Go Back   ADVrider > Riding > Regional Forums > Australia
Old 03-31-2014, 08:04 AM   #7276
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 667
Originally Posted by ditchwitch650 View Post
yeah i have in line relays already per pair isn't to bad i pay $30 a pair for my rubber mounts that i have now
Definitely worth it - I have already ordered a set in a group buy, only $15 USD for delivery flat rate.
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 04-01-2014, 12:55 PM   #7277
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,510
Pigs at work
Sean-0 is offline   Reply With Quote
Old 04-01-2014, 06:15 PM   #7278
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,387
Doesn't surprise me they keep you in the basement away from everyone else.
poppy is offline   Reply With Quote
Old 04-01-2014, 07:23 PM   #7279
jm-2008
jm-2008's Avatar
Oddometer: 517
[QUOTE=poppy;23834710]Doesn't surprise me they keep you in the basement away from everyone else.
No low speed trees in the basement so no risk for a high speed XR!
JM-2008
jm-2008 is offline   Reply With Quote
Old 04-01-2014, 07:56 PM   #7280
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,654
The gimp
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 04-01-2014, 10:03 PM   #7281
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,510
asshole's
Old 04-03-2014, 10:38 PM   #7282
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,654
suspension questions
what are the differences in the shock from stock to the lengthened ones teknik did for the safari bikes?
what changes to the forks if any happened with the longer shock? (how did they compensate for the changes in the bikes geometry)
what where the reasons for the longer shock?
did any of the American baja racers use a longer shock?
Old 04-03-2014, 11:56 PM   #7283
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 667
I can't say anything for the safari bikes, maybe Kasa knows?
However, the Baja bikes had the CR500 hybrid which made the shock about an inch taller (which with the lever arm ratio made it quite a bit higher at the back). I read somewhere that Johhny Campbell had special forks with longer fescalised portions to make the front end higher, but the ex Baja race team forks I have are stock length so I am not too sure.
Without riding my bike I can say that it feels very balanced with the higher rear end. The reasons for the longer shock were varied, but the main reason for using the CR500 shock body was for the extra oil capacity for cooling and the high speed adjuster.
Hope this helps a little :)
Old 04-05-2014, 12:08 AM   #7284
AussieDaz
Oddometer: 59
Does anyone run Conti TKC80's on their 650R?
Does anyone happen to know what sizes I need for front and rear? There's about 4 different ways of measuring tyres and I can't work out what I need!
AussieDaz is offline   Reply With Quote
Old 04-05-2014, 11:28 PM   #7285
KASUYAHO
Road Hog
Oddometer: 3,790
Both bike suspensions topped out Digga to show the different heights.
The reason why Nick changes the length of the shock for is ment to change the steering geometry as well as a few other things.
The yanks Baja bikes shock was longer than stock.
KASUYAHO is online now   Reply With Quote
Old 04-05-2014, 11:57 PM   #7286
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,654
we measured poppys, seanos and my bikes topped out last weekend and poppys measures 40mm higher. I don't know how.
Old 04-06-2014, 12:06 AM   #7287
KASUYAHO
Road Hog
Oddometer: 3,790
What do you mean you don't know how ?
Where the rear wheels off the ground when you measured them ?
Old 04-06-2014, 12:08 AM   #7288
KASUYAHO
Road Hog
Oddometer: 3,790
Old 04-06-2014, 12:22 AM   #7289
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,654
measured from the concrete to underside of rear indicator bracket with the shock topped out. his static and race sag is also 40mm higher then ours.
is it missing a spacer or stopper or something or has it been modified?
Old 04-06-2014, 12:54 AM   #7290
GSXR
Trail Rider
Oddometer: 969
Steal subframe from bike A & see if it changes bikes B & C.
This thing is getting out of control
GSXR is offline   Reply With Quote
Times are GMT -7.   It's 01:05 AM.
