Old 03-12-2009, 05:40 PM   #1
escuchamente OP
Let's Ride
escuchamente's Avatar
Oddometer: 492
Question Steering Stabilizer on KLR?
Has anyone tried mounting a steering stabilizer/damper on a KLR 650 whether a Scotts or other make?
http://www.scottsperformance.com/pho...in.php?ID=1309
http://www.scottsperformance.com/damperinfo.php
If so, what are your thoughts. Would it be better to spend the $400 on front suspension work, stabilizer, both?
Not looking for what people "think" about it or what people have done in lieu of suspension/stabilizer work. ONLY LOOKING FOR ADVICE FROM PEOPLE WHO HAVE ACTUALLY DONE IT. Thanks,
E
Dual Sport Riding Techniques
Advanced Dual Sport Riding Techniques: The DVD!
Proud to be Riff Raff, forever! Thanks Charlie, Rob, Niles & Jonah for a great ride.
escuchamente screwed with this post 03-12-2009 at 11:21 PM
escuchamente is offline   Reply With Quote
Old 03-12-2009, 07:52 PM   #2
Beezer
Oddometer: 5,874
Wondering why... if it's because of high speed wobblies there are a few things to try first (your stem bearings are set correctly).... raise fork oil level to 170mm and 10psi air costs about $10 for the Belray 10wt. After that a fork brace for about $100. Those are the most cost effective, bang for the buck front suspension upgrades out here. Mebby progressive springs like Moab.... better yet get a Moab rear shock.
Beezer is offline   Reply With Quote
Old 03-12-2009, 11:25 PM   #3
escuchamente OP
Let's Ride
Oddometer: 492
Bluhduh Thanks but...
Looking to hear from people who have tried it.
Old 03-13-2009, 07:15 AM   #4
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,925
I'm guessing you'll be hard pressed to find many........... mostly because the KLR generally doesn't need it. Ok, it just doesn't need it. Look for the most farkeled out gear whore riders and you still won't likely find a $400 scotts on a KLR...........
You answered your question in the first post. First spend the money on the suspension. (applies to almost any bike really) Progressive springs at a minimum on any KLR IMO. If that's not enough gold valves or a fork swap to something good. I've found the progressives to be just fine. Then beef up the rear, I've got the 420 rear now and it's nice even tho I never did manage to kill the stocker............
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 03-13-2009, 08:25 AM   #5
Rover31
formerly tdfox
Rover31's Avatar
Oddometer: 663
Really???
If you are getting headshake under power or are trying to calm the jolt of rippin through rocks I'd say it's time for you to get a different bike cause you are really really ridding the KLR far over what anyone else ever has. So You would need to answer why do you feel the need for a dampener?
Now that said
I would look at some gold valves or if you can get a set of KLX650 forks or???
The Gold valves have been very good on all of the bikes I have put them on.
That and some correct springs and fresh oil you would be very happy.
However don't forget about the rear shock it is just as important and it can have a huge effect on the front.
Good luck
T
03 640Adv, 08 CRF450X
87 Elite 250
TTR125LE, TTR90
KTM65SX, KX65
Rover31 is offline   Reply With Quote
Old 03-13-2009, 11:04 AM   #6
mountain eagle
terrorist
Oddometer: 2,925
Oh, and headshake under what little power a klr has is most likely a problem. Tire, air pressure, bad bearind in the wheel or headstock, something anything but too much power.............
mountain eagle
KTM 950SE
my smugmug gallery
Old 03-13-2009, 11:31 AM   #7
ShrinerDan
Helping kids walk
ShrinerDan's Avatar
Oddometer: 1,173
E
I have an idea... Since you have torn into people on TWO different forums why don't you just put one on the bike and tell us how it works or doesn't work. You're not going to find anyone that has done this because most of us KLR owners don't ride our bikes like they're all out dirt bikes because they're not. If they were supposed to be ridden that way they would already have a dampner installed.
Danael A. Zilk
Waterloo lodge #105 AF&AM
El Kahir Shrine AAONMS
High Twelve Club #46
ShrinerDan is offline   Reply With Quote
Old 03-13-2009, 01:40 PM   #8
Brandon
Brandon's Avatar
Oddometer: 194
The folks here are giving you some good advice and I agree with them completely. The KLR will greatly benefit from a suspension upgrade. I had mine pretty well tricked out to suit me at both ends and it was literally a night and day improvement. I have a Scotts on my XR400 and it has helped that bike greatly, but I never installed one on my KLR.
