Old 03-15-2009, 07:00 PM   #1
slowinfastout OP
Just Ridin' By....
slowinfastout's Avatar
Oddometer: 1,858
EWS Ring Antenna - Dare I Ask?
Yes, I found the Threadfest. OMG, there's like 212 pages of posts to read through. I gave up about page 9.
So here's my question that I have. I got a new spare EWS Ring to carry on my 06 GS12 after reading all the horror stories and just got it a few days ago. I see its held on by two Phillips head screws. If the EWS fails, is its a simple matter of just removing the old unit, plugging in the new and turning on the key?
Any other steps required for a field replacement?
Thanks for NOT making me read the whole 3,000 or more posts.....
Duane
slowinfastout screwed with this post 03-16-2009 at 10:21 AM
slowinfastout is online now   Reply With Quote
Old 03-15-2009, 10:53 PM   #2
JR356
JR356's Avatar
Oddometer: 3,936
I'd look closely at those screws,they are likely security screws rather than phillips.
From past reports they can be drilled out and replaced with allen or torx,then the antenna swap is easy.
Otherwise you remove the wiring connector to the existing antenna ring using a T-10 torx to get the cover off and connect to your spare antenna with your spare key wired or taped inside the new antenna(the emergency plastic key works too).
Secure the whole assembly near your ignition switch,switch on your key in the ignition switch and off you go.
Newest part number for antenna ends in -247 and is now around $35-40,used to cost >$100!
JR356
JR356 screwed with this post 03-16-2009 at 10:32 AM
JR356 is offline   Reply With Quote
Old 03-16-2009, 12:18 AM   #3
Haroon
RIDE for PASSION
Haroon's Avatar
Oddometer: 555
Ofcourse, you will have to go page by page on that old thread (like somebody here said- Maybe you need a new hobby!).
But on page 211 there is some info to get you there. Here is the link
http://www.advrider.com/forums/showt...light=antennae
Haroon is offline   Reply With Quote
Old 03-16-2009, 12:47 AM   #4
motoreiter
Oddometer: 1,243
don't forget that you need a #10 Torx wrench...
Adventure is just another word for poor planning.
http://www.motoreiter.com
motoreiter is offline   Reply With Quote
Old 03-16-2009, 07:38 AM   #5
slowinfastout OP
Just Ridin' By....
Oddometer: 1,858
Thank you Gentlemen! A 1-page answer. I do appreciate it!
Old 03-16-2009, 08:58 AM   #6
PRW
living @ 11.5740741uHz
PRW's Avatar
Oddometer: 1,092
Originally Posted by JR356
...remove the wiring connector to the existing antenna ring [insert: Using a #10 Torx to get the cover off] and connect to your spare antenna with your spare key wired or taped inside the new antenna (the emergency plastic key works too).
Secure the whole assembly near your ignition switch, switch on your key in the ignition switch and off you go.
+1. But make sure your spare's part number ends with a "-247" suffix. To my knowledge, this is the only version that has proven solidly reliable so far.
This method works as a field replacement. Obviously, if you want to permanently replace it, you need to drill out the security bolts, which I understand is a bitch.
When Im riding my motorcycle, Im glad to be alive and when I stop riding my motorcycle, Im glad to be alive. -Neil Peart
2008 R1200GS (Slate Gray Metallic Matt)
2003 R1150GS (Night Black)
PRW screwed with this post 03-16-2009 at 09:03 AM
PRW is offline   Reply With Quote
Old 03-16-2009, 07:16 PM   #7
slowinfastout OP
Just Ridin' By....
Oddometer: 1,858
OK guy, thanks so far! Now if I can prevail upon you a bit more....
I have the -247 spare, so thats all good. I went out and took the cover off (attached with the small TORX), but don't see any security screws or otherwise a way to remove the ring from the ignition switch. Does a permanent fix involve removing the handlebars and triple clamps to get to it?
TIA
slowinfastout screwed with this post 03-16-2009 at 08:25 PM
Old 03-16-2009, 07:25 PM   #8
PacWestGS
Life Is The Adventure!
PacWestGS's Avatar
Oddometer: 10,866
I have the -247 spare, so thats all good. I went out and tool the cover off (attached with the small TORX), but don't see any security screws or otherwise a way to remove the ring from the ignition switch. Does a permanent fix involve removing the handlebars and triple clamps to get to it?
TIA
Yes,
Also, you don't need to tape or attach to spare ring unless you plan on turning off and on the bike a lot. The ring antenna only affects starting the bike. You can plug in the good RA and with extra key held nearby - start the bike and unplug the RA and put it safely in your pocket. It's not needed to keep the bike running.
Russ
The world is a dangerous place to live, not because of the people who are evil, but because of the people who don't do anything about it. (Albert Einstein)
PacWestGS is offline   Reply With Quote
Old 03-16-2009, 10:40 PM   #9
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,548
TIA
Remove handlebars and top fork bridge. The bottom side of the fork bridge looks like this:
The security screws are labelled #1. Doesn't look that hard to do (but I've never done it and things I've never done always look easy )
// marc
marchyman is offline   Reply With Quote
Old 03-17-2009, 05:49 AM   #10
slowinfastout OP
Just Ridin' By....
Oddometer: 1,858
Perfect! Thanks guys....that tells me all I need to know. This forum rocks.....
Times are GMT -7.   It's 07:44 AM.
