03-22-2009, 08:07 AM
#16 |
The Energizer Bunny
Oddometer: 3,794
Joe, I'd be curious as to what Pete says. Say hi to Mike and Mark for me.
ride till you can't. 1200GS black Cagiva Gran Canyon Italiano/rosso |
03-22-2009, 08:08 AM
#17 | |
Broken Roadie
Oddometer: 2,784
03-22-2009, 08:52 AM
#18 |
Oddometer: 268
As I posted over on the F800 forum:
While it does look ominous, if you look at the parts fiche, it shows some sort of notches at that location. The thing I'd be concerned about is that the gap on the left lobe looks as though it impinges on the area rubbed by the cam follower, or drag lever, as BMW calls it. |
03-22-2009, 09:46 AM
#19 |
Sir Loin of Biff
Oddometer: 8,562
Ah, well. Hope you got warranty.
People before prophets. |
03-22-2009, 09:49 AM
#20 |
Oddometer: 61
normal my ass
If thats normal then why is the cam lobe burnt on the good side?????????????? your drag lever is probably wearing at an alarming rate. You may have metal blockage at your oil pump sufficient enough to cause overheating, and who knows what that grimlin will eat up. Its a casting defect pure and simple. the heat associated with grinding may have changed the hardness, or just caused it to weaken further. Why would a reputable dealer bawk at any warranty work?
03-22-2009, 10:45 AM
#21 | ||
Runcible Spoon
Oh, and it's "balk" It may still be a casting defect, but I'm not sold yet, based on just the one shot. It does seem clear from the photo that it was built that way, rather than having some material grenade off as some have suggested.
"Another road remains, but it provides no more. It can only take us away" |
03-22-2009, 12:05 PM
#22 |
Broken Roadie
Oddometer: 2,784
OK, looks like I'm going to have to open it up to get some more photo's....
![]() anybody have the torque specs I need? Haven't found a service DVD yet.... |
03-22-2009, 12:23 PM
#23 | |
Paint it black.
Oddometer: 12,846
That's what I figured from your ride report. Most awesome by the way. The thing is..you're home now and it needs to be repaired properly. I would have been done with the thing/bike after the chain snappage. The shock loads that the trans saw during that mess would be enough to warrant a full tear down and inspection along with replacing bearings on the shafts. You need somebody to verify what caused the oil leak. Did the shop that did their best to get you on the road just smear some sealant on a cracked valve cover from a chunk of metal that got flung off the cam or what. You paid a ton of money for that bike and it needs to looked after properly now that you've made it home. Talking to trusted sources and techs isn't going to fix a thing. It's time for some elbow grease.
03-22-2009, 02:21 PM
#24 | |
Oddometer: 11
Those divots/nothces in the cam surface are there for a purpose. Since the cam follower is centered over the cam lobe, the cam follower would tend to always track the same position and never rotate. That would cause wear on the cam follower surface. By casting a small notch across part of the cam lobe (during a time when the valve is closed), there's a momentary interval when friction on one side of the cam follower is different than the other causing the follower to rotate slightly. The next time a valve is opened, the follower is in a slightly different position and the wear is distributed. I'd be more concerned with what looks like white metal flakes on the cam surface. If it's steel, that's a problem; if it's aluminum, then it's probably flakes from removing the valve covers. Bruce Santa Fe, NM |
03-22-2009, 02:58 PM
#25 | |
PHAT BASTARD
Oddometer: 974
Careful there. You're disagreeing with all the "experts" here LOL.
"Well Traveled Wise-Ass" 2006 DRZ400E 2005 R1200GS |
03-22-2009, 03:01 PM
#26 | |
Red Clay Halo
Oddometer: 11,159
Be wary of torque specs for the valve cover bolts. The valve cover bolt is shouldered all the way down to the threads. This means that when the shoulder bottoms out on the top of the cam cap (that threaded hole in your photo) it stops. So you basically go from loose to can't turn the bolt by hand anymore. At this point it is very easy to snap the valve cover bolt, and often the torque specs (probably because the threads are full of oil) are too much and will snap that bolt right at the shoulder. I always snug them up by hand using a small 1/4" drive ratchet. It's very easy to feel what is snugging, and in reality it takes almost not stretching to break those bolts because there is almost no material to stretch between the shoulder and the thread.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
03-22-2009, 03:06 PM
#27 | |
Oddometer: 11
Bruce |
03-22-2009, 03:08 PM
#28 |
Hooked Up and Hard Over
Oddometer: 7,438
Spanker ?
Frank Reinbold "Every bike I ever had, was the best bike I ever had, when I had it" *2010 FOREVER WEST* NEW ENGLAND AND CANADA OFFROAD F800GS 14 DAY IDAHO ADVENTURE KTM 950 TRANS AM TRAIL WEST TRANS AM TRAIL VID CLIP THE DEAN OF WESTERN ADVENTURE ROUTES |
03-22-2009, 03:16 PM
#29 |
Oddometer: 2,366
I would like to see a brand new camshaft and compare it against the fubar'd one. It may not be a problem but from my experience, this does not look good!!
I would ask my dealer to order one in and prove to me mine is okay: put up or shut up and fix it!!
"I'm a thousand miles from nowhere,Time don't matter to me, Cause I'm a thousand miles from nowhere, And there's no place I'd rather be!! |
03-22-2009, 03:26 PM
#30 | |
Marinoni man
Oddometer: 1,858
As the 800 does not have either the follower will always be in the same position. I would think the follower has end play to tolenance but no movement in relation to the cam. |
