03-27-2009, 10:48 AM
#31 |
More tacos than you
Oddometer: 5,123
Well, here are some replies from the airlist from some notable airheads:
"... It tries to keep oil temps below dangerous figures that can and does occur, in either single or dual plugging. There is nothing to ask...BMW put the coolers on for a reason. It certainly wasn't for running up the cost of the machine !!...Be careful what you hear on the list ........Oak" And another... "As for your engine, if you were traveling light and staying on pavement, it probably would not matter either. The conversion has to be done correctly, including changing out the filter center tube. You'd be well advised to fit the deeper R80/R100 oil pan and pickup along with the correct dipstick. If you anticipate some offroad and low-speed riding the cooler will actually provide some benefit. The risk is that you could easily rupture the cooler in off-road excursions. Tom Cutter Yardley, PA http://www.RubberChickenRacingGarage.com "To get what you never had, do what you never did." "
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
03-27-2009, 11:08 AM
#32 | |
G(/)S ... what else!
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me] ... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake] Stephen Bottcher Ontario, Canada '72 R75/5 The Blues www.stephenbottcher.net |
03-27-2009, 11:39 AM
#33 |
Now fully goosed
Oddometer: 2,687
Of fit one of these - minimul reduction of ground clearance but you can use the stock pan with it's skid plate mounting holes
http://www.wunderlichamerica.com/mm5..._Code=R100GS-U
Sometimes you get the ABAT....and sometimes the ABAT gets you |
03-31-2009, 05:52 PM
#34 |
I have read this thread over and over and it provides excellent info. Now, I was concerned running the deep 1983 oilpan on my G/S from day 1. On the front most of the fins are already damaged, most likely from stones flying and/or touch ground. I want the large sumpguard back on, but not with the deep pan, as that would be another 1/2in off the ground clearance. So back to the shallow GS oilpan it goes. Based on all issues discussed here, especially the reduced cooling area of the shallow pan and the restricted airflow due to the sumpguard I will add the cooler. I will however go for the 1987-on monolever version with oil thermostat. For that, I will need the longer stub pipe, part number 11 42 1 335 387 (EUR 17 = about USD 22). The thermostat alone new is EUR 175, which is approx. USD 230. So one has to look for some second hand parts.
I will however see, if I get the oilcooler mounted on top of the front fender, underneath the headlight.
10-16-2011, 09:41 PM
#35 |
Oddometer: 14
resurrecting the discussion
Any new thoughts on this topic?
I'm getting ready to purchase another oil cooler after my 92 GS took a dump on the highway and sprayed oil all over my left shin. I had relocated the cooler with the Touratech kit several years ago. Now either the kit came with a little brass bypass rod or I had purchased it "just in case" - the rod had threads on both ends to connect the lines. On the roadside, I fumbled through the tool kit hoping I had packed away the gizmo. There in a little baggie wrapped in a paper towel - voila! Threaded into the two stainless hoses, zip tied the hoses to the crash bar and off I went. As I read through this thread, I'm tempted to just leave it as is. Anyone have long term experience lately with running their airhead GS without the oil cooler? |
10-17-2011, 12:39 AM
#36 |
Oddometer: 1,186
I was given a temp dipstick and used it in my R80 GS with 1000 pots. No cooler. 2up with gear on the open road in summer it will sit on 140 c. About 20 deg c hotter than with a cooler. It never gets any hotter, even slow going it runs cooler. After a while I took it out. Cant worry about the temp if you dont know what it is !!
10-17-2011, 04:25 AM
#37 |
Oddometer: 3,460
I think bypasses that join the hoses together miss the whole point that a hose can be the problem. Sure it might be the easiest fix if the cooler breaks, but that's just one scenario. I'd feel a lot better about a fix that replaces the hoses and cooler with a solid bypass.
I eliminated the cooler on my '88 GS and have done some offroad stuff since then (the GS Trials at the Pownal rally for instance, which would be as much of a challenge as that bike is likely to see temperature-wise) and it hasn't died yet. Stock jetting. I think it still has the stock oil pan with the waffle plate; I can see the point that the later smooth pan and solid plate might hold in more heat, but that's assuming something about how effective the pan is at cooling oil in the first place. |
10-17-2011, 04:44 AM
#38 |
R 100 GS & R 100/T
Oddometer: 362
So does such an animal exist?
1992 R 100 GS (ZED) 1981 R 100/t (The Naked Lady) My Motorcycle Videos & More @ http://vimeo.com/user2721333 No Rules Photography @ http://brittrunyon.com/ |
10-17-2011, 05:10 AM
#39 |
Further...
Oddometer: 5,146
Yes. It's a small block machined out of aluminum. The hoses are removed from the banjo joints and the block simply replaces them. I first saw them in BMWON 15 years ago and recently saw it on ebay but I can't find any today. It's a lightweight, seemingly bombproof solution (although mine has never left the tool tray).
10-17-2011, 05:17 PM
#40 |
A proud pragmatist.
Oddometer: 2,866
Well, they did exist back in 1991 when I made one out of some old banjos.
![]() And this came with with my "new" GS, I am sure my hydraulic shop would make me something like that.
Have tools, will travel!
10-17-2011, 07:04 PM
#41 |
Oddometer: 1,054
10-18-2011, 04:04 PM
#42 |
A proud pragmatist.
Oddometer: 2,866
Ok....Touratech is still available it seems:
http://www.touratech.com/shops/001/product_info.php?products_id=496 But any hydraulic shop should be able to make you one of them, at least mine will and they do have the banjos. Probably cheaper than the Touratech part. Using old lines, removing the banjos and crimping new SS braided lines on them, not a problem either, I did that when I relocated my oil cooler on the 90 GS. Using old banjos, brazing them together with a short lenght of pipe in between,I think I just cut the pipe on one banjo to lenght and enlarged the hole in the other one to mate them together. Cheap but you have to braze with the cover off the bike and the banjos lined up and held there with the banjo bolts to keep the parts in line. Obviously you don't want to heat up the aluminium cover too much so out comes the good old welding blanket,small tip and lower melting point brazing rod. No removing/relocating the oil cooler on my "new" 87 GS, I have to keep it as original as possible to get the much cheaper "Collectible Vehicle" insurance in a year or so.
10-18-2011, 04:13 PM
#43 |
More tacos than you
Oddometer: 5,123
Get one made. A buddy of mine (the same one I started this thread about) ended up using the touratech bypass and it failed after a week of continuous all day riding. When confronted with this, Touratech said that it was not intended for continuous use and was only meant to "get you home" if you bang up your oil cooler. We stopped in at a random hydraulic fittings shop on the side of the road in San Diego and had one made in 10 minutes for $15. It has lasted the last two years and about 40,000 miles.
10-18-2011, 04:25 PM
#44 | |
Further...
Oddometer: 5,146
Regardless, that's why I don't like the nipple between the hoses or the single replacement hose. The block or brazed banjos are smaller, lighter and stronger - a perfect solution. |
10-18-2011, 04:31 PM
#45 |
the thread-killer
Oddometer: 4,297
Wow. And people continue to patronize these guys?
