Old 04-11-2013, 04:15 AM   #361
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,594
Originally Posted by Spektrum84 View Post
My old iPhone 3GS gets very warm if I'm using the GPS for extended periods, by maybe newer phones are more efficient and may not generate the same amount of heat.
My 4S also gets uncomfortably warm when I use the gps with the display on for extended periods. I've experimented with using the phone in the car, powered from the lighter outlet, and after a couple of hours of that I have to let it cool before I put it back in my shirt pocket.
I always go back to a dedicated gps.
Emmbeedee is online now   Reply With Quote
Old 04-14-2013, 07:55 PM   #362
Lager Meister
Work less, ride more
Oddometer: 157
Originally Posted by RobTheRigger View Post
Does anyone know if the Touratech GPS adapter for the Adventure (TT P/N 044-0770) work on the support bar for the touring screen? The BMW clamp for the Navigator 3 will mount directly to the support bar, but is angled way too far down with the screen installed. Any other inexpensive options for getting the GPS above the gauges? If this has been brought up, I completely missed it, so don't crucify me! THANKS!
- Rob
I went down this path and was able to get it to work with some creativity, but didn't like the result and took it off. There are two problems you have to solve to make it work. The diameter of the tubing on the F800 touring screen support is too small for the clamps on the Touratech part. I used some pieces of thick flat rubber to get a tight fit. The other problem is the bar on the Touratech part that you mount your GPS on is too long, so the whole thing is too wide (side-to-side) to fit in the space available on the touring screen support on the F800. To solve this, you need to make a shorter bar. I used a piece of threaded stock cut to the right length and a bunch of lock nuts. I had it to the point where I thought it would be stable, but didn't like where the GPS was positioned and decided to just scrap the whole idea. I took some pictures before I tore it apart, but can't seem to find them. I still have all the pieces, but sold the touring screen bracket when I sold my Cee Bailey's screen.
My advice is not to go down this path, but if you want to give it a shot I'd be willing to sell the Touratech bracket and throw in the pieces I cobbled together to make it work.
Lager Meister is offline   Reply With Quote
Old 04-15-2013, 07:03 PM   #363
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,485
Laugh ram mount
I bought one of these for my Iphone (gps)... works fantastic for every day running around.... should work great with the ever changing GPS...
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 05-11-2013, 07:48 PM   #364
poppy510
Oddometer: 31
poppy510 is offline   Reply With Quote
Old 05-12-2013, 10:50 AM   #365
slowpoke
slowpoke's Avatar
Oddometer: 103
Originally Posted by poppy510 View Post
How the hell can you even see your instrument gauges?
slowpoke is offline   Reply With Quote
Old 05-12-2013, 09:09 PM   #366
poppy510
Oddometer: 31
It looks a little exaggerated in the first photo. Truth is, the real problem is seeing the GPS...even with the sunshade you can't really see the damn thing.
Old 05-20-2013, 08:31 PM   #367
Yip
gą - n00b
Yip's Avatar
Oddometer: 23
This is mine. :)
"life's a journey..."
Yip is offline   Reply With Quote
Old 06-01-2013, 06:02 PM   #368
OZZY-GS
OZZY-GS's Avatar
Oddometer: 426
Montana & Touratech mount
hi ,
This is my setup.
Works well and its were it needs to be.
Riding
BMW F800GS
OZZY-GS is offline   Reply With Quote
Old 06-02-2013, 01:20 AM   #369
thleon
Theo
Oddometer: 51
Is it stable enough? Are there any vibrations on the GPS?
thleon is offline   Reply With Quote
Old 06-02-2013, 01:47 AM   #370
OZZY-GS
OZZY-GS's Avatar
Oddometer: 426
There are some as the hole instrument cluster moves also . The Touratech mount has rubber mounts. Have not done a lot with this setup but so far so good.
Riding
BMW F800GS
Old 06-02-2013, 10:17 AM   #371
Calgary06
Calgary06's Avatar
Oddometer: 160
That's where I have my montana. I is ok on the highway but once offroad it bounces quite badly. I've mounted it using a ram mount and a new hole drilled in the metal frame. I was thinking of attempting something similar to what Mike.C did one for extra support. There is a lot of stuff to bend around down by the triple clamps though...
(can't seem to paste the link from my phone. Post 388 from the D3 who's got one thread.)
http://advrider.com/forums/showthread.php?p=20145289
EEUC
Calgary06 is offline   Reply With Quote
Old 06-02-2013, 03:38 PM   #372
OZZY-GS
OZZY-GS's Avatar
Oddometer: 426
Yeah I saw that post but he had a 650 which has a lot more room around the triples.
Riding
BMW F800GS
Old 06-02-2013, 03:42 PM   #373
pilesofmiles
Life is an Adventure
pilesofmiles's Avatar
Oddometer: 711
I ordered this and will have it installed (plug and play) next Saturday.
I like a clean neat install.
http://www.bmwmotorcycles.com/_commo..._adventure.jpg
"Life is no dress rehearsal"
pilesofmiles is offline   Reply With Quote
Old 06-02-2013, 04:13 PM   #374
Calgary06
Calgary06's Avatar
Oddometer: 160
Do you know which Montana BMW is using? Camera or no camera?
EEUC
Old 06-04-2013, 12:43 PM   #375
pilesofmiles
Oddometer: 711
Not sure, but will post up after install.
Times are GMT -7.   It's 04:01 PM.
