Old 10-17-2009, 10:36 AM   #31
Law Dawg (ret)
Law Dawg (ret)'s Avatar
Oddometer: 820
Originally Posted by LimeRider
GI am new to BMW and I have a few questions.
$190.00 for a battery charger??? I see BMW chargers for sale on eBay for $70.00, is there any reason to buy a charger from the dealer?
Bottom skid plate and engine protection bars? I live in a rural area, and I expect to take this bike off road often. To me, the bottom plate makes good sense, but it is not clear to me what the bars would save. The engine on the 800 is tucked away inside the frame.
Brush guards, do these do anything strange at high speeds?
1-Answered above.
2-Get the bottom plate and make sure it protects the oil filter and cooler. Also get the crash bars as they will save you gobs of cash in even a tip over and give you more peace of mind in the dirt. I have Adventure Spec bash plate and crash bars...love them both right from my install to day to day rides.
3-Brush guards protect (to a degree) your knuckles and hands from rocks/bugs/branches/cold/etc. I have had them on three bikes now and have noticed no problems or strange anything at speed up to and including 100+ or -.
Those are the big ones IMHO.
Firefly; the way it will actually be...rednecks in space, dealing with the mess made by urban progressives while being hounded by them and all without any goofy alien stuff. Shiney!
Law Dawg (ret) is offline   Reply With Quote
Old 10-17-2009, 01:27 PM   #32
Aether
Oddometer: 251
Originally Posted by alexcorral
You can hook up a Battery Tender Jr. through the standard power socket before you switch off the ignition and the battery will continue to charge after you switch it off.
...and then stop when the CANBUS system shuts it off a couple of minutes later. A standard Battery Tender will only work if you wire it through a direct connection to the battery that avoids the CANBUS system.
You posted this same misinformation before in this thread: http://advrider.com/forums/showthread.php?t=509696
Several people corrected you there too and you admitted that you hadn't tried it yourself. Please stop leading people astray!
Aether is offline   Reply With Quote
Old 10-18-2009, 11:25 AM   #33
alexcorral
alexcorral's Avatar
Oddometer: 1,305
I tried it personally and it worked for a while. How long will it take to shut down?
2014 BMW R1200 GS Adventure
2014 KTM 350EXC-F
2013 Harley Davidson 1200 Custom 110th Anniversary
alexcorral is offline   Reply With Quote
Old 10-18-2009, 07:26 PM   #34
dukedar
60 easy payments!
dukedar's Avatar
Oddometer: 340
It stays on for about 15 minutes according to the manual:
and they talk about the charging also:
Umm, RTFM?
Darren
'09 BMW F800GS
dukedar is offline   Reply With Quote
Old 10-19-2009, 03:47 PM   #35
alexcorral
alexcorral's Avatar
Oddometer: 1,305
I'll time it... I'll get back to you on the outcome
2014 KTM 350EXC-F
Old 10-19-2009, 05:21 PM   #36
Aether
Oddometer: 251
It's a moot point. The purpose of the Battery Tender is to keep your battery fully charged over time. Since the CANBUS shuts off the connection to the Battery Tender a few minutes after the ignition is turned off, it's not going to be able to do its job. As has been said several times, it needs to be connected directly to the battery, not via the CANBUS system.
-A
Old 10-21-2009, 08:31 PM   #37
Roy Barnes
Riding for the SON
Oddometer: 28
Originally Posted by Law Dawg
Don't get the BMW hand guards if you think you might want a friction type throttle cruise control (ie;Kaoko). Aftermarket offers some very nice ones that provide both better hand/controls protection and block more wind...for MUCH less $$$.
I have the BMW handguards and a Kaoko throttle holder. I works fine. They have a special one for the handguarde.
Roy Barnes is offline   Reply With Quote
Old 10-21-2009, 08:34 PM   #38
Firefight911
Firefight911's Avatar
Oddometer: 997
I have the Wunderlich with the BMW handguards. Works great!
Ride Safe, Ride Often, RIDE!!!!
Firefight911 is offline   Reply With Quote
Old 03-26-2010, 03:07 PM   #39
dajg
dajg
Oddometer: 65
fuses?
f650 twin - anyone tell me about fuses? what type & capacity are used, and where are they?
thanks
d
dajg is offline   Reply With Quote
Old 03-26-2010, 05:58 PM   #40
Roy Barnes
Riding for the SON
Oddometer: 28
thanks
d
My understanding is that there are not any fusses. The system just shuts down in a current draw above what is expected.
Old 03-26-2010, 06:15 PM   #41
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,614
Correct, no fuses.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 03-26-2010, 06:54 PM   #42
805gregg
Just Stroming along
Oddometer: 1,581
Just bend over, that's what most owners do.
805gregg is offline   Reply With Quote
Old 03-27-2010, 04:03 AM   #43
yellow zebra
yellow zebra's Avatar
Oddometer: 138
is this correct?
Originally Posted by MCMXCIVRS
Remove the plug from the cover, then slide the cover back the opposite way. Took me a while to figure it out when I did the same thing. I just folded the lead over and then zip tied it off to the side. Makes the space much more useable. Ive got my mini tire pump and patch kit in there now.
I asked same question a couple of months ago, and I thought they advice was to ensure I re-connected the two together, out of the way, since the leads 'needed' teh dummy plug??? It this correct? thanks.
yellow zebra is offline   Reply With Quote
Old 03-27-2010, 12:25 PM   #44
gr8ridn
gr8ridn's Avatar
Oddometer: 413
If you are asking about the plug in the center of the tail behind the seat, you are correct. You need to keep that plug capped with the terminating resistor in the cap. The CANBus needs this to maintain reliable communication with the tied in components. With out the cap the ABS, ECM, ZFE and instrument cluster modules are subject to errors and disrupted operation. There is a spring clip that holds that cap in place you can unlatch and tie the assembly out of the way. BMW should have taped the plug and cap out of the way in the first place.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 03-27-2010, 01:22 PM   #45
dukedar
60 easy payments!
dukedar's Avatar
Oddometer: 340
Puke
You guys without alarms make me jealous
Darren
'09 BMW F800GS
Times are GMT -7.   It's 07:33 PM.