Why?
Because I never felt the need. I rode my KLR at a pretty good pace through all kinds of terrain after I upgraded my suspension and not once did I ever think I would benefit from a damper. The KLR, when properly set up, is a very stable bike. My money would have been better spent on some riding classes than a damper.
But what it all comes down to is you. It's your bike, your money, and you should farkle it out the way that you want to. But don't ask for opinions and then when it isn't what you want to hear, start bashing folks. That just ain't cool.
Current Rides
2008 Suzuki V-Strom 650
2002 KLR - Not quite a stocker.
Brandon is offline   Reply With Quote
Old 03-13-2009, 03:31 PM   #9
El Brad
Leave it long on top
El Brad's Avatar
Oddometer: 462
Thumb done it and really like it.
E
I have a Works Enduro Rider steering stabilizer on my KLR, not to control
head shake issues like some have talked about but to control front
wheel side deflection while riding off road. For that reason I really like mine,
kind of a safety item, helps keep the front wheel from deflecting quite
so hard or far when you hit that "gotcha" rock or whatever you did not see.
As far as how my KLR is set up suspenion wise. Forks have progressive
springs, Race Tech gold valve emulators, 10wt. synthetic oil.
Shock has stock spring, Race Tech gold valve emulators, Fox remote
resrvoir with compression adjustment. The gold valves way improve
rebound control.
For me it all works great for what I use it for, Iam happy with mine
it gets ridden mostly dirt I would say 70% dirt 30% asphalt.
I ride everything from two track dirt roads of all conditions,some
ATV trails, no single track and a lot of graded county roads.
My tire of choice is the Kenda K270.
Hope that gives you some helpful info. If you want picks of my stabilizer
install let me know. Iam headed out of town for spring break, so
will not be able to post picks for about a week.
El Brad screwed with this post 03-13-2009 at 03:44 PM
El Brad is offline   Reply With Quote
Old 03-13-2009, 03:54 PM   #10
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,269
rebound control.
I'd like to see pix of that and, if possible a link to where you got it from.
There is a thread in the hacks forum of klrworld.com where someone is asking about steering dampers on a KLR sidecar rig. He got similar answers from everyone(including me):find and fix the problem before buying a steering damper. But there are some applications where, if the bike is well sorted, a steering damper might be a welcome addition. It would be cool to see how you installed yours!
" I need to stop talking and start drinking" ...Mom
RedMenace is offline   Reply With Quote
Old 03-13-2009, 03:58 PM   #11
Zerodog
Oddometer: 1,233
Zerodog is offline   Reply With Quote
Old 03-13-2009, 04:09 PM   #12
Kbetts
Kbetts's Avatar
Oddometer: 1,259
Originally Posted by mountain eagle
I Ok, it just doesn't need it.
+1
Check oil level in forks
Check air pressure in tires
Check chain tighness
Adjust SAG (Rear first, then front) You may need a new rear spring. You can use air in the front.
Front fender may be loose, alternate: trim front fender, replace front fender
Torque steering stem nut
Done..
If you are bottoming or topping your suspension, you need to upgrade. If not, it's fine.
We're all sheep gone astray
Originally Posted by TrashCan View Post
Hey, this is ADVrider, where facts are not real important.
Kbetts is offline   Reply With Quote
Old 03-13-2009, 05:23 PM   #13
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,766
rebound control.
I think you would agree that for the KLR the suspension upgrades would be the first thing to do before the damper though.
I have a WER on my KLX250S and had a Scott's on my Husky TE250. They really help in rocky stuff (I liked the Scott's better than the WER, YMMV).
A damper is worthwhile, but fix the suspension first.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 03-13-2009, 05:58 PM   #14
El Brad
El Brad's Avatar
Oddometer: 462
Thumb yep
to my knowledge nobody makes a damper specifically for the KLR.
The one I used was for another Kawasaki, don't remember which
one I have a call in to the bike shop that sold it to me, I will post
that info as soon as I get it. It went on real easy, with only
slight mods and a little welding to attach bracket to bike steering head
area. The damper mounts to bike between fender and bottom of triple clamp, using the same bolt holes that the fender uses, then works
using a control arm that attaches to said bracket on bike.
Old 03-13-2009, 07:22 PM   #15
El Brad
El Brad's Avatar
Oddometer: 462
Thumb damper pics
the best I can do without taking the bike apart............
Times are GMT -7.   It's 07:26 AM.
