Old 06-18-2004, 09:17 AM   #16
arroyoshark
Needing some space
arroyoshark's Avatar
Oddometer: 2,130
Originally Posted by Greg Minor
This is what I found the engine was really dirty on both sides I found this when I removed the tanks to change the oil. Both sides where leaking
Gotcha, no small bolts there. It also appears that the oil is seeping down from above, like perhaps when they replaced the valve covers the valve cover gasket, especiallyat the cutout for the camshafts, might not have been seated correctly. I know I had to check and redo mine during initial service to get them properly seated in there grooves. Somone may also have been forgetful about correctly torquing the valve cover bolts (4 each cylinder).
arroyoshark is offline   Reply With Quote
Old 06-18-2004, 11:06 PM   #17
jcividan
jcividan's Avatar
Oddometer: 10
Same Noise
I can hear the same noise, it could be a coincidence but it started after I fitted the Akras.
jcividan is offline   Reply With Quote
Old 06-19-2004, 08:36 PM   #18
Doug Matson
Doug Matson's Avatar
Oddometer: 2,031
If you take the inserts out of the Akra's the exhausts will chirp. Its the bolt hole for the inserts making the noise. Mine only chirps when those are out and the hole is not covered.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Old 06-19-2004, 10:33 PM   #19
Katoum OP
Katoum's Avatar
Oddometer: 711
I would say it's a coincidence. Its amazing how many bikes are chirping, but no one has found the cause, maybe we need a reward. I get one solid chirp every time I let out the clutch, and I also chirps in first gear when just idling along and gental throttle rolling on and off, like in city traffic. It may be doing it other times as well, we just cannot hear it. I'm still leaning to water pump as the cause. My dealer has heard it, and will be reporting to KTM. Not knowing, and fact that all bikes to do not do it, is driving me to .
Katoum is offline   Reply With Quote
Old 06-19-2004, 11:00 PM   #20
arroyoshark
Needing some space
Oddometer: 2,130
I was out riding my Transalp yesterday and it makes a chuffing sound, almost a chirp when accelarating at low throttle. This is intake noise. Maybe it is just carb or airbox intake noise that we are actually hearing on the KTM, but it's higher pitched because of even less throttle opening to take off. I will listen more closely next time on KTM.
Old 06-21-2004, 12:19 PM   #21
Shamal
Shamal's Avatar
Oddometer: 41
I had the chirping sound with stock exhausts (exactly as described above) and I still have it with the Akra's w/o baffles. So I think what you are hearing is different...?
Shamal is offline   Reply With Quote
Old 06-21-2004, 05:22 PM   #22
woodsrider
woodsrider's Avatar
Oddometer: 587
I heard the chirp slightly yesterday. Dangit -- I knew I shouldn't have read this thread!
2008 KTM 450 XCR-W
2008 KTM 690 Enduro
1997.5 KTM 200LE Jackpiner
'75 Bultaco 250 Alpina (M137)
woodsrider is offline   Reply With Quote
Old 06-21-2004, 05:30 PM   #23
Doug Matson
Oddometer: 2,031
It's a bird, a plane, no a KTM!
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 06-21-2004, 10:07 PM   #24
Katoum OP
Katoum's Avatar
Oddometer: 711
You know in the old days the miners used a Canary to monitor air quality, I hope KTM is not using the same process. So we really don't have to worry untill it stop chirping. God the suspense is killing me!!
Old 06-22-2004, 09:51 PM   #25
CaDirtSurfer
poop
Oddometer: 41
Mine chirps too and buddies also! Both 2004 models. What the hell is it? Could it be the SAS system? Anyone have chirpping with the SAS removed?
CaDirtSurfer is offline   Reply With Quote
Old 06-23-2004, 12:52 AM   #26
SMAC
Oddometer: 90
chirping
It does it with baffles in the Akras, it does it with or without SAS (it's not even fitted in Europe), it does it at constant throttle (even idling) when you release the clutch, but only in gear, I'm sure it's gear/transmission.
I've not stripped the clutch yet, but mine at 5,000 miles it getting very light and the fluid is very black. I'm getting worried. by the way bike has never been off-road so clutch work is pretty light. Is there a rod actuated by the hydraulic clutch which may need greasing, does anyone know ?
Smac
SMAC is offline   Reply With Quote
Old 06-23-2004, 01:26 AM   #27
KTMax
Ninth of the Nazgul
KTMax's Avatar
Oddometer: 1,099
Yes there is but it's inside the engine (and engine oil) so it doesn't need any maintenance.
I'm following this chirping story for a while now. Never noticed it. But how exactly does this chirping sound? Maybe we are talking about the whirring / whistling of the cam gears? The LC8 engine does have a VFR like wheew to it.
690 SMR
Pics & info @ MonoManiacs
KTMax is offline   Reply With Quote
Old 06-23-2004, 02:01 AM   #28
SMAC
Oddometer: 90
Chirping.
It sort of goes "chhirpp" or if you move off very slowly "chhhhirrrp".
It's not a wheeze, whirr, rattle or squeek, just a "chirp".
I'm wondering if it maybe a brake pad sticking ?
smac
Old 06-23-2004, 02:06 AM   #29
KTMax
Ninth of the Nazgul
KTMax's Avatar
Oddometer: 1,099
Weird...
690 SMR
Old 06-24-2004, 05:08 PM   #30
Anthony
Hurry up, Stephie!
Anthony's Avatar
Oddometer: 300
Dumb ass theory
I discovered yesterday that my wife's bike has been running with about half the coolant required. It was making the chirping noise that I think we are talking about I think more before I topped off the coolant. Could it be the impeller in the H2O pump?
Just a theory....
P.S. CHECK YOUR COOLANT!
Anthony
Hayduke drove a Jeep.
Anthony is offline   Reply With Quote
Times are GMT -7.   It's 04:01 AM.
