02-23-2013, 09:59 AM
#1186 |
V4 Whore
Sounds like he has been loading with H110 too, I don't think you can go much slower burning in 357.
Which is a bummer, as I want one of the revolver caliber carbines but they don't appear to be all that accurate. El Guero screwed with this post 02-23-2013 at 10:30 AM |
02-25-2013, 05:17 AM
#1187 |
winter is coming
Oddometer: 9,153
While I don't have empirical data to support this, my 'sense' is that I got somewhat better results shooting a 44 Mag out of a bolt-action rifle/carbine than results with various 357 caliber rifles seem to demonstrate. And I know that I get even better results with the 500 S&W Magnum round out of an H&R HandiRifle than I did with the 357 in the Marlin. I'm not sure why this is. Rifle variables or something inherent in the cartridge? I remember that a number of years back Ruger chambered their excellent No. 1 single-shot in 357 Magnum. I wonder how well those shoot? I've had excellent results wiht the No.1 in rifle calibers (7mm Remington Mag, 270, 375H&H and 9.3x74R).
Μολών λαβέ Hard cases make bad law. |
02-25-2013, 05:31 AM
#1188 |
V4 Whore
I just generally assume that it has something to do with bullet design. Probably 99% of bullets fired through a 357 rifle were designed to be shot from a revolver within 50 yards. At a minimum I imagine that the increased velocity would affect the accuracy of even the most thoughtfully designed pistol bullet. I'd like to see people shoot more with the Hornady pointed bullets to see if that helped at all.
02-25-2013, 07:23 AM
#1189 | |
Slacker
Oddometer: 29,458
The finishers medal is satisfyingly heavy... Neduro on Dakar The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them. -Furious D |
02-25-2013, 08:57 AM
#1190 | |
V4 Whore
02-25-2013, 12:41 PM
#1191 |
Oddometer: 2,799
I have loaded practice rounds for my .35 Whelen using 158gr XTP's, but I limit velocity to less than 2000fps. Not super accurate, but not too bad.
I was born... I shall die... but the time in between is mine. WWJWD? What Would John Wayne Do? Southwest Riders visit www.my2wheels.com. |
03-01-2013, 04:11 PM
#1192 |
Back at last
Oddometer: 9,887
Question for you loading Gurus - when buying new equipment, is it a good idea to stick with the same brand for the major components - like press, dies and shell holders, or can you mix and match?
I did not get a straight answer from my local gun dealer and of course the Lyman reloading book suggests - Lyman. Not that I'm adverse to buying their stuff, but it's mostly mail order whereas I can get RCBS stuff at the local store. Another question regarding die setup - once a die is adjusted in the press, it looks like there's a locking collar - I assume this allows you to reset the die at the proper location each time you reuse it? That would seem to obviate the need for a turret style press for most reloading purposes, correct? Although there's no loading materials out there so I'm not sure this goes anywhere. Thanks.
"More than any time in history, mankind now faces a crossroads. One path leads to despair and utter hopelessness, the other to total extinction. Let us pray that we have the wisdom to choose correctly." Woody Allen "*enhance* not enjoy, gramps mcbuzzkill" - Lemon G.
03-01-2013, 05:09 PM
#1193 | |
Oddometer: 1,302
I like a single stage press for rifle stuff, and a progressive for straight wall pistol loads.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper |
03-01-2013, 05:30 PM
#1194 | |||
Moobless Adventurer
Oddometer: 4,818
03-01-2013, 08:27 PM
#1195 |
Back at last
Oddometer: 9,887
Well, not having loaded before. My initial goal is to save some bucks on shooting ammo - certainly would load for my .40 S&W, maybe my 9MM. I suppose that this could be 300 rounds a week between the two if I had the materials.
For rifle, I'd like to load for my .30-30 just for plinking ammo, and might want to load lower power loads for a .30-06 - the hunting loads hurt too much for fun shooting. Future goal is to get a target rifle in .308, but that may be down the road. I imagine that I would probably want to start to use cast bullets to save additional bucks, and would consider doing my own casting at some point. All of this is tempered by the fact that no loading materials are available....
03-01-2013, 08:37 PM
#1196 | |
Slacker
Oddometer: 29,458
03-02-2013, 07:39 AM
#1197 | |
Oddometer: 1,917
Some of my dies are set and locked down, like the 9mm, 45, 40S&W since I don't change the loads. The case stays the same size, assuming you trim properly when needed. The only time you might need to reset the die is changing bullets size / weight / design and can require resetting the die. Same for switching from 38 to 357 or 44 special to 44 mag since the cases are different lengths. Note that if you load cast lead slugs and they have a heavy lube on them you can get a build up of lube on the seating die that can change the seating depth if you do not pay attention.
Wherever we go, there we are. DEFINITION OF A VETERAN A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life." Author Unknown |
03-02-2013, 10:06 AM
#1198 | |
Back at last
Oddometer: 9,887
Thanks for the reminder on lead lube - that would be a lousy lesson to learn on the 9 or .40 given how small those cases are. Looking at the hardware required to do the job, I'm thinking a Lyman set including the case trimmer looks like a pretty good setup to start with - they seem to be the only kits with a case trimmer standard. I know there's a pack of stuff that has to be added to that, shell holders, die sets, caliper and priming system... Without shopping for all of the hardware items individually, is there anyone who averages lower prices than Midway?
03-02-2013, 11:36 AM
#1199 |
Oddometer: 2,534
with skyrocketing prices for ammo ... .223 used to be one would do special loads for more accuracy or different weight bullets to justify hassles of reloading .223 .. not to save $$$.
now days it's common to pay $1 per round for .223 ... making it economically desirable to reload even .223. good thing I'm covered with reloading components ... have not purchased or sold anything since this scare started...
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
03-02-2013, 04:57 PM
#1200 | |
Oddometer: 1,302
If you are going to load for a .40 or 9mm, check your pistol's rifling to make sure that it is not polygon style rifling ala Glock. If it is that type, you will probably want to avoid lead bullets. They tend to lead up badly even with mild loads.
| Thread Tools | |
