, but I would try and find someone who has tried them.
The in-line banjo ones mentioned first seem to be the most commonly used.
Old 10-27-2013, 01:47 AM   #6604
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,457
had a look at the caliper today. looks like the only one that will work is that stupid stick on the top thing
Old 10-27-2013, 04:05 AM   #6605
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,216
What about trying a different fluid Digsta...one with a higher boiling point or get a better front brake perhaps
A vewwy good fwiend in Wome
Big Willy is online now   Reply With Quote
Old 10-27-2013, 04:29 AM   #6606
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,457
I have put the highest temp boil stuff in it now. maybe I will just ride up hill from now on.
Old 10-27-2013, 06:25 AM   #6607
jm-2008
jm-2008's Avatar
Oddometer: 507
Digga1111 - Brake Fade
[QUOTE=digga1111;22645429]I have put the highest temp boil stuff in it now. maybe I will just ride up hill from now on.
Have similar issues on occasion here in Vic on very long/steep down hills ie Billy Goats Bluff track dropping from 1400m to the river in not many Kms.
Tried a variety of brake pads but same issue.
Put DOT5 fluid in and still the same issue (pedal loses pressure and needs to be pumped to get any reaction).
Shortly after purchasing the XR I had some significant brake fade front & rear.
Fixed the front with an oversize BRAKING rotor, replaced the rear pads and removed the wear indicator (thin metal insert between pad and piston) as I have removed this on other XR's I've owned reasoning that with it gone heat would dissipate from the pad to caliper and fluid more efficiently however I'm rethinking my logic on this issue after experiencing brake fade again on the rear.
Refitted the wear indicator prior to the last ride but that was a three day in the Flinders Ranges and we had nothing like Billy Goats Bluff track to check for fade.
Interested to know if you have the wear indicators fitted?
JM-2008
jm-2008 is offline   Reply With Quote
Old 10-28-2013, 01:56 AM   #6608
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,457
http://www.braking.com/catalogue/intro.php?lang=EN
Old 11-09-2013, 02:56 PM   #6609
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 471
Hi Lostsaffa how is the build going ?
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 11-09-2013, 03:52 PM   #6610
*nick*
*nick*'s Avatar
Oddometer: 360
Question
g'day lads,
I've put 26,000 clicks on my XR250R and want to go up a few sizes as i'm mostly on the open road nowdays and have a big 2 month solo trip planned for 2014, are there any things in particular I should be looking for when inspecting second hand BRP's?
I own a few bikes, including two old 1940's BSA's, I have a reasonable idea as to what to look look for when inspecting used bikes but I was more interested in if there were any unique BRP tell tale signs of abuse, misuse or lack of maintenance?
I'm mostly looking for something close to original or with a documented service history, big kay's on a bike don't scare me off as long as it's been serviced accordingly.
Any honest help or advice for me being a young fella would be greatly appreciated.
-nick
have bike, will travel.
*nick* is offline   Reply With Quote
Old 11-09-2013, 04:15 PM   #6611
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,348
growelly has 1 forsale in tassie .....looks the goods
but if looking ...look at chain tension bolts in swingarm ..under swingarm for chain wear under the chain slider ....under rear fender for subframe tweaks ..right hand footpeg ..model dependent the clutch bushing...2000 and 2001 models ....when you have purchased look at the pig pen to find all its lil issues and fix them b4 they bite ya
http://www.xr650r.us/
Sean-0 is offline   Reply With Quote
Old 11-09-2013, 07:49 PM   #6612
GSXR
Trail Rider
Oddometer: 861
Nick,
Your main priority should be to get one that has not been dicked around with. Idealy a dead stock example with service history, as you mentioned. The km's advertised are rarely genuine, so look for signs that support a low km bike, wear and tear etc.
If is going to be a keeper we can help you do the mods to make it handle and be bullet proof. Don't touch anything with a dodgy sounding engine. This is the best part of these bikes & if you never have to open it up, you're likely onto a winner.
Let us know what you find.
HP shows when go flat strap
GSXR is offline   Reply With Quote
Old 11-09-2013, 11:47 PM   #6613
QDogg
QDogg's Avatar
Oddometer: 195
Sad, day...
Mines up for sale.
http://www.advrider.com/forums/showp...&postcount=159
Husqvarna Nuda 900
QDogg is offline   Reply With Quote
Old 11-09-2013, 11:59 PM   #6614
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,348
like you said ...your gunna regret it
goodluck with its sale ..i recon its a steal
Old 11-10-2013, 12:43 AM   #6615
QDogg
QDogg's Avatar
Oddometer: 195
Cheers!
In a perfect world I'd keep it and buy another, but as we all know...
Money doesn't grow on trees.
Husqvarna Nuda 900
Times are GMT -7.   It's 06:28 PM.
