Old 03-18-2009, 06:03 AM   #1
LuciferMutt OP
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,387
What's a good carb sync tool (not looking for homemade this time)
What's a good carb sync tool for bikes with two cylinders? (parallel twin in my case).
Right now I'm using the two bottle contraption with the hose that connects the two bottles so nothing can get sucked into the carb. I hate using it; I can't ever tell if the fluid is really flowing one way or the other until the carbs are WAY off. I just can't get good adjustments with it. I had to do my second sync with this tool last night and I do beleive I made it worse... But I had to ride in this morning since my wife couldn't carpool with me and my bike can park at work -- car can't. The bike is running good except for an off-idle stumble/hesitation that was there the last time the carbs were out of sync.
Anyway, I'm giving up on all the homemade tubes and fluid crap. I want something digital or with gauges. I've heard electronic sync tools (twinmax?) are quite good but wanted to see if anyone has used one. Suggestions?
LuciferMutt screwed with this post 03-18-2009 at 06:17 AM
LuciferMutt is offline   Reply With Quote
Old 03-18-2009, 06:33 AM   #2
yosmitetom
Oddometer: 3,354
Morgan Carbtune is what I use.
Carbtune
yosmitetom is offline   Reply With Quote
Old 03-18-2009, 08:13 AM   #3
showkey
Oddometer: 1,970
+10 carbtune
showkey is offline   Reply With Quote
Old 03-18-2009, 08:50 AM   #4
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,161
Although home made this works well. I use two dial vac. gages. These are the type that can be adjusted. Before starting to sync. I connect both to the same vac source and adjust to read the same if needed. The gages are mounted in a pc. of shipping foam one on top of the other slightly offset so it is EZ to see both needles at the same time.
Another important part of carb. syn. is to set the idel throttle opening of each carb. the same. This is so that each throttle will open from the same point. This will insure that the different fuel flow circuts in the carb. start at the same time during throttle opening. I use a 2" dial indicator to measure the height of the slide in the carb. bore. Something different may be needed for butterflies.
Hopfully you did the sync. at some RPM that stablized the fluid columns and you could see the difference. The same hold true for most sync. tools.
For my Guzzi 4000 RPM is the point the needles stablize.
Pic comming.
Here it is:
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc screwed with this post 03-18-2009 at 06:18 PM
fritzcoinc is offline   Reply With Quote
Old 03-18-2009, 03:13 PM   #5
duck
duck's Avatar
Oddometer: 10,403
TwinMax - not as fancy or 99.999999999999999999% accurate but easy and quick.
duck is offline   Reply With Quote
Old 03-18-2009, 08:51 PM   #6
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,228
Morgan Carbtune. +10,000
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 03-18-2009, 09:02 PM   #7
pilot3
Oddometer: 417
What he said
pilot3 is offline   Reply With Quote
Old 03-19-2009, 05:09 PM   #8
FuriousGeorge
Oddometer: 97
One more vote for the carbtune. Simple and works great. So nice not having to worry about spilling any fluids. Just get the four cylinder version. The two cylinder version isn't much cheaper and you never know what you'll be working on in the future.
FuriousGeorge is offline   Reply With Quote
Old 03-19-2009, 09:09 PM   #9
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
The reason I like the TwinMax is because it is a differential gauge. It is an inexpensive (relatively speaking) tool that is portable and can be used in 'real world' testing.
And as is usually the case you get what you pay for. And any tool can be damaged due to abuse (being dropped for instance) so in the end it is about how much accurracy and reliability are you willing to pay for.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 03-19-2009, 09:20 PM   #10
mtrhd101
Garage Queen lover
mtrhd101's Avatar
Oddometer: 344
The newer Motion Pro works pretty good and no mercury.. Has adjustment for balance to sync before use..
mtrhd101 is offline   Reply With Quote
Old 03-20-2009, 05:30 AM   #11
2slow
Road toad
Oddometer: 456
Flowmeter
I'm using a flowmeter. Easier, cheaper, and quicker than vacuum gauges. Just stuff it in the inlet tract, either in the carb/throttle body or air horn and proceed. It is not as precise a method as a good vacuum setup but I find the results adequate.
http://www.cbperformance.com/catalog.asp?ProductID=572
2slow is offline   Reply With Quote
Old 03-20-2009, 05:33 AM   #12
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,208
I will put in a vote for the TwinMax. It is easy to use and I have had great results with it.
Marc
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is offline   Reply With Quote
Old 03-20-2009, 06:22 PM   #13
hugemoth
hugemoth's Avatar
Oddometer: 3,032
My favorite is still the old mercury stick but I don't even know if you can get them any more.
Q
Old 03-20-2009, 07:08 PM   #14
bwringer
bwringer's Avatar
Oddometer: 2,228
Right -- the Carbtune can be used on three and four cylinder bikes as well.
"Be the center of attraction in your circle of friends! Be the envy of friends and neighbors as they flock around to watch you tear down and tune up all kinds of motorcycles..."
Old 03-20-2009, 07:11 PM   #15
yosmitetom
Oddometer: 3,354
Q
I think you can still get 'em from China.
Times are GMT -7.   It's 12:13 PM.
