Old 09-07-2011, 04:25 AM   #1
BluWolf OP
Oddometer: 188
Powerlet USB adapter
Has anyone found an aftermarket USB power adapter for the powerlet outlet on the F800 yet? Bob's says Powerlet is working on it but no ETA is available. The battery on my phone doesn't last long enough for my longer rides and I us it for music and the occasional GPS function.
Marc Langlois
BMW F800GS
BOA #166285
BluWolf is offline   Reply With Quote
Old 09-07-2011, 05:10 AM   #2
loph917
Beard Bros Racing
loph917's Avatar
Oddometer: 3,411
this isn't an exact answer to your question but i believe it's a better alternative (for me anyway). i obtained a centech ap-2, wired it into the battery. from there i electrified my tank bag using an SAE connector (to be able to disconnect and remove the bag as needed). in the bag i wired up a cigarette outlet (none of this is very neat but 1+ years on it is still working great). i use one of those dual-port cigarette-to-usb adaptesr. i can run my gps, cell, charge the sena, or use the air pump. works great. it gives more flexibility than a dedicated usb outlet. that said, i do want a dedicated usb port run off the centech-2 for the gps but it's not critical now.
[ this space for rent ]
loph917 is offline   Reply With Quote
Old 09-07-2011, 05:42 AM   #3
TowPro
I want to ride
TowPro's Avatar
Oddometer: 1,787
I also wired my tank bag setup direct to the battery, now I am having second thoughts.
My delorme GPS has been acting strange since I moved it to my F800. Problems like screen locking up but still displaying a picture (only not updating), or locking up in the off position. I think this is being caused by a voltage spike while starting the bike (but I don't have a O scope to test it).
Not sure how much electronics I want running on this wire if it is a voltage spike. I will be switching the bps to using the factory GPS connector.
I think the hot setup would be to take direct off the battery, but use a load shed relay so during cranking (or off) the wire is not HOT.
I think the high beam fits that logic.
2010 F800GS Stone Road Touring bike!
TowPro is offline   Reply With Quote
Old 09-07-2011, 07:20 AM   #4
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 800
Cool2 Wired
About the first thing I did to this bike was wire an SAE connector directly to the battery for running a pump or hooking up a battery tender. Later, when I needed more stuff wired up, I added the Termin-8 from Powerlet, which tucks right in behind the battery http://www.powerlet.com/product/term...-fuseblock/409 .
Now I can just use my old SAE-Cigar light cable to hook up a USB charger for Droid or Pod. Not sleek, but functional, especially with this little guy from BurnsMoto: http://burnsmoto.com/usb-car-charger.php
However, it seems like you're looking for a more sano installation like this: http://burnsmoto.com/micro-usb-stand...le-ppc-027.php
Bucko is offline   Reply With Quote
Old 09-07-2011, 02:24 PM   #5
Karbono
Rookie GSer
Karbono's Avatar
Oddometer: 335
bought an adapter on ebay. works great.
for example: http://www.ebay.co.uk/itm/Powerlet-B...#ht_1012wt_905
and you probably need this as well:
http://www.ebay.co.uk/itm/USB-Cigare...item3cbbaf7ee7
I did a quick search and those were the first results.
You can see my setup here:
http://www.advrider.com/forums/showthread.php?t=688628
Cheap. easy, effective.
Karbono is offline   Reply With Quote
Old 09-10-2011, 03:13 PM   #6
Stackator
F800GS goodness
Stackator's Avatar
Oddometer: 1,343
TAPP™ LITE USB POWER PORT with DIN 4165 Plug (BMW)
Here you go
https://www.adventuremoto.com.au/pro...118afcda1d4d71
Golf courses are Enduro parks waiting to be discovered
Refresher for the Australian forum: http://www.deakin.edu.au/current-stu...outs/apost.php
Stackator is offline   Reply With Quote
Old 09-10-2011, 04:06 PM   #7
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 592
When on trips I have a SAE cable off the battery (Powerlet) that links through another cable to charge up a Goal Zero Sherpa 50 battery (available at REI among other places). This can then be used to charge (via USB or dc plug output) all my other devices like Go Pro, camera, I-pad, I-pod, cell phone, Petzl headlamp, and battery charger (for AA's and AAA's). I just route the SAE cable up into my duffel where I keep the Sherpa 50 battery and charge it while I ride. This battery can also be charged off of the Goal Zero folding solar panels but this takes about 6 hours of direct sun.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 09-10-2011, 09:00 PM   #8
raider
Big red dog
raider's Avatar
Oddometer: 1,333
I lost my accessory-socket compliant iphone charger on a trip, so I did a field repair using parts from a nearby auto store and my multitool.
First, I bought a cheap Chinese iphone 12V charger from a gas station - about $10. Then I bought a convertible 12V/accessory socket plug - the kind that has a red cuff on the end that you can remove for the smaller accessory socket - plus a 12V socket and some insulated, coily 10A (coily like on your old telephone handset).
I used the screwdriver on the multitool to dismantle the 12V plug to work out where + and - go (it's + in the centre, - on the edges), and then put it back together. I used the knife poke a hole in the side of my tankbag, ran the wire through it, and then used the blade to strip the ends of the wire and assemble the 12V/acc plug and the 12V socket I'd bought, using the old twisted wires and electrical tape method to make the joins.
Then I just plugged my cheap charger into a conventional auto 12V socket inside my tankbag. I meant to come home and upgrade my twist-and-tape wire joins to proper crimped blade connectors, but never got around to it. 2 years later it still works like a charm and has never fried anything.
"It's cunnilingus and psychiatry that's led to this" - Tony Soprano
10 F800GS
raider is online now   Reply With Quote
Old 06-04-2013, 09:01 AM   #9
ADVCanuck
Oddometer: 5
I know I'm reviving an old thread but...
I wanted to ask Ronin ADV how the Sherpa has been working out, now that some considerable time has passed? Are you out there?
Cheers
ADVCanuck is offline   Reply With Quote
Old 06-04-2013, 06:36 PM   #10
PatrickM
Oddometer: 210
I use this combination when just cruising on the highway...
Powerlet to cigarette adapter
Then cigarette to USB (low-profile)
PatrickM is offline   Reply With Quote
Old 06-05-2013, 04:08 AM   #11
JRose
JRose's Avatar
Oddometer: 271
Originally Posted by Stackator View Post
Ouch. $54!?!??
If it were me (I personally cannot stand cheap things that are overpriced for no reason), I would pick you up one of these jewels. They can be found all day long for $15 on Al Gore's interwebz.
Take 15-30 minutes to run a couple of wires, and be done. Plus the benefit of being able to mount it wherever you want.
JRose is offline   Reply With Quote
Old 06-05-2013, 09:10 AM   #12
HeadinSouth
vroom!
HeadinSouth's Avatar
Oddometer: 80
I have a similar setup to the others with a plug running into my tankbag. I run this http://www.scosche.com/usb-car-charger-dual-port since I need to charge my new ipad and most USB car chargers dont put out enough wattage.
HeadinSouth is offline   Reply With Quote
Old 06-05-2013, 10:44 AM   #13
jengel451
1 Cool MotherF#$cker
Oddometer: 164
Just be sure you connect to a switched circuit, they draw power even if nothing is plugged into it....I found out the hard way on my XR650R.
jengel451 is offline   Reply With Quote
Times are GMT -7.   It's 02:04 AM.
