07-02-2012, 10:35 AM
#1036 |
Thumper jockey
Oddometer: 4,025
I now use a separate primer punch and quickly remove all the primers with a hammer before neck sizing and also use a hand tool (RCBS) for re-prime.
"Get yourself to the hills and be uplifted, assuming you got some good knobbies" |
07-02-2012, 09:18 PM
#1037 | |
V4 Whore
07-05-2012, 10:37 AM
#1038 |
stevedore
Oddometer: 1,268
Question for those who cast their own bullets. Is the lead used in scuba weights usable? Reason I ask is that I have a couple of old school scuba belts and weights in the garage and if those weights are usable, I'll find a local guy who can put them to good use.
07-05-2012, 10:39 AM
#1039 | |
1.5 Finger Discount
Oddometer: 20,085
Depends, you gotta find out what their alloy content is.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
07-05-2012, 12:24 PM
#1040 | |
Thumper jockey
Oddometer: 4,025
http://castboolits.gunloads.com/showthread.php?t=31923
"Get yourself to the hills and be uplifted, assuming you got some good knobbies" doc_ricketts screwed with this post 07-05-2012 at 08:20 PM |
07-05-2012, 07:38 PM
#1041 |
Thumper jockey
Oddometer: 4,025
To repeat my earlier view that the Lee hand press and Lee collett dies are an excellent and cheap way to reload, this happened yesterday afternoon:
I was spending a couple hours shooting at the Poulsbo WA range and asked the range master if I could get my little tackle box reloading system out on the bench to reload a few rounds. He was quite interested since he had reloaded shotgun shells with the Lee hand press. Furthermore he brought down a young man recently out of the Army who wanted to get into reloading but was put off by the cost. So I sat him down and went through how easy and cheap it is to reload good ammo. We loaded five rounds in just a few minutes with instructional guidance (I did the work and he listened). After being done with five .308 rounds I shot the first two in my Savage 12 which had cooled off during the pause (good for the Savage). At 100 yd the first two went into one hole and the young vet was quite impressed that $100 worth of hardware had done this so easily on top of the shooting bench. He went away to buy what he could at Sportmans Warehouse and order the rest online.
07-06-2012, 09:39 AM
#1042 |
Road Captain
Oddometer: 9,322
When I was doing SASS competition I mainly shot cast lead with Goex black powder. I used a Lee hand press to decap the .45 Colt and .45-70 brass before leaving to get it soaking to make cleaning easier. The hand press worked great! I also used it several times at the range when I was working up some .22-250 prairie dog rounds much like you did. I think it is a worthwhile addition to any reloader's kit.
Pain in the Butte Ranch Durango, Colorado - Calculated risk or forbidden fruit? |
07-06-2012, 06:47 PM
#1043 | |
Slacker
Oddometer: 29,466
The finishers medal is satisfyingly heavy... Neduro on Dakar The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them. -Furious D |
07-07-2012, 02:32 PM
#1044 | |
Thumper jockey
Oddometer: 4,025
http://www.buffalobore.com/index.php...duct_list&c=53
07-08-2012, 05:48 AM
#1045 | |
Slacker
Oddometer: 29,466
The article you linked is from a guy selling hard cast bullets. I'm shocked he is making a case for them. Shocked, I tell you.
07-08-2012, 10:19 AM
#1046 | |
Thumper jockey
Oddometer: 4,025
07-10-2012, 06:27 AM
#1047 |
Broken Hearted
Oddometer: 9,543
Can someone with a Hornady manual check a recipe for me?
I'm loading 357 magnum, using Hornady's 158 gr XTP (the FP version, but that shouldn't matter) into Hornady cases with 2400. The main reason I want to back up my Lyman is that Hornady uses short brass (1.25") in their factory ammo, so my once fired stuff is a lot shorter than the rest of my brass. thanks in advance. |
07-10-2012, 06:46 AM
#1048 |
Wag more Bark less
Hornady 4th edition calls for 13.5 gr max of 2400 @ 1400 fps
07-10-2012, 08:01 AM
#1049 |
Broken Hearted
Oddometer: 9,543
Wow, that is really low. Lyman calls for a max of 14.9, Alliant lists a max of 14.8 for a 158 gr Speer JHP.
I guess that might explain why my handloads went a little quicker than the factory ammo. Does the manual give a trim length and an OAL? I was really surprised at how short the factor brass was, I asked one of their technicians and he said it was because their leverevolution bullets are long and they use the same brass across the product line. |
07-10-2012, 08:11 AM
#1050 | |
Knees in the Breeze
Oddometer: 4,758
I have to keep them separate when reloading to make the seating/crimp easier.
And all you are left with is a vast featureless blancmange de merde. - Bongolia 2003 XR650R (plated) For Sale |
| Thread Tools | |
